Smog and Speedster Swepts - VTXOA
post #1 of 4 (permalink) Old 01-19-2017, 04:24 PM Thread Starter
Cuthbert J Twillie's Avatar
Howdy, Do all VTX 1300's have the Pair Valves or just the California bikes?? I just took delivery on my Cobra Speedster Swept Pipes. I know this Pair Valve talk has been exhausting in its coverage.....but unclear if my 2006 1300 has the anti smog device or not. If it does, it seems everybody has a method. Plug this hose with a sheetrock screw. Another, don't plug it, its the breather tube. I trust in my web wondering I find a mechanic who lays it out in certain terms.
But for now, Do ALL VTX's have Pair Valves??
Cuthbert J Twillie is offline
post #2 of 4 (permalink) Old 01-20-2017, 08:14 AM
All bikes have the PAIR system. Do not plug the hose, it will fill up with condensation. Remove it, plug the cap at the engine or just buy the $15 plates. See this http://tech.bareasschoppers.com/engine/vtx-1300-desmog/
post #3 of 4 (permalink) Old 01-20-2017, 12:21 PM
The breather tube is a crankcase 'vent' & must be kept open, un-kinked and working.
If not, pressure will build up and blow out engine seal at shifter!!
The PAIR system is on all VTX bikes, Calif Models have a few extra pieces..
Even a carbon canister at rear of frame in front of rear tire to filter fumes..
Looks like a soup can.....
Get the plates and do it clean if removing the system.
I ran mine with hose plugged (right at air cleaner) for about 1K miles before I got the plates and cleaned up mine.
No water vapor in vac line when I finally took it off...???
post #4 of 4 (permalink) Old 01-20-2017, 05:55 PM Thread Starter
Thank you for the link!
