Custom Tach Adapter Wiring Query - VTXOA
post #1 of 11 (permalink) Old 05-17-2017, 11:00 AM Thread Starter
Hello
End of last season i bought a Baron tach adaptor that I installed last week. It fails out of the box. My late googling seems to show that that is a typical thing, So I thought about making my own. Attached is the wiring diagram that consistantly shows up. However, my issue is that it shows everything in parallel. If there is the diode in there to regulate current flow direction, doesn't the parallel configuration effectively bypass the diode thru the resistor? I feel it should be coilwire->diode->resistor->tach wire for both sides.
I am asking for feedback before I try the series configuration so I do not risk my computer !
thanks
Mastertechie is offline
post #2 of 11 (permalink) Old 05-17-2017, 12:38 PM
Those are 100K ohm resistors. You won't get much signal to the tach with those resistors in series. My guess is that the resistors are likely not needed 100% of the time, but depending on the driving circuit, it does put the tach at the coil potential. IOW, it doesn't hurt having them in there and will allow the tach to see a logical high (if it needs it).
post #3 of 11 (permalink) Old 05-18-2017, 06:15 AM
The diodes are blocking the +12v and peak voltage.
I suspect the tach puts out +5 or +12 volts with a pull up resistor and the diode is forward biased when the coil is grounded.
The resistor may be used to discharge the circuit or is the pull up resistor.
My 2
post #4 of 11 (permalink) Old 05-22-2017, 02:53 PM Thread Starter
well I tried it and did not get the results I wanted. It seemed to show double the idle rpm and when revved up it lagged and then would not get up there or drop to 2000 and sit there. Also had alot of needle bounce.
Oh well. thanx for the insights and I did not fry anything,
post #5 of 11 (permalink) Old 05-22-2017, 05:34 PM
It has been a long time since this came up.
If the tach is made to connect direct to the Ign coil, then reverse the diodes and the high voltage
spike should go to the tach. The down side would be the +12v from each coil would be gated to the tach also
for a long duration. Put the resistors in series with the diodes and try that.
post #6 of 11 (permalink) Old 05-23-2017, 11:39 AM
At this point I think it would be very helpful to see what the tach manufacturer woudl like to see for a hookup and what bike this is actually for. Then it would be easier to come up with an "adaptor". Without that, it's all just a guess.
post #7 of 11 (permalink) Old 05-23-2017, 05:01 PM Thread Starter
sadly there are no manufacture marks on this
post #8 of 11 (permalink) Old 05-23-2017, 07:48 PM
I don't know if this will help you or not. I bought a Rivco setup, with a VDO brand tach, some time ago. I suspected when I bought it, it was for a 1300, not an 1800. After making several calls, I was lucky to get the little black box adapter for the 1800. Until last Tuesday, I had no wiring instructions, but now I do, and thanks to Chuck_VTX_F I now have a working tach. If you would like a copy of the Rivco instructions, PM me with your email, and I will forward them. You're welcome.
post #9 of 11 (permalink) Old 05-25-2017, 09:32 AM Thread Starter
PM sent. Thank you
post #10 of 11 (permalink) Old 05-28-2017, 05:43 PM
You're better off buying a tach adapter off Fleabay that uses the dip switches which allow for just about any combination of motor/tachometer. The one I bought was about $50 and has a signal doubler so it's only hooked to one coil.
I bought one last year as I was doing the homemade tach adapter route and eventually burnt up my first Baron after about 6 months. Too much needle jumping eventually sent it to the grave I guess. New one has been pretty much flawless.
Sent from my VS986 using Tapatalk
BigTex03 is offline
