quick help needed - VTXOA
  • 3 Post By Donnie Downer
post #1 of 4 (permalink) Old 02-13-2017, 07:04 AM Thread Starter
mightywarrior72's Avatar
quick help needed
VTX 1300R
My front brake caliper is loose. It shakes like a loose tooth. What bolts do I need to tighten.
I need to ride in about 1 hour from now.
Thanks
mightywarrior72 is offline
post #2 of 4 (permalink) Old 02-13-2017, 09:43 AM
Originally Posted by mightywarrior72 View Post
My front brake caliper is loose. What bolts do I need to tighten.
The loose ones.
rangers4u, lofty and steveroy60 like this.
Donnie Downer is online now
post #3 of 4 (permalink) Old 02-13-2017, 09:45 AM
cal_105's Avatar
See if it is the Caliper bolts or the Disc bolts. Also check the wheel to see if it is loose if you have not already done so. There are several disc bolts holding the disc to the wheel, and two main bolts as I recall on the right side of the front wheel assembly that need to be tightened for the Caliper to the fork assembly. they are supposed to have lock lite on them. I would not ride until these are tight.
cal_105 is offline
post #4 of 4 (permalink) Old 02-13-2017, 09:51 AM
The caliper slides on the bracket, which is bolted to the forks. What exactly seems to be loose? Bracket, caliper, pads???
The bracket should feel solid, the caliper slides on two pins and it is normal for it to have some play, if that's what you're feeling. The pads have a sheet metal "spring" to keep them from bouncing around, did you lose it?
