Mixing Fork Oil - VTXOA
 7Likes
post #1 of 14 (permalink) Old 02-12-2017, 08:44 AM Thread Starter
Randman's Avatar
Mixing Fork Oil
I replaced my front fork seals. When I did this I used DelRay 10 weight fork oil. I cleaned all the old fluid out and added the recommend amount. It seemed a bit thicker than the stock oil. My front suspension is now a bit stiffer than I would like it.
I was thinking of using a vacuum pump and a hose to remove some of this oil measuring the removed amount and adding the same amount of a thinner oil to soften it up a bit.
My question is: Is it ok to add thinner oil without removing all of the existing oil. Is it ok if they are mixed. Will they mix or stay separated?
Also wondering if different brands would be incompatible?
Randman is offline
post #2 of 14 (permalink) Old 02-13-2017, 12:12 PM
In theory, if you mixed a 10 and a 5 50/50, you'd have a 7.5. Stick with Bel-Ray.
Randman likes this.
Jimbo is offline
post #3 of 14 (permalink) Old 02-13-2017, 01:04 PM
do not mix brands or types... but OK to mix.
and you did use correct weight..
but time and miles you put on bike will lower the weight of oil... plus made it dirty, also lowering thickness.
Randman likes this.
chuck_VTX F is online now
post #4 of 14 (permalink) Old 02-13-2017, 03:28 PM
The Hondas shipped with 5W in them, AFAIK. Larger folks, like myself preferred 10W to lighter weights. The primary thing to remember is that 10W BelRay is not the same as 10W Maxima which is not the same as Lucas (necessarily). Some manufacturers may have really close formulations, but the variance in fork and suspension fluids is astounding. Generally speaking, as mentioned, I can confirm same brand and type (series) of oils generally mix fine to make an intermediate viscosity.
post #5 of 14 (permalink) Old 02-13-2017, 09:04 PM Thread Starter
Randman's Avatar
I weigh around 250 so I thought the 10W would be ok. It's just a bit too stiff. Maybe I'll take half of it out and replace it with 5W of the same brand. I did see a chart on the forum that backs up what you're saying about different brands of fork oil having a variance in viscosity ratings. I think BelRay was one of the thicker ones.
Thanks Man!
Randman is offline
post #6 of 14 (permalink) Old 02-13-2017, 09:12 PM
I am old school and use ATF
115000 miles on the 1300 with just flushing every year or so and bushings & seals are factory stock.
Charlie D is online now
post #7 of 14 (permalink) Old 02-13-2017, 09:26 PM Thread Starter
Randman's Avatar
That's a lot of miles for stock seals! Apparently the fork seals like ATF.
The seals on my bike where shot when I bought it. I never tried using ATF in forks.
Randman is offline
post #8 of 14 (permalink) Old 02-13-2017, 10:20 PM
There's nothing wrong with ATF other than it will foam more than fork oil. That said, it's not like we ride like I ride my CRF450X. ATF does have seal softeners in it to keep seals pliable. Might be its good for fork seals. If it works, good on ya. Thanks for sharing that.
rangers4u and Randman like this.
post #9 of 14 (permalink) Old 02-13-2017, 10:28 PM
Look at repair manuals from the 60s
They call for ATF and 30wt oil mix to get the action you wanted.
Fork oil is a market scheme.
ATF is anti foaming
Randman likes this.
post #10 of 14 (permalink) Old 02-14-2017, 07:12 AM Thread Starter
Randman's Avatar
ATF is anti foaming
The Bel-Ray fork oil was around $12.00 and I had to buy 3 bottles if I remember correctly. You can buy generic ATF for $3.50. So yeah, that is saving a bit of cash. Especially if you are flushing it regularly. Apparently it is ok to mix with oil. I may just try this myself.
Randman is offline
