Lost power 1800C - VTXOA
post #1 of 8 (permalink) Old 09-09-2013, 12:55 PM Thread Starter
Lost power 1800C
Hope I can get some help with this. 03 1800C, no PC, no mods except shorty exhaust.
Had a problem last year with the bike loosing power after I got on the gas to catch up with some friends. Just started bogging down, loosing power on and off. Did this a three or four times and then ran fine for a while. Started acting up again until I didnt feel comfortable riding the bike. Check out the threads here and did the ground fix, no change. Ended up draining the tank and filling with new gas and added some fuel injector cleaner. Seemed to help the problem. Every now and them the bike would lose power briefly, a few seconds, then straighten out. Now it has started again. Again I drained the tank and added fresh gas, took it out in town for 10 mins or so and the bike ran great. Got on this morning heading to work and the first mile it was fine, then lost power again. The bike still ran but at maybe 75%, just really bogged down. Was able to get it home.
Where should I start looking for the problem? Fuel Filter-FPR?
Any help is appreciated.
Thanks
2003 Blk 1800C
duglaw is offline
post #2 of 8 (permalink) Old 09-09-2013, 01:01 PM
hawkvtx's Avatar
check in this order
Battery cables make sure they're good and tight
Air filter. Is it dirty? Needs cleaning and/or replacing.
Plugs. My be time for new ones.
Battery...how old is it? A weak battery can cause your problem.
FPR...may need replacing . the older models with the FPR has been a known problem.
Check the simple stuff first.
Livin' Blue in a Red state.
hawkvtx is offline
post #3 of 8 (permalink) Old 09-09-2013, 10:29 PM
Hans&Feet's Avatar
Is it running excessively rich??? If not then probably NOT the FPR. Pull the vacuum hose off the FPR, turn the IGN switch ON, does fuel come out of the FPR vacuum port during prime? If not, probably NOT the FPR.
I want you you look at a power connector. Some 2002 have had this trouble.
Just wondering when the first 2003 will have it..
Link>> http://tech.bareasschoppers.com/tech...d-main-wiring/
A few have had injector leads shorting to a cable clip (main harness clamp).
Any FI codes???
2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back. 180,596 miles of smiles
Hans&Feet is offline
post #4 of 8 (permalink) Old 09-11-2013, 09:43 AM Thread Starter
Thanks for the info. Guess I was expecting more of a fuel problem then electrical. The battery is definitely old, so I'm gonna start there.
Thanks
2003 Blk 1800C
duglaw is offline
post #5 of 8 (permalink) Old 09-23-2013, 11:14 AM Thread Starter
Well I got a new battery, air cleaner and plugs. Checked the electrical connection, but still no power.
Is it possible that the fuel filter or fuel injectors could be bad. Bout ready to take it in and have it looked at but really dont want to spend the money if its something simple to fix.
2003 Blk 1800C
duglaw is offline
post #6 of 8 (permalink) Old 09-23-2013, 11:27 AM
Philscbx's Avatar
May have to start pulling plug in's apart - inspecting for loose or over heated.
Wires to the ECM - very fragile zone of small wires -
Under the Tank - some have had wear through of wires -
INspect soft spots in small wires - where internally - the wire inside could be fractured.
Usually a couple inches out from ECM - the main computer with two large Plugs.
Smell the oil off the Dip Stick just to verify no excess fuel in the oil. - That's a FPR issue by default.
Was Scoot purchased New?
The Scoots 07 Neo III 03 18C ServMan Wiring Dia
Philscbx is offline
post #7 of 8 (permalink) Old 09-23-2013, 11:38 AM
baddawg Neo's Avatar
Loosing Power?
Mine had a weird power loss issue when I first bought it with 10 K miles on it.
Even though it is fuel injection (2004 1800N) it acted like a carb engine running out of gas.
I would get on it, or any situation that called for (almost) max power and it would just bog down, sometimes just die altogether. The problem was in the fuel return line from pump back to tank. It was pinched or folded over. This would put so much back pressure on pump that it couldn't work.
Does yours have an external pump? Can you follow the return line back to tank?
Hope this helps.
baddawg Neo is offline
post #8 of 8 (permalink) Old 09-23-2013, 10:27 PM
Hans&Feet's Avatar
Internal to the tank fuel pump, still has a return line from the FPR.
Check the fuel flow rate.
Download the service manual and start testing with a procedure to test and eliminate.
This is what he has done:
SM is about 53 MB
http://downloads.hondatech.info/Moto...By%20Mosue.pdf
