LED strip tail light - VTXOA
post #1 of 3 (permalink) Old 04-14-2016, 01:14 PM Thread Starter
slip's Avatar
Hi all, I am designing a RGB strip LED that will wrap around my rear fender that will be the tail/brake/left turn signal/right turn signal all in one. I want to make it so that it is basically plug and play. Going to put the electronics in a waterproof case with leads that have bullet connectors for the brake/left/right turn signals. The case can be mounted near the battery. Suggestions for the battery and ground conn
Question: Where are the quick disconnects for the left/right turn signals and brake light located at? I assume they are close to the lights.
I have it working on the bench. Going to build a prototype unit and install on the bike. I'll post a video of it after I install it. Stay tuned.
slip is offline
post #2 of 3 (permalink) Old 04-14-2016, 01:38 PM
Here's a pic of the right side of the bike with cover removed. This is very modified, so yours will look different. In any case, do you see the vertical rubber boot on the left side of pic next to the frame? That's where your brake/tail/blinker quick connects are.
Randy2575 is offline
post #3 of 3 (permalink) Old 04-15-2016, 11:09 AM
SeaSteve's Avatar
Holy Crap does that look clean!
The wires disconnect from the "from" the boot and then run into the rear fender. You can get wire color codes off the your bikes schematic at BareAssChoppers.
Meatloaf~Bat Out Of Hell
SeaSteve is offline
