Difficulty Keeping Steady Speed In 1st gear - Page 3 - VTXOA
 6Likes
post #21 of 24 (permalink) Old 10-25-2016, 10:17 PM
Travis311's Avatar
Everything works fine on the bike, maybe it's not worth the investment since most say this is normal.
I think you're spending too much time in 1st and 2nd. If it is running fine in the others gears, don't worry about it.
Travis311 is offline
post #22 of 24 (permalink) Old 10-25-2016, 10:29 PM Thread Starter
Abandoned's Avatar
Cool. Thanks guys. I don't spend a lot of time in first and second, but when I have too it can be a little jumpy/jolty. And since gathering info on this bike I've decided to and been getting out of first as fast as possible without "lugging it" and it has helped. This issue is much less significant or a problem in second. I will get the ground fix done though for sure.
Thanks for all the help guys.
Abandoned is offline
post #23 of 24 (permalink) Old 10-25-2016, 10:53 PM
chkmte77's Avatar
I agree with pushrod.
maintenance is vital, but if its not broke don't fix it. the unsweet spot is common on most engines....motorcycles, boats, cars.(some are more pronounced than others) For example, I cant stand that my overdrive kicks in at 40 m.p.h. in my truck and the engine drops r.p.m. and it starts lugging until it downshifts....its a common problem that the manufacturers do to get the fuel mileage right for the e.p.a. Drivability for the customer isn't really an important factor, but government approval is. So, in my truck I manually shift out of overdrive until I hit at least 50 m.p.h. or keep my foot into the gas until then.
Some, maybe many will disagree with this statement. An engine will only run in its "perfect form." When it is at its peak of its powerband.....any other time it will be either lean or rich. (Remember your first 2 stroke dirtbike gentlemen?) The EFI systems have cleaned up this problem a lot but it has not perfected it.....yet. It is possible that if you try and resolve this low speed surge it may cause issues somewhere else in the r.p.m. range/curve. you could actually lose h.p. in the mid to upper range by "cleaning up" the low end...of course this is just my opinion. Me personally, I'm a Torque junky, a zero to 60 guy. I'm more concerned about the full throttle mid range torque area than I am with my 1st. gear surging. But if you feel you must chase it down happy hunting to ya!
chkmte77 is offline
post #24 of 24 (permalink) Old 10-26-2016, 09:51 AM
SeaSteve's Avatar
I'm adding my 2 cents to the echo chamber here...here...here...here...here. lol
Follow Bareasschoppers directions to do the Ground Fix and the PAIR system removal. It's all very easy to follow.
Meatloaf~Bat Out Of Hell
SeaSteve is offline
