How to change the spark plugs? - VTXOA
post #1 of 15 (permalink) Old 04-28-2009, 01:27 PM Thread Starter
Hello Experts,
Please let me know how to change the spark plugs. I don't know where they are located to begin with. I tried to pull the chrome (plastic) covers but they are not coming out. I think the spark plugs should be hiding some where behind.
Thanks in advance.
Bulletman is offline
post #2 of 15 (permalink) Old 04-28-2009, 01:30 PM
big jake's Avatar
the chrome covers just sit in a rubber grommet like your side covers do, just pull them out, they pull hard, just be careful not to break the pegs off the plastic.
big jake is offline
post #3 of 15 (permalink) Old 04-28-2009, 01:35 PM
allmack's Avatar
Just did mine for the first time to.
Just grab the chrome cover and pull towrds you , they will come right off, when putting back on just line up the 3 mounting points to the bushings
The plugs are very simple to change also , all you need is a 5/8 plug socket and about a 4' - 6" extension. very straight forward and dont forget to check the gap i used NGK and the gap was all set .035
Good Luck
06 vtx 1300c red w/hypercharger pro , Kuryakyn lizard lights , cobra tachometer
allmack is offline
post #4 of 15 (permalink) Old 04-28-2009, 02:55 PM
madmax's Avatar
put a little dab of lithiem grease on each round tab of covers go in easier and come off easier
Ride free ,always ride defensive as though your invisible to people around you2006 1300R
madmax is offline
post #5 of 15 (permalink) Old 04-28-2009, 03:09 PM
Old Goat
TennX's Avatar
IMHO if your going to own one of these things you should invest in a manual, god forbid the forum crashes good luck
Phil "I should be riding" Ford
06 CBC 1300R Darkside/Foots
"Have You Hugged Your Dog Today"
R.I.P Buddie 2003 - 2015
R.I.P Ginger 2009 - 2015
TennX is offline
post #6 of 15 (permalink) Old 04-28-2009, 03:17 PM
THE MAN 69's Avatar
not to high jack the thread but you can get the manual here.
http://www.mdxiles.com/VTX1300_Service_03_04.pdf
it is rather large so it may take a while, but you can save it to your cpu and go to town...
THE MAN 69 is offline
post #7 of 15 (permalink) Old 04-28-2009, 03:19 PM
Send a message via MSN to Madness_MC
Several helpful hints that I learned years ago before puberty overtook me -
- Go to your local auto supply store and purchase a "special" tool known as spark plug wire pliers - made by K-D or Lisle tools. These allow you to grip the spark plug boot further down on its boot. Give a few mild clockwise-counterclockwise twists of the pliers and the plug wire usually lifts, off reducing the chances of pulling the wire out of the boot and connector. Cost - maybe $20.
- Next, break the spark plugs free with your spark plug socket (and ratchet) and loosen them all about 1 full turn. Crank the engine over several times and you'll hear the compression "putt-putting" past the plugs. What this does is it blows most of the sand, grit and other debris out away from the spark plug holes thereby reducing the chances of anything falling down into the plug hole threads or into the cylinders.
- Next trick is to take a 6” long piece of 3/8" fuel hose. Push the fuel hose firmly over the old spark plugs like they were the spark plug boots being reinstalled. Use the fuel hose to remove the old spark plugs from the cylinder heads. For the new plugs, after straightening the side electrodes, correctly gapping them and wiping a tiny bit of anti-seize compound on the threads, push the same fuel hose over the new plugs. Then use the "flexible extension" to screw the new plug into the head as far as it will go. Doing this for each spark plug greatly eliminates the possibility of cross-threading the steel base of the spark plugs into the aluminum cylinder heads. Lightly snug the new plugs into the heads with a 6” handled 3/8”-drive ratchet. Put a little dab of silicon dielectric grease inside each spark plug wire boot and reinstall on the plugs.
You're done changing your spark plugs.
And yeah, get yourself a VTX1300 Service and Repair manual!!!
Anyone who attempts to do any type of repairs on their vehicle without first thoroughly reading that specific section of the repair manual for their vehicle is asking for troubles. I've been working on cars, trucks, bikes and motorized equipment for 45 years, and I ALWAYS drag out the manual for each vehicle that I'm working on, regardless of how many times I've done the exact same operation.
Madness_MC is offline
post #8 of 15 (permalink) Old 04-28-2009, 03:19 PM
if the forum crashes. then i guess we would see a lot VTX's on craigslist
jwingfiel is offline
post #9 of 15 (permalink) Old 04-28-2009, 03:24 PM
SawltyDawg's Avatar
I agree. Not sure what lithiem grease is. I use "Never Seize". It's the silver looking stuff I stole from work. I am sure it acomplishes the same thing as Lithiem though.
2007 1300 Retro, Switchblade, River Road Saddlebags, Honda Sissybar, Aeromach Risers
SawltyDawg is offline
post #10 of 15 (permalink) Old 04-28-2009, 03:46 PM
NVR2FST's Avatar
I pretty sure he was referring to lithium grease on the chrome cover grommets not the spark plugs. And yes use some anti sieze on the threads of the spark plugs good insurance down the road
[SIGPIC][/SIGPIC]]
2012 Kawasaki Concours GTR 1400
2006 VTX 1300C - Gone
Had Kids
2003 Suzuki GSXR 1000
2002 Suzuki Hyabusa (Twin Turbo mod) - Gone
2001 Honda CBR F4i - Gone
2001 Suzuki Bandit 1200 - Gone
2000 Honda RC51 - gone
2000 HD Fat Boy - Gone
1997 Suzuki GSX 1100
NVR2FST is offline
