FRONT FORKS 2003 VTX C - VTXOA
post #1 of 5 (permalink) Old 04-08-2006, 12:12 PM Thread Starter
WAS WONDERING IF ANY BODY HAVING TROUBLE WITH FRONT FORKS, ME AND A FREIND OF MINE HAVE 2003 VTX BOUGHT NEW LAST YEAR AND ONE OF THE FORKS ARE SHORYER THAN THE OTHER. I HEARD THIS WAS A PROBLEM WITH SOME 2003 C, BUT NO RECALL. MY FREIND HAD HIS REPLACED AND NEW TIRE AND HONDA PAID FOR IT NOW I HAVE TO TAKE MY VTX IN AND SEE IF HONDA IS GOING TO COVER IT. JUST THOUGHT I WOULD CHECK AND SEE IF ANYBODY ELSE HAD THE SAME PROBLEM OR KNOWS OF ANYONE HAVING IT?
vtxbigman is offline
post #2 of 5 (permalink) Old 04-08-2006, 12:16 PM Thread Starter
CORRECTION ONE FORK IS SHORTER THAN THE OTHER
post #3 of 5 (permalink) Old 04-08-2006, 12:23 PM
Send a message via MSN to stepper Send a message via Yahoo to stepper
I'm not the best in this field , but this I do know. Other than there actually being a manufactures error on one fork, this may be explainable by what i read in the manual, and also in one of the Fork mod Writeup. There is a threaded rod in the fork that has a nut. If you don't keep this nut in the same place, it will cause a problem. hope thats helps. If the dealer replaces it for you, Cool. Good luck. Stepper
03C, G-Man Inserts,6* T's, Headlight Extended w/ mod,Hand polished TTT-speedo-fork lowers-wheels,custom mirors, Supreme Legends Forwards and Rears, Ope Mod, Chrome Dip, chome ring, Paint- Vagurple w/ Pearl, desmog, Mustangs, Kuryakyn lic plate w/ Chicken Lights, ground and diode Fix, Met200
stepper is offline
post #4 of 5 (permalink) Old 04-08-2006, 12:35 PM
It is NOT a problem. Once the forks are linked together with the wheel and the axle they operate a one solid unit. They are different legths when no wheel or axle is holding them because one fork is for extension, and one fork is for compression. So they work differently to counteract one another. So the compression fork will be longer. The uneveness will not cause uneven tire wear, will not cause the bike to track to one side. They are one solid suspension unit when the wheel is in place. This is from suspension experts Progressive Suspension.
http://www.vtxoa.com/forums/viewtopic.p ... solid+unit
Chicago-Spike is online now
post #5 of 5 (permalink) Old 04-09-2006, 04:54 AM
I'll send thanX Mr. Spike. I was conserned for the man, but what you said is clearly correct. I have mine sitting on the Jack , and I don't see an obvious difference in the length.
stepper is offline
