odometer LCD replace? - VTXOA
post #1 of 20 (permalink) Old 06-09-2012, 02:03 AM Thread Starter
kotkinjs1's Avatar
after a few years in the FL sunlight my odometer lcd has gotten almost too dark to read in the daytime. I've seen threads about people asking about replacing the entire speedo to solve that (and that the mileage is stored on the speedo board itself, not the bike's computer) but can just the LCD be replaced? I've looked on the various OEM parts websites and they only sell the entire speedo unit. Anyone know where I can just get the LCD and if that only can be replaced?
Thanks in advance!
kotkinjs1 is offline
post #2 of 20 (permalink) Old 06-09-2012, 08:53 AM
Fla.Cableguy's Avatar
Send a message via Yahoo to Fla.Cableguy
If I'm right their a post on the how to do. Will tell you how to change the light, color of it and the face of it. But I'm sure some one will pop in with pics and info. Smitt
[SIGPIC][/SIGPIC]Lot's of time and money. I trust no one's wrench, but my own. Avon Monster Club, Black Out Club, Mat Black Fastest Color....Pay it forward .
Fla.Cableguy is offline
post #3 of 20 (permalink) Old 06-09-2012, 08:59 AM Thread Starter
kotkinjs1's Avatar
Thanks- I think I know the post you're talking about but that deals with the LEDs in the speedo- I need the LCD of the odo itself. Thanks again anyway.
post #4 of 20 (permalink) Old 06-09-2012, 09:16 AM
OOO I see what you wrote now. Can't say I have seen any post's for that before. I'll be watching. Smitt
post #5 of 20 (permalink) Old 06-09-2012, 06:05 PM
Thanks in advance!
Mine did the same thing for the same reason, too long in the Florida sun. My solution was to replace the entire speedo base and move the bike to North Dakota. To be serious, I don't think the LCD is a replaceable unit. If I remember correctly, when I looked at it, it was hard soldered to the base and it doesn't show as a separate part on the fiche.
cdockter is offline
post #6 of 20 (permalink) Old 06-09-2012, 06:39 PM
Have the same problem here in Arizona, I'm actually on my second speedo and it is browned over also. Will be checking around to see if I can find a shop that can just replace the LCD. If I can find one I'll let every one know.
STUMPY-D
2003 1300S
DAVE M is offline
post #7 of 20 (permalink) Old 06-09-2012, 11:42 PM
Jim-Eye's Avatar
Hello,
I created the LED write up. (I've had the dash assembly apart) The Digital display part is soldered in, but a steady hand and a fine soldering tip should do the trick. I would contact DigiKey to see if you can get the part seperatly. Good luck
Jim-eye
Jim-Eye is offline
post #8 of 20 (permalink) Old 06-10-2012, 10:21 AM
jangell's Avatar
Mileage is not stored on the computer. I've done speedo LEDs for a lot of people and I always hook them up to my bike to test them and send pics. It always shows their mileage not mine.
Also, on replacing the LCD display, it's not extremely difficult And if you're doing that you could change the LEDs too if you want. Removing the LCD display is the "hardest" part of the led change. The LCD is a 12 or 16 pin connection (can't remember for sure how many). You just have to use a solder gun to remove it. Heat up one at a time and work your way across. Unless you have a hot air solder station then you can do it all at once. I've done them numerous times. Like I said. Not a huge deal.
Progression of My Bike
My Bagger Build - Bike 2
2006 VTX1300 F'n C
2004 VTX1300(S) Custom Bagger
2002 VTX1800C 1940CC modded w/ 240 conversion
jangell is offline
post #9 of 20 (permalink) Old 06-10-2012, 03:24 PM
For future reference, do you have a part number and supplier for the LCD panel?
Thanks in advance!
cdockter is offline
post #10 of 20 (permalink) Old 06-10-2012, 03:54 PM
jangell's Avatar
Thanks in advance!
I don't have the part number. I've never replaced one. I've removed them to replace the LEDs. I will see if I can find them online. Right now I've found http://www.phoenixdisplay.com/24hoursquotes.php
They can replicate the one you have.
2006 VTX1300 F'n C
jangell is offline
