Yausa Battery - VTXOA
 7Likes
post #1 of 11 (permalink) Old 02-16-2017, 01:52 PM Thread Starter
Yausa Battery
Have a new Yausa battery being delivered today. Have an 03 1800C. Will this battery require charging before use? I have left them a vm, used tech portal, an read all on there site. No reply to any?? I got the one with 310 CCA.. Bike has been down since last Sunday. Horrible customer service, as that's my business also..
post #2 of 11 (permalink) Old 02-16-2017, 02:23 PM
fastspek's Avatar
https://www.thumpertalk.com/forums/t...ge-first-time/
Curt E likes this.
brothers in arms:
2003 VTX 1800C (forever)
2002 HD FLSTF since 07/2008
fastspek is offline
post #3 of 11 (permalink) Old 02-16-2017, 02:29 PM Thread Starter
Thanks Fast. This is a maintenance free battery..
post #4 of 11 (permalink) Old 02-16-2017, 02:44 PM
Dartanuan's Avatar
Maintenance free usually means you don't take off the caps to add water. If it were me, I'd still put it on the trickle charger overnight before I installed it. But that's just MY opinion....
rangers4u and Curt E like this.
2007 1800T, Memphis Shades 21" Windshield, Kury Engine Bars & Foot Pegs, HondaLine Light Bar, Mean City Cycles Seat, Cobra Slash-Cut Pipes, HondaLine Saddlebags, Iron Horse Tail Bag, Show Chrome Front Fender Rail, Color-Matched Radiator Housing, Kury Iso-Grips, Custom Breather Cover. GO TEAM DREW!!!
Dartanuan is offline
post #5 of 11 (permalink) Old 02-16-2017, 02:46 PM Thread Starter
Thanks Dart. Think I will. Don't want to mess up a very expensive battery an I'm not even certain that's my problem..
post #6 of 11 (permalink) Old 02-16-2017, 02:54 PM
I just bought a new Yuasa AGM from Summit Racing. Two sets of instructions from Yuasa..
It is dry, so I added the acid, let it soak for a few hours, sealed the cell then put a low charge rate on it.
I had 0.4 amps charge current about 30 minutes after charging began.
After 12 hours I removed the charger, left the house for a few days.
When I returned I put the charger back on for another 12 hours.
My charger has the output voltage set to 14.3 volts. with a maximum current of 1.5 amps.
If you get a pre-filled battery put it on a low charge rate.
6 hours at 1 amp is better than 6 amps at 1 hour>> less heat and gas produced.
If you have an unregulated battery charger, put a voltmeter on the battery, keep it below 14.5 volts.
http://www.yuasabatteries.com/faqs.php?action=1&id=30
Curt E likes this.
2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back. 178,645 miles of smiles
post #7 of 11 (permalink) Old 02-16-2017, 04:13 PM
Travis311's Avatar
I took mine to Advanced Auto and the guy checked it and meter said was dead and bought one there for $88. It was agm... forgot the brand.
Took it home, superglued the bolt terminals before screwing them in, and fired it up.
It's doing great so far.
Curt E likes this.
Travis311 is offline
post #8 of 11 (permalink) Old 02-16-2017, 05:20 PM Thread Starter
Plan to charge/install after work. Will give update ASAP..
post #9 of 11 (permalink) Old 02-16-2017, 05:35 PM
Mmusicman's Avatar
Every AGM battery I've ever purchased required filling the cells with acid, then a slow charge. Most likely it will come with instructions.
Curt E likes this.
Mmusicman is offline
post #10 of 11 (permalink) Old 02-17-2017, 12:13 PM Thread Starter
Battery
Bad battery was issue. Bike running fine with new Yuasa AGM battery. The Interstate battery was only 2 yo an on a tender when not used.. Apparently a cell died as bike had 0 power after riding then getting gas an poof, nothing.
I have no accessories to draw on system..
Appears to be a nice weekend, so i'm riding!
Appreciate everyone's help, an assistance.
