Engine rattle? - VTXOA
  • 1 Post By Chicago-Spike
post #1 of 9 (permalink) Old 03-19-2017, 11:12 PM Thread Starter
Danielvtx1800f's Avatar
Engine rattle?
Good evening... I apologize in advance, I know there's many topics on noises and the like. So if there is an existing thread that matches my situation, please point me in the right direction.
After the engine is warm, I can her a fairly aggressive rattle under the tank above 3-3500rpm. I can't easily tell if it's tank, exhaust or internal engine related. The engine runs like a champ and everything feels/seems normal.
In case the signature doesn't show:
07 f
17k miles... I'm due for the second valve check/adjustment.
Desmog
V&H exhaust
Any ideas on what it might be or what I can check?
2007 VTX1800f 8100mi.
K&N Air Filter, Desmog
Danielvtx1800f is offline
post #2 of 9 (permalink) Old 03-20-2017, 08:58 AM
Put a glove on and start grabbing/pushing on every part you can until you find it. Start with the chrome dash panel on teh tank. Second most popular is the wires inside the headlight shell. See Bareasschoppers.com for that. Third, check the tank hold down bolt, I forgot to tighten mine once and it rattled. After these it could be anything, exhaust heat shields, spark plug covers, anything......................
post #3 of 9 (permalink) Old 03-20-2017, 12:07 PM
Valve rattle should be steady without skipping a beat, and change up & down with slightest RPM change...
Other rattles will be missing and skip a beat or miss a beat (normally).
Check as above It can drive ya nuts and is always the very last thing you check !! And get that Valve adjustment done...
frnkcat is online now
post #4 of 9 (permalink) Old 03-20-2017, 12:10 PM Thread Starter
I can do all of this within the hour... valves within the next month.
I should say that the racket starts clearly around the 3-3500 Rpm range, not getting louder.
I do hear the valve ticks separate.
post #5 of 9 (permalink) Old 03-20-2017, 02:40 PM Thread Starter
Sure enough is was the heat shield next to the rear jug. Now to secure/adjust it.
Thanks for the help!
post #6 of 9 (permalink) Old 03-20-2017, 02:44 PM
Do not tighten the heat shield clamp too much! Just snug it up to the pipe, if you tighten too much, when the pipe heats up the band clamp mount on the heat shield will snap off
Longeford likes this.
post #7 of 9 (permalink) Old 04-18-2017, 09:57 PM Thread Starter
So I'm back at it again... I've tried to adjust the heat shield every way I can, and after a few miles it seems to start rattling again.
At the rear cylinder, the shield is rattling against the exhaust nut, but only at medium to high rpm.
Has anyone encountered this specific thing before? My next thought is grinding it down... but I'd rather not.
post #8 of 9 (permalink) Old 04-19-2017, 09:49 AM
KenDawg's Avatar
If it's rattling againt the exhaust nut, get some needle nose pliers and try to bend the part that touching away a little...
KenDawg is offline
post #9 of 9 (permalink) Old 04-19-2017, 10:09 AM Thread Starter
I can try that this evening.
Thanks!
