E.c.u - Page 2 - VTXOA
post #11 of 21 (permalink) Old 10-19-2016, 10:15 PM
I run about 3 front and 8-9 rear
I also run a/f of around 14.5 at cruise
post #12 of 21 (permalink) Old 10-19-2016, 10:21 PM Thread Starter
schnitz's Avatar
Ecu
Thanks for the great info.. Much appreciated!
schnitz is offline
post #13 of 21 (permalink) Old 10-19-2016, 10:38 PM
With the set up i have i can tune to what i want any time.
Have a windows tablet with software for the pcv mounted to risers real time info on injectors duty what throttle position fuel added or removed and every gear a different map
post #14 of 21 (permalink) Old 10-20-2016, 08:17 AM Thread Starter
schnitz's Avatar
WOW!,,,thanks
schnitz is offline
post #15 of 21 (permalink) Old 10-20-2016, 02:24 PM
KenDawg's Avatar
so you run 3 advance in front and 8-9 advance timming in rear? it's been a while since I looked at the powercommnder app, but do you have to set that for each RMP/throttle range like the add/remove fuel? or is it just a general setting you put in?
I haven't had mine tuned yet... just using a close to mine map, but it had no timming settings.... I plan to get it tune after I replace the stock clutch since I know it would slip when they tune it... I had it do it a couple times... but anyway, think if I did your timming settings I would benefit?
KenDawg is offline
post #16 of 21 (permalink) Old 10-20-2016, 03:11 PM
Ignition on the pcv has the same adjustments as the fuel
Most tuners don't do the ignition
post #17 of 21 (permalink) Old 05-18-2017, 09:01 PM
With all of that being said: I have a 2003 1800R that I'm taking in to get put on the dyno next weekend. I had it done some 10 years ago or so when I installed my PCIII. The last time they did it, they referred to it as a "general smoothing". Well it's time to get it done again due to some changes. Is there anything specific that I need to ask to get done? I need it smooth for long trips when the wife is on the back, but would like some more "performance" out of it too. Any suggestions? Thanks.
2003 VTX1800R
Ken1800R is offline
post #18 of 21 (permalink) Old 05-19-2017, 01:08 AM
Originally Posted by Ken1800R View Post
With all of that being said: I have a 2003 1800R that I'm taking in to get put on the dyno next weekend. I had it done some 10 years ago or so when I installed my PCIII. The last time they did. it, they referred to it as a "general smoothing". Well it's time to get it done again due to some changes. Is there anything specific that I need to ask to get done? I need it smooth for long trips when the wife is on the back, but would like some more "performance" out of it too. Any suggestions? Thanks.
For what you want you need the PCV a switch and 2 maps.
You should also have throttle body sync too.
Have you ever changed the fpr if not it is also time.
post #19 of 21 (permalink) Old 05-19-2017, 01:38 AM
Not looking to get into all of that, just looking for a happy medium. So I should just tell him a general smoothing then? Throttle body sync? Not familiar with that.
Ken1800R is offline
post #20 of 21 (permalink) Old 05-19-2017, 01:39 AM
No, I have not changed the FPR but sounds like a good time to do it. Thanks.
Ken1800R is offline
