pair mod w/VH - VTXOA
 9Likes
post #1 of 11 (permalink) Old 02-11-2017, 10:43 AM Thread Starter
chkmte77's Avatar
pair mod w/VH
So in the midst of my leaky radiator repair, being The tank was already removed I decided to pull the pair solenoid off and cap the covers. I bought some rubber caps off the help rack put them on. I finally got the Radiator, lindby bars, radiator cover fuel tank etc. back on. went for a ride no leaks, but wow the backfires!!!!...sounds like fourth of july....(my pipes are not loose or leaking) I have a dual cone K&N intake setup with Vance and Hines slash cuts.......With the pair installed it had a low rumble with very minimal decal pops, with it removed its just plain embarrassing and annoying......looks like ill be pulling the tank......again......and reinstalling the pair.....blah.....
VTX1800FGMCZ71 likes this.
chkmte77 is offline
post #2 of 11 (permalink) Old 02-11-2017, 02:11 PM
fastspek's Avatar
It is difficult to understand why desmog would cause backfire. Imo you should look for an air leak. Are those rubber caps that you put on really tight? You normally should use rubber plugs(or block off plates)
Chicago-Spike, Harkon and nate6966 like this.
brothers in arms:
2003 VTX 1800C (forever)
2002 HD FLSTF since 07/2008
fastspek is offline
post #3 of 11 (permalink) Old 02-11-2017, 04:43 PM Thread Starter
chkmte77's Avatar
very tight.....no leaks I'm actually glad I didn't spend money on the block off plates ...I read a ton of threads here about the desmog and all the exhaust notes it does/doesn't cause.....im just going to put it back on, no big deal, you cant see all that junk under the tank anyway....I only removed it because of the threads I read and figured it would clean up the area.
Ill try and get some pics once I pull the tank.......I need to run it down on fuel first..
chkmte77 is offline
post #4 of 11 (permalink) Old 02-11-2017, 07:41 PM
There really isn't any way for blocking off the pair valves to increase decel pop. If you think about it, decel pop is unburned fuel igniting in the exhaust. This requires 3 things in order to happen. You need fuel. That happens because you have a closed throttle and very little air coming in through the throttle body. The charge is rich and with the lack of air unburned fuel is a byproduct of this. You need heat. This is obvious, the exhaust pipe is generally hot enough to ignite a burnable air fuel mix. Then you need air / oxygen. Where is this going to come from. With the pair functioning the valve lets in air specifically to burn off any unburned hydrocarbons. Block that off properly and no air from there. Leaky exhaust gaskets result in a lot of decel pop because in a decel condition air will actually get sucked in there, decel pop is a byproduct if that. Ultimately if you take away the air, no decel pop, or very little anyway. There certainly should not be more decel pop with the pair blocked off. No way should that be possible. It just doesn't figure.
You, my friend, have a leak somewhere.
rangers4u and nate6966 like this.
post #5 of 11 (permalink) Old 02-11-2017, 07:50 PM
Decel popping is the result of unburned gas leaving the combustion chamber, mixing with oxygen and igniting brought on by the heat of the exhaust. To ignite, the fuel/air ratio has to be just right or it won't happen. Straight pipes with little or no baffles allow oxygen to get sucked into the pipes on each return pulse of the exhaust. This oxygen will then mix with the unburned gas and the result is decel popping. I'm guessing that when your PAIR system was in place the oxygen it passed into the exhaust port, mixing with the oxygen coming up the pipes, created a fuel/air ratio that was too lean to fire off. You'll soon find out when you reinstall your PAIR system.
Sojourner is offline
post #6 of 11 (permalink) Old 02-12-2017, 12:40 AM
I have never heard of anyone getting more decel popping from doing the desmog/PAIR removal.
I know you believe you have no air leaks, but there are multiple points where air could be getting in.
If the exhaust headers were moved or adjusted, the exhaust crush gaskets have to be replaced.
'07 VTX 1800F spec 3
post #7 of 11 (permalink) Old 02-12-2017, 01:18 AM
News to me too Nate. Just thinking outside of the box.
post #8 of 11 (permalink) Old 02-12-2017, 06:42 PM
I suppose that's possible but I doubt you get air back far enough where there is enough heat to ignite the mix. Again anything is possible but this scenario would be a long shot IMHO. Far more likely air is incoming upstream.
post #9 of 11 (permalink) Old 02-13-2017, 12:51 PM
Did your caps have the cut out (dimple) for the screw? If not, it didn't seal.
NCGus is offline
post #10 of 11 (permalink) Old 03-12-2017, 08:42 PM Thread Starter
chkmte77's Avatar
pair mod decel backfife 4th july blackcats.
A few weeks ago I pulled the the air valve off, and put tight rubber vacuum caps over the stock plates.....ran the bike and on decel it sounded like the 4th of july behind me....I finally got around to pulling the tank and reinstalling the air valve......all back to normal...I never had any exhaust leaks so why all the noise from removing the kit? I was just trying to clean up the spaghetti under the hood but I guess Honda had a reason for it.....no harm no foul
chkmte77 is offline
