Accessory Lighting Circut - VTXOA
post #1 of 12 (permalink) Old 05-07-2017, 09:20 AM Thread Starter
Randman's Avatar
I bought some LED fog/running lights. I see an accessory plug in the light bucket. Any body know what fuse that goes to?
These are low wattage led bulbs. They don't draw much current. I'd rather not run a new wire from battery if I don't have to. Will I blow a fuse if I connect these lights to the accessory plug?
I don't want to find out the hard way on a dark winding road.
Randman is offline
post #2 of 12 (permalink) Old 05-07-2017, 12:40 PM Thread Starter
Randman's Avatar
In the service manual wiring diagram it doesn't even show the accessory plug. Must go to headlight circuit? Has anyone tried connecting lighting to this?
Randman is offline
post #3 of 12 (permalink) Old 05-07-2017, 03:00 PM
That is driving light plug, i think stock light bar has 25 watt lights
Randman likes this.
Charlie D is online now
post #4 of 12 (permalink) Old 05-07-2017, 03:01 PM Thread Starter
Randman's Avatar
Ok, I have determined the accessory plug goes to headlight circuit. One lead is on low beam the the other is high beam. I went ahead and wired the fog lights to this. Later before I do a night time ride I will check amp draw on the head light circuit. I'm guessing it was meant for auxiliary lighting so a couple of LEDs should be ok. Hopefully
Randman is offline
post #5 of 12 (permalink) Old 05-07-2017, 03:02 PM Thread Starter
Randman's Avatar
Oh, good! Thank you very much Charlie!
Randman is offline
post #6 of 12 (permalink) Old 05-07-2017, 03:04 PM Thread Starter
Randman's Avatar
Strange it doesn't show on wiring diagram. Maybe it does and I'm just blind.
Randman is offline
post #7 of 12 (permalink) Old 05-07-2017, 03:16 PM
Only has power on low beam if i remember correctly.
post #8 of 12 (permalink) Old 05-07-2017, 03:31 PM Thread Starter
Randman's Avatar
This one has two leads one for high one for low. I just put it on the low beam lead.
Randman is offline
post #9 of 12 (permalink) Old 05-07-2017, 08:30 PM
Black/Brown wire is Fuse B.
Blue wire is High Beam
Green wire is Ground
Part of the 02-03 1800 VTX R/S schematic
Randman likes this.
post #10 of 12 (permalink) Old 05-08-2017, 11:46 PM Thread Starter
Randman's Avatar
I have a different manual than you apparently. I just double checked mine. it shows nothing in that location on my wiring diagram. Thank you Hans!
Randman is offline
