Setting preload on forks - VTXOA
post #1 of 4 (permalink) Old 07-13-2016, 04:46 PM Thread Starter
Fork seal
Getting ready to change fork seals,I will be using the manual and the you tube video with leaving inside of tubes together and just replace sliders,and seals,question is I never tried the pvc way of setting the seals,so my question is once the seals are ready to be pressed in do you use the bottom of the tube and slide it against the pic to set the seals?
neilc is offline
post #2 of 4 (permalink) Old 07-13-2016, 04:49 PM Thread Starter
12 years ago I installed Proggressive springs,seems like I remember you had to offset one leg with preload so when you set the front axle you had to push up on the I believe left fork leg
neilc is offline
post #3 of 4 (permalink) Old 07-13-2016, 04:51 PM
Here's everything on how to set the forks;
http://tech.bareasschoppers.com/susp...ment-vtx-1800/
Chicago-Spike is online now
post #4 of 4 (permalink) Old 07-13-2016, 05:33 PM Thread Starter
Hey old too see your still with the forum Chicago,I go back to 2003 when I first got the bike but have not needed any info for a while,but I got a lot of great info from you thanks
neilc is offline
