VTX 1800C Red Line RPM (HELP) - VTXOA
post #1 of 4 (permalink) Old 07-04-2005, 12:42 PM Thread Starter
I just installed a tachometer for my 2004 VTX 1800C but cannot find the red line RPM anywhere. It is not even in the manual.
I am looking for max RPM, peak power RPM if anyone knows I would appreciate it.
Thanks
Hard Krome 3" Dual Sideburners
Kuryakyn Pro Hypercharger
Kuryakyn grips, Highway Bars, Retro Pegs
Custom Mirrors (Maltese Cross w/ flames)
vtxbloom is offline
post #2 of 4 (permalink) Old 07-04-2005, 12:50 PM
as the rocketeer says, If you have a good reaction time (0.5sec) then set the shift light at 5450. this gives you the begining of the torque curve in the next gear.
hope this helps
04 1800c
________________________________
don't force it ,it should slip right in
Mr.Obvious is offline
post #3 of 4 (permalink) Old 07-04-2005, 01:01 PM
redline
From other posts, 5750 is where the rev limiter is set.
'04 Neo, Magenta, Spec II, Memphis Shades Fats 21", lowers, Hopnel windshield bag, Honda low Neo backrest, Neo luggage Rack, Hondaline Saddlebags, Kury Iso grips, throttle boss, switch covers, Kewlmetal helmet locks, Brown County Custom airbox cover, K&N filter, PC III USB, V&H Bigshots, Rivco drive shaft cover, frame covers, swingarm cover, highway pegs, passenger floorboards w/extensions.
topduck is offline
post #4 of 4 (permalink) Old 07-04-2005, 03:59 PM
tin-indian's Avatar
I might have this backwards of wrong all together.but I think the fuel shuts off at 5750 then the ignition cuts out at 6000.
[SIGPIC][/SIGPIC]'02 VTX1800C
tin-indian is offline
