I'm trying to figure out where this vibration/rattle is coming from.
It's kind of a buzzing sound around 40/45mph+.
Kind of sounds like something from the fairing or speedo cluster. (I recently took apart the speedo from the housing to replace the felt gasket around the two. I'm 98% sure I put back all the little plastic shims around the bolts. The fairing seemed secure, I even opened the headlight bucket to check in there since one of my driving lights was not working.
The only thing I can figure is the right side bolt by my fairing windshield by the brake reservoir is vibrating enough to hit the reservoir.
I'm inclined to turn the brake a little to fix it.
I can't move the fairing up any higher. I might be able to tilt it down a touch, but I'm not sure if I have any more tilt.
