Triple Whammy™ Run-Turn-Brake Light Kit - VTXOA
post #1 of 20 (permalink) Old 07-21-2016, 02:59 PM Thread Starter
jackk's Avatar
Has anyone installed one of these? Problems? Advise?
jackk is online now
post #2 of 20 (permalink) Old 07-21-2016, 05:03 PM
House O' Pain's Avatar
I have one of these on my VStar and it was very simple to install. On my VTX, I opted for this instead:
https://kisantech.com/mag/tailblazer.html
It's just a bulb that flashes in the same way as the whammy (sans flashing signals with the brake).
Here is a previous discussion on flashing tail light options:
Flashing Brake Lights
Good that you are doing something to improve your rear visibility.
Just don't ask if you rear looks fat.
House O' Pain is offline
post #3 of 20 (permalink) Old 07-21-2016, 05:41 PM
I'm not an electrician, so my buddy Renegade Rick installed mine. Because my 1800 C only has one blinker indicator for both turn signals, he had to wire something different, maybe an extra resistor? in order for mine to flash properly. If you then use LED lights, it will flash rapidly unless using an LED flasher relay.
post #4 of 20 (permalink) Old 07-21-2016, 06:26 PM
DaveAA's Avatar
installed this 10-12 years ago with no problem, still working fine
http://www.kuryakyn.com/products/734...ake-controller
switched the turn signals to red lenses at the same time
today I learned they now sell it as a package! get the front bezels too, improves the looks for not much $
DaveAA is offline
post #5 of 20 (permalink) Old 07-22-2016, 03:36 PM Thread Starter
jackk's Avatar
I ordered this today and watched a video on the install. Not a good video from kurakyn! He cut 4 wires on the input side and 3 on the output side? Also seamed a little confusing on the colors. I am not using led's but still have a concern on the install. Just trying to be prepared. Looking for any help out there!!!!!
jackk is online now
post #6 of 20 (permalink) Old 07-22-2016, 03:40 PM Thread Starter
jackk's Avatar
Also the comments on that video were all negative. Over a half dozen weren't answered!
jackk is online now
post #7 of 20 (permalink) Old 07-22-2016, 07:44 PM
My best advice to anyone would be to consider what you want before you purchase. If the desire is for a pulsing rear brake function and always on rear signals that also pulse with the brake light, (you'll have to change lenses to red and you state laws must allow this) get the plug-n-play:
Kuryakyn product:
Fitment: Part#4610
'06-'09 VTX1300C, '06-'09 VTX1300R, '06-'07 VTX1300S, '08-'09 VTX1300T, '05-'07 VTX1800C, '04-'08 VTX1800R, '04-'07 VTX1800S & '07-'08 VTX1800T
If you don't want to change your rear lenses to red and don't care about the always on option, or the signals also flashing with the brake, simply buy the TailBlazer light bulb, as it gives you the bright, pulsing rear brake light and you need only screw in the bulb and you're done:
post #8 of 20 (permalink) Old 07-23-2016, 09:46 AM Thread Starter
jackk's Avatar
I do not have a service manual. Will someone give me the required wire color/function for a stock bike? Thanks
jackk is online now
post #9 of 20 (permalink) Old 07-23-2016, 06:22 PM
I couldn't find anything for a 1300, but this is a 'how to' for the 1800 that could help
http://tech.bareasschoppers.com/elec...inker-install/
post #10 of 20 (permalink) Old 07-24-2016, 01:23 PM
I installed this last winter. With a meter you can tell which wire color goes where. The hardest part was getting all the new wires tucked back into the same space.
onurleft is offline
