Need an ECM - VTXOA
post #1 of 10 (permalink) Old 11-12-2016, 07:16 PM Thread Starter
Need an ECM
I have a 2002 VTX1800C It had been running real rich even for an 02. I had an error code for the MAP sensor. I checked the voltages and they were good so I replaced the module. Still get the code. The manual said the last potential problem was the ECM. I cleared the codes and ran it a few minutes. Now when I check codes again I get a solid red light. Looks like it is the ECM. The one in it is a 38770-MCH-671 which I understand has been replaced with 38770-MCH-772. Perhaps the replacement doesn't run quite as rich as the origional 02's. The dealer wants $1,000 and can't be sure that it is actually the problem and if it doesn't fix it the part is still mine. On line I see them new for $609. That is too much money to part with not being sure it will fix it. On Ebay I see Honda ECMs from $80 to a couple hundred used but none are listed right now with the right numbers for my bike. I'll keep looking there but I thought I would ask if anyone here had one they wanted to part with.
BrunoK is offline
post #2 of 10 (permalink) Old 11-12-2016, 08:09 PM
You need to check +12v Bl/w wire at Engine stop relay... Y/R wire +5volts for the sensors..
Read link below..... Bare also has more info on trouble codes.
http://tech.bareasschoppers.com/tech...d-main-wiring/
Affects 2002...
http://rs1185.pbsrc.com/albums/z350/...h=480&fit=clip
2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back. 179,444 miles of smiles
post #3 of 10 (permalink) Old 11-12-2016, 09:04 PM
Find someone local and swap for a ride to see if problem is still there.
post #4 of 10 (permalink) Old 11-13-2016, 08:20 AM
Pull your ECM out and send it to someone on the forum to test on their bike?
You're (probably) going to pull yours out of the bike anyway.
If it gets lost in shipping it was probably broken anyway.
If there's something about your bike that breaks ECM's (inconceivable) the other guy didn't run that risk.
TurnOne2000 is offline
post #5 of 10 (permalink) Old 11-13-2016, 08:40 AM
have you Ohm'ed out the wires.. ??? the 1300 has major issues with ecm wires going to ECM. the 1800 wires are not much stronger.
wire breaks inside insulation.. and insulation does not break.. so looks OK. till ohm'ed.
try to find someone local to swap ECM. my bet is wires. as ecm failures are rare.
chuck_VTX F is online now
post #6 of 10 (permalink) Old 11-14-2016, 10:03 AM Thread Starter
Thanks for the input. The voltage is within spec for all three wires to the MAP sensor so I don't think it is a wiring issue. Finding someone to swap with for a test would be ideal, but I don't know anyone else here in Houston with an 2002 1800c to try my ECM.
BrunoK is offline
post #7 of 10 (permalink) Old 11-14-2016, 10:08 PM
Do you get fuel pump prime???
What voltages do you get for the MAP sensor wires???
post #8 of 10 (permalink) Old 11-17-2016, 12:21 AM Thread Starter
The voltages are in the high but acceptable range according to the manual. I don't remember exactly but it was around 5.25v. The pump is fine. The bike runs but not real well, it seems to be running from the default mixture tables rather from the computer. I cleaned the plugs and they carbon up after just a few miles.
BrunoK is offline
post #9 of 10 (permalink) Old 11-17-2016, 02:09 AM
I suggest changing out the fuel pressure regulator and related vacuum hose if for nothing else than to tick it off the list as possible causes of running a rich mixture.
Sojourner is offline
post #10 of 10 (permalink) Old 11-17-2016, 09:55 AM
TPS, Baro and Map sensors get +5v Y/R and Ground is Green/Orange.
Green/Orange is a sensor ground only for IAT, ECT plus the above three sensors.
Test the +5v to the sensor ground(G/O). Verify continuity back to the ECM connector.
ECM has three Grounds to the "Common Electronics" ground bolt on the front Ignition coil.
One Green wire and two Green/Pink wires--verify continuity from Ground bolt to the ECM terminals.
Engine running in "Failsafe" mode = limp home mode...
Many early 1800 have had FPR fail. 1800 runs extremely rich when FPR fails.
Lack of vacuum to FPR looks like WOT so fuel line pressure is high = richer mixture.
