2002 VTX 1800 C - Not Starting - VTXOA
post #1 of 2 (permalink) Old 02-12-2017, 11:13 AM Thread Starter
Good Morning, I have a 2002 VTX 1800 that will not start. I went to go take it out the other day on an unusually warm New England winter day and the battery we weak and would not turn the bike over. I hooked up my battery charger/starter as I have done in the past and set it to the Start function. When I went to turn the bike over something strange happened. The bike began to turn over, and when I let go of the start button it continued to crank I then turned the handlebar switch off and it continued to crank. Then I turned the key off and it still cranked, slower and slower. I quickly disconnected the charger leads and everything stopped. Now, nothing works. I turn the key, flip the handlebar switch and the fuel pump doesn't prime, no lights come on, nothing happens. I checked the two 30 amp fuses and they both seem good.
I am unsure where to look next. Could it be the key switch, the starter solenoid, I am just really unsure where to look. Any help would be greatly appreciated.
pnshr.vtx1800 is offline
post #2 of 2 (permalink) Old 02-12-2017, 11:24 AM
The battery is dead. Buy a new one, charge it full then hook it up. If the starter starts up as soon as you connect the charged battery, tap the starter solenoid to see if that unsticks the starter solenoid. If it doesn't, unhook battery and replace the starter solenoid.
Reason why the solenoid stuck open was from a very low dead battery. Once it stuck open, it may have killed the solenoid.
Tags
electrical issues , not starting , vtx 1800
