Idle Adjustment screw for 1800 engine - VTXOA
post #1 of 4 (permalink) Old 02-15-2013, 10:07 PM Thread Starter
salesphil1's Avatar
I have an 08 1800F and I'd like to set the idle adjustment at 900 RPM.
The screw under the coolant reserve is spring loaded and difficult , to me at least, to adjust with the spring
keeping the screw from turning and staying put. At this point, after it warms up the idle sets at 1000 RPM.
That's not too bad however my problem is when the engine is still warm after an hour or so the RPMs
after restarting drops to 800 RPM and even dips below briefly. I have read on a thread through Spike
that anything under 800 is not good due to possible oil pump problems. I would like to set it up a tad
but the spring action is keeping me from turning the screw. My Clymer manual doesn't get into detail
on how this adjustment works. Any advise from the techs would be appreciated.
Thanks,
Phil
salesphil1 is offline
post #2 of 4 (permalink) Old 02-15-2013, 10:47 PM
Philscbx's Avatar
I would like to set it up a tad but the spring action is keeping me from turning the screw.
My Clymer manual doesn't get into detail on how this adjustment works.
Any advise from the techs would be appreciated. Thanks, Phil
I wouldn't worry about oil pressure @ 800 RPM.
All that's required to prove the point - add oil pressure gauge.
What grade Number of oil is Used right now?
The Scoots 07 Neo III 03 18C ServMan Wiring Dia
Philscbx is offline
post #3 of 4 (permalink) Old 02-15-2013, 11:32 PM Thread Starter
salesphil1's Avatar
I think it's just Honda 10w 40 or 50
post #4 of 4 (permalink) Old 02-16-2013, 03:03 AM
fastspek's Avatar
Thanks,
Phil
According to the manual idle should be set between 700 and 900 RPM so 800 is perfect. It is easier to turn the adjusting knob if you detach it from the bracket and stretch the cable. Another way is using a Philips screwdriver to turn the screw that is in the centre of the knob.
brothers in arms:
2003 VTX 1800C (forever)
2002 HD FLSTF since 07/2008
" Today you raised more questions than giving answers "
fastspek is offline
