does anyone have a fuel/carb/gas tank diagram? - VTXOA
post #1 of 10 (permalink) Old 10-03-2016, 01:20 PM Thread Starter
My 2004 1300C has been sitting apart for quite some time, and I cant seem to recall where all the little hoses and stuff go, can anyone provide a diagram or show where I can find one ? upon starting the bike it simply cranks and no fuel appears to be going into the motor.
hedgehog is offline
post #2 of 10 (permalink) Old 10-03-2016, 07:41 PM
Welcome to the forum....
frnkcat is online now
post #3 of 10 (permalink) Old 10-03-2016, 07:57 PM
The petcock needs vacuum to operate. Make sure it's hooked up.
Donnie Downer is offline
post #4 of 10 (permalink) Old 10-04-2016, 09:43 AM
jammerwalker's Avatar
You can see diagrams for almost everything on any of the sites that sell OEM parts, like Partzilla, BikeBandit, etc. That should help. You should also get a manual.
(((=-JammeR-=)))
jammerwalker is offline
post #5 of 10 (permalink) Old 10-04-2016, 10:00 AM
SeaSteve's Avatar
MRVTX has a great write up on disassembling and cleaning the 1300 carb and Bareasschoppers has a great write up on removing the gas tank. Between the two you should be able to correctly assemble yours.
Meatloaf~Bat Out Of Hell
SeaSteve is offline
post #6 of 10 (permalink) Old 10-04-2016, 10:22 AM
Intake manifold(Vacuum source)---------------Tee--------------Air cutoff valve on carb
.................................................. .....................| Tee to petcock
Extra Tee and hose if PAIR valve connected..
2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back. 178,645 miles of smiles
post #7 of 10 (permalink) Old 10-08-2016, 03:32 PM Thread Starter
Whats this do?
hedgehog is offline
post #8 of 10 (permalink) Old 10-08-2016, 03:34 PM Thread Starter
Where does this vacuum hose go? My vtx will only run with the choke out even after warming up it will stall out and die if i push the choke in. Upon revving it gives loud POPS when the rpms come back down.
hedgehog is offline
post #9 of 10 (permalink) Old 10-09-2016, 09:19 AM
Engine Idle screw adjuster in your hand..
Rubber hose looks like intake manifold to Tee hose.
Probably removed when PAIR removed.
http://www.partzilla.com/parts/searc...%29/parts.html
post #10 of 10 (permalink) Old 10-14-2016, 06:12 PM Thread Starter
figured it out all, thank you guys
hedgehog is offline
