Fuse problems - VTXOA
post #1 of 5 (permalink) Old 03-18-2017, 05:52 PM Thread Starter
Fuse problems
2004 vtx 1300 c. Tailight and speedometer wont work after storage.Fuse blown,put in new fuse blows right away so must have a bare wire somewhere. Is there a common place to start my search that is a common pinch point. Thank you.Took my tank off and unhooked it so I believe its not shorting out in the speedo housing.Also no mice damage that I can see easily.
Little Butch is offline
post #2 of 5 (permalink) Old 03-18-2017, 06:05 PM
Add Front Run lights, license plate light and speed sensor on the rear of engine case inboard of the drive shaft.
Any mods in the off season????
In the right side cover you can remove the rear lights with the bullet connectors in the clear plastic sleeves..
A Black/Brown stripe wire.
Also goes to the "Optional fog light? connector in the headlight bucket..
Some aux/fog lights have shorted at a hollow bolt I believe..
2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back. 179,444 miles of smiles
post #3 of 5 (permalink) Old 03-18-2017, 09:38 PM Thread Starter
Thanks for the reply.Found it.Tail light brown wire.Wires run between a brace and fender,wire had slid down and got pinched.Never did a thing to it all winter,just strange timing.lol.thanks
post #4 of 5 (permalink) Old 03-18-2017, 09:47 PM
Near this area??
Black/Brown goes to Brown in the rear... I forgot that change...
File Type: jpg 1300C Rear fender cables-wiring pic.jpg (556.4 KB, 13 views)
post #5 of 5 (permalink) Old 03-18-2017, 10:59 PM Thread Starter
Yes,that area exactly.Going to stuff something toward the bottom so it can not work down in there again.
