Enrichen A/F mixture with Big Shots? - No rejetting, rest is stock - Page 3 - VTXOA
 4Likes
post #21 of 26 (permalink) Old 02-15-2017, 12:59 PM
No vibrating noise, hangs down next to Idle adjustment, below air filter housing... If you adjust the A/F you can easily replce the screw with new one from Glen.... Unscrew old, make sure rubber O ring, spring and metal washer is out. May need a pick or Paper clip to feel around inside threads with..
Screw in new one....... Adjust........
post #22 of 26 (permalink) Old 02-16-2017, 06:08 AM Thread Starter
Awesome, so installation is easy enough to not do something wrong? I would very likely have my mechanic do it.
I take it that it's very easy then to have bike with stock A/F then, correct? Since I'm having to go every 2 years to emissions testing, I'd simply turn Glenn's A/F screw on the spot an hour or two before taking my bike for inspection. So is it as easy as I'm imagining to go back to stock A/F mixture?
Thanks!
EuroDude is offline
post #23 of 26 (permalink) Old 02-16-2017, 11:26 AM
Thanks!
Yes it is an adjustable idle jet.
The setting of that jet is as easy as stated.
Screw it in or screw it out....
You will likely not notice anything with its setting changes.
Possibly a better/smoother idle..
Every bike engine is different, we all set jets and air different to our own taste and running. My settings may not work on another bike.
Slight differences in Carbs, Intake volume, Spark, Vacuum leaks etc will demand different settings to run smooth and strong..
I have a 220 Main jet (stock is 95) a 58 Pilot jet (stock is 55) and A/F is at about 2 1/4 turns (stock is 1 5/8 .. I also have a more open air/filter Spike intake..
I also have 'Clayton Mod' to pipes. Drilled out with 1 deep through baffle (1/2" holes). Sounds good to me & runs strong...
It runs good & sounds good at this point for me and how I ride.....
I can average 42/44 MPG if I dont hot rod to much. But has been as low as 36/38MPG when I do hot rode a lot or run around town a lot....
I really like the feel and sound, at 72 yrs old I ride like a teenager. LOL
post #24 of 26 (permalink) Old 02-16-2017, 04:42 PM
Thanks!
Honestly, I wouldn't even bother with the AF. It only affects such a small portion of the throttle. Just put the pipes on and see how it runs.
Donnie Downer is offline
post #25 of 26 (permalink) Old 02-17-2017, 06:36 AM Thread Starter
Thanks, folks.
Well, Big Shots arrived yesterday. No dents or scratches. Looks high quality and they're very light. I thought they'd be heavier and they look heavier. I've read people mentioning stock pipes are very heavy, so good way to remove some excess weight from the bike.
I'm now just waiting for the quiet baffles.
At this point I'm going to simply have the Big Shots + quiet baffles installed with NO tuning of A/F mixture (nor jetting). I'll let you know of how that goes in this thread.
Question:
It's hot where I live and it's also a long journey for the quiet baffles to arrive at my house. Do you think that quiet baffles could be damaged in transit due to impact or heat? Would any damage to the quiet baffles be readily visible?
EuroDude is offline
post #26 of 26 (permalink) Old 02-20-2017, 08:52 PM
DaveAA's Avatar
can't be hotter than IN the exhaust they're made of fairly heavy steel wrapped in exhaust packing. you can't hurt them.
I put that same setup on recently, sounds great. not obnoxious. didn't change anything else and it runs fine
DaveAA is offline
