Bike won't start - VTXOA
post #1 of 20 (permalink) Old 03-20-2017, 05:19 PM Thread Starter
Bike won't start
Morning group, went to start my 2003 1800c all lights come on and fuel pump sounds but bike just keeps cranking . Was running yesterday no issues. Battery is new plenty of juice, anybody have this issue? Where should I start looking ? Checked fuses all good.
Thanks Terry
T-bone22 is offline
post #2 of 20 (permalink) Old 03-20-2017, 05:27 PM
hawkvtx's Avatar
Start by tightening battery cables. If that doesn't work then it could be the starter relay going bad. When it's turning over is it turning over strong?
Livin' Blue in a Red state.
hawkvtx is offline
post #3 of 20 (permalink) Old 03-20-2017, 05:42 PM Thread Starter
Yes cranking strong, it did start once then I shut it off and she will just crank. Everything seems to be working fine. Just doesn't seem to be getting fuel or spark.
T-bone22 is offline
post #4 of 20 (permalink) Old 03-20-2017, 05:50 PM
Did the fuel pump prime you will hear when key is first turned on after sitting for awhile.
Charlie D is online now
post #5 of 20 (permalink) Old 03-20-2017, 06:20 PM Thread Starter
Yes it did prime, after turning the key on, everything turned on as always but just wont start
T-bone22 is offline
post #6 of 20 (permalink) Old 03-20-2017, 06:38 PM
fastspek's Avatar
Ground fix done? Any fuel manager on board? Enough gas? Bad gas?
brothers in arms:
2003 VTX 1800C (forever)
2002 HD FLSTF since 07/2008
fastspek is offline
post #7 of 20 (permalink) Old 03-20-2017, 10:31 PM
Larry_J's Avatar
That's what first came to my mind as well. I know my 1300 doesn't have a fuel gauge, so I imagine the 1800 also does not, so maybe you just ran low. I've tried my fair share of times trying to start a bike or 4-wheeler when low on fuel.
Then again you typically run out of fuel while you're out and about, not first start up in the morning. You never know though. If you can't see fuel when the cap is pulled, I'd dump a gallon of gas in there and give it another try before digging deeper in troubleshooting.
2005 VTX 1300C.................................................. ...2006 Kawi ZZR600 street fighter
Larry_J is offline
post #8 of 20 (permalink) Old 03-20-2017, 10:49 PM
N2theX's Avatar
Pull the vacuum line off of the fuel pressure regulator. Turn the key on and see if fuel comes out of the regulator where the vacuum line was plugged into. If good then on the fron cylinder there is a cam position sensor on the front side, check the connection.
2003 Red Custom
2013 HD Road Glide Ultra
God Bless America!!!!
Support our Troops!!!
Air CAV
N2theX is offline
post #9 of 20 (permalink) Old 03-21-2017, 06:01 AM Thread Starter
Just filled up Friday fresh gas bike is all stock no management system, haven't done the ground fix. Ok never had to work on bike much ..it's a Honda , on the front where is the regulator located? Does the tank need to be removed? And where is the cam sensor? Not new to working on things just haven't needed to fix anything on the 1800.
T-bone22 is offline
post #10 of 20 (permalink) Old 03-21-2017, 06:03 AM Thread Starter
Fresh fill up on Friday, will suck if the tank has to come off.
T-bone22 is offline
