No power problem - VTXOA
post #1 of 5 (permalink) Old 11-14-2016, 02:09 PM Thread Starter
No power problem
Originally Posted by Hans&Feet View Post
Thanks for the kind words Chuck! I am glad you found the problem!
Everyone on a 2002-2003 VTX 1800 should look at their 2Pconnector and relay connector.
Many run cycles, electrical connector oxidation with high current = failure. The intermittent nature makes it a PIA. Dangerous also.
Just unplugging it and reconnecting it makes a better electrical connection(scrapes off oxidation).A little bit of N0-Oxide or silicone grease may help but once the tension on the wire terminations is gone---high resistance/open.
Hey, I just came upon this reply from you and I have a 2002 1800C....which 2P connector and relay connector are you specifically talking about??? I read the rest of the posts and didnt really see which ones I need to look at. I would really appreciate this info cause my vtx died and has no power going anywhere. Ill check the 30amp main fuse tonight, but all otehr fuses are OK. My email is rob8213@yahoo.com cause I dont think i am a member here yet. Im a member on VTX cafe.com . Thanks!
rob8213 is offline
post #2 of 5 (permalink) Old 11-14-2016, 03:12 PM Thread Starter
I see that location of the 2P connector on the left side from your pic, but is that the 30amp main fuse location that I see just to right in that same pic? I have similar issues and need to get home and look at the left side fuses. I only checked all the main fuses on the right side fuse box with the 5 fuses.
rob8213 is offline
post #3 of 5 (permalink) Old 11-14-2016, 03:21 PM
I moved your posts to the 1800 Tech board where you will get more help than in a 5 year old thread.
post #4 of 5 (permalink) Old 11-14-2016, 09:04 PM
You are correct--it is the 30 amp fuses from the Battery + to the harness via the 2P connector.
Near the Starter Relay.. Bare has more info on the link. You do not need a connector. Direct wire/solder,etc.
http://tech.bareasschoppers.com/tech...d-main-wiring/
File Type: jpg 1800 Left cover 30A fuses starter relay.jpg (310.8 KB, 6 views)
post #5 of 5 (permalink) Old 11-15-2016, 06:44 AM
Welcome to the VTXOA forum from Daytona Beach, Ride safely.
