Handlebars wobbling - VTXOA
post #1 of 5 (permalink) Old 05-17-2017, 02:23 AM Thread Starter
Melvin Macaroyo's Avatar
Handlebars wobbling
Just change my tires and balanced. when I let go handlebars I still get wobbling on the handlebars does anybody know what is causing this problem
Melvin Macaroyo is offline
post #2 of 5 (permalink) Old 05-17-2017, 02:56 AM
Look at rear shock bushings or could be you haven't upgraded the stem bearings to the tapered ones.
post #3 of 5 (permalink) Old 05-17-2017, 07:02 PM
Look up 'Death Wobble' in the search feature. Shock bushings are cheap, try that first. If not, then you need a $30 set of 'All Balls' brand steering neck bearings. the stock OEM from Honda are worse than on a Schwinn. You can probably get them changed free at a tech session, or maybe a member close to you could help if you would post exactly WHERE you are. 2-3 hrs. for someone with experience changing them. And a special tool or 2 are needed.
post #4 of 5 (permalink) Old 05-17-2017, 07:12 PM
Check your tire pressure
Kn!ght is offline
post #5 of 5 (permalink) Old 05-19-2017, 05:27 PM
leroys73's Avatar
My first thought was front tire. That is the only time at any speed mine wobbled up to 96,000 miles. Then they weren't bad but changed when up graded the suspension to Race Tech with Gold Valve.
However, since you have a new tire and balanced, hopefully correctly, then I would agree with the steering head bearings unless the they need a little tightening. New ones would be the best way I would go then you are sure.
As stated above there are other factors in the rear that can cause it and the shock bushings are cheap to try first.
My VTX as used on Race Tech site.I'm68 rode to 49 States+DC & 11 Provinces, 127k on my '07 Black Cherry VTX1300R w/aux tank, Race Tech Gold F&R,Mean City Cycle, Motolights, Glen's Light Bar w Rivco H-4 aux headlights w/SS Utra bulbs,Radiantz LEDs,Baron tach,Marlin therm&clock, PowerLet,Break-A-Way,K&N, IBA: 2xSS2000,12xSS1000,4xBB1500,2TX1000,NPT 29/76; Lake Superior Circle Tour
leroys73 is offline
