Brake light modulator - VTXOA
 17Likes
post #1 of 83 (permalink) Old 07-25-2016, 03:57 PM Thread Starter
slip's Avatar
I have designed a brake light modulator that is plug and play. Simple 4 wire hook up. Brake switch wire has male bullet connector. Brake light wire has female bullet connector. 12V wire, and a ground wire. Let me know what you think.
Landisil and nate6966 like this.
slip is offline
post #2 of 83 (permalink) Old 07-25-2016, 06:14 PM
If that would work on my 1800F with the factory LED brake light, I would be seriously interested in it!
I've avoided the brake light flashers just because I haven't seen an option for a reasonable price. I've just gotten into the habit of flashing my brakes on my own every time there is someone approaching me when I'm stopped.
'07 VTX 1800F spec 3
post #3 of 83 (permalink) Old 07-25-2016, 09:00 PM Thread Starter
slip's Avatar
Yes, it should work with the factory LED light. My module handles the incandescent bulb on the 1300 which draws about 2 amps. But it actually should handle at least double that. I'll get a picture of the module up soon. It is a real easy hookup. Is the brake light connection behind the side cover on the 1800. Let me know for sure so I know what length to make the brake wire. What do you think of the flash rate? What about the amount of times it flashes. Im open for suggestions. It's programmable, so I can adjust that. I'm charging $16 for the module.
slip is offline
post #4 of 83 (permalink) Old 07-25-2016, 09:46 PM
Sounds like a deal. Yes, the connections are behind the right side cover. As far as the flash rate, I think it's fine. Does it continue cycling the flashes, or only right when you activate the brakes?
Sent from my... wait - No free advertising here!
post #5 of 83 (permalink) Old 07-25-2016, 10:17 PM Thread Starter
slip's Avatar
It does three quick flashes 3 consecutive times, and then light goes on steady After brakes are applied.
slip is offline
post #6 of 83 (permalink) Old 07-25-2016, 10:41 PM
Works for me! I'll pm you my info
post #7 of 83 (permalink) Old 08-12-2016, 09:11 AM Thread Starter
slip's Avatar
I have 4 new brake light modulators ready to ship. Anyone want one. $18.50 S&H is included.
slip is offline
post #8 of 83 (permalink) Old 08-12-2016, 09:39 AM
SeaSteve's Avatar
I bought one of your earlier models last year. You had a little "production" issue with sealing the plastic wrap around the circuit board. Is that issue corrected?
Meatloaf~Bat Out Of Hell
SeaSteve is offline
post #9 of 83 (permalink) Old 08-12-2016, 01:49 PM Thread Starter
slip's Avatar
Yes SeaSteve, it will be water tight. Nice weather proof bullet connectors for the brake light/brake switch connection as well.
slip is offline
post #10 of 83 (permalink) Old 08-14-2016, 09:54 AM
I'll take one. PM your PayPal info.
06 Candy Black Cherry 1300C with Foots Mod, Chrome rims, final, and swingarm.........and a lot more.
Quietrider is offline
