E.c.u - VTXOA
post #1 of 21 (permalink) Old 10-18-2016, 09:59 PM Thread Starter
schnitz's Avatar
E.c.u
Is it worth to have the ecu re flashed on a 1800 X or hogwash?
schnitz is offline
post #2 of 21 (permalink) Old 10-18-2016, 11:32 PM
My tuner says can't be done
He does a lot of other makes though.
post #3 of 21 (permalink) Old 10-19-2016, 08:13 AM
You can't flash a Honda ECU. You buy a Powercommander or some other fuel manager to remap the fuel curves
post #4 of 21 (permalink) Old 10-19-2016, 08:21 AM Thread Starter
schnitz's Avatar
Thanks, but what about timing curves, I have a pc3?
schnitz is offline
post #5 of 21 (permalink) Old 10-19-2016, 09:51 AM
The Power Commander III USB Accessories
Power Commander III USB Ignition Module
The Ignition Module is connected to the PCIII USB with it’s built in expansion port link and communicates via a CAN interface. As in the case of the Power Commander, the Ignition Module uses OEM style connectors to plug in-line of the stock ignition harness so no cutting or splicing is required.
The Ignition Module uses “direct coil driver technology” and allows a high degree of timing adjustment. In the Power commander Control Center Software the user is able to advance or retard the ignition curve up to 10 degrees based on throttle position and RPM. It is also possible to alter the timing for each cylinder individually if necessary.
rangers4u and Randman like this.
post #6 of 21 (permalink) Old 10-19-2016, 05:51 PM Thread Starter
schnitz's Avatar
Ecu
Thanks for the info.. I did not know about this
schnitz is offline
post #7 of 21 (permalink) Old 10-19-2016, 08:37 PM
Power commander V with ignition is what i use.
post #8 of 21 (permalink) Old 10-19-2016, 09:33 PM Thread Starter
schnitz's Avatar
Ecu
Nice numbers. Never had mine dynoed. 06 1800c 63,000. Is there much to be gained by increasing the timing on these?
schnitz is offline
post #9 of 21 (permalink) Old 10-19-2016, 09:54 PM
Smoother since Honda programmed in about 15 degrees off on rear cylinder to give it the vib affect.
post #10 of 21 (permalink) Old 10-19-2016, 10:07 PM Thread Starter
schnitz's Avatar
So would you just add timing to the rear or more to rear and some to front?
schnitz is offline
