time for my first oil change - VTXOA
 20Likes
post #1 of 26 (permalink) Old 05-17-2017, 05:32 PM Thread Starter
Pumba23's Avatar
Hey guys, i was doing some searching around, and I've found mixed answers. I want too change the oil in my bike, because i'm not totally sure the last time it was changed. What oil weight/brand is best to use? My Honda repair manual says 10/30, a lot of guys on here seem to like 20/50 or rotella. I've always used 20/50 in other bikes. just don't want to use the wrong stuff. Also recommendations on filters welcome. I know not to trust fram already.
'04 1300C, 45k miles, Mustang seat and backrests, Rinehart Racing exhaust, Cobra floorboards
Stay safe, Shiney side up
Pumba23 is offline
post #2 of 26 (permalink) Old 05-17-2017, 05:38 PM
footprintsinconc's Avatar
Send a message via Yahoo to footprintsinconc
I use to use mobile one...now use rotella T6.
There are a ton of oil threads here to look through
Sent from my SM-N920T using Tapatalk
21" Fats Memphis Shades, V&H Bigshots, AB neck bearings, Jeff's Power Box, Matejj's Driving Lights, VTX1300Retro's Backrest Plate, Glen's CPR, Drive Shaft Cover, CustomCruiser 2.5" Headlight Extension, Ultimate LowRider w/ backrest, 150mm Avon Venum Radial FT, Darkside CT General Grabber 205-70R15, Stebel Twin TM80 Magnum Horns ....& more to come
footprintsinconc is offline
post #3 of 26 (permalink) Old 05-17-2017, 06:57 PM
Chuck_VTX_F runs Fram filters, for decades, on all his many Hondas. He's a retired Honda/ bike/ auto mechanic, and knows his stuff. Fram stories= fallacy. I personally use Mobil 1, 4T Racing synthetic, 10W40, and Mobil 1 M108 filter. Just because. Not pinching pennies. I like to spoil my bikes and women. Remember there are 2 drain plugs. Once you change oil, if you check the level while sitting level, when you put it on the kickstand, re-check the level and mark with a little file so you can check it that way in the future w/o having the bike sitting level.
Pumba23 likes this.
post #4 of 26 (permalink) Old 05-17-2017, 08:11 PM
I love using Purolator PL14612 oil filters (search Amazon for these, they're an amazing deal) and Amsoil for metric motorcycles. I've tried a few other routes and feel like this combo is what's right for my bike and my climate
'07 VTX 1800F spec 3
post #5 of 26 (permalink) Old 05-17-2017, 08:27 PM
We rarely use 20-50 here. Liquid cooled engine does not need it.
A couple cases where the sprag would not engage when the starter motor turned over.
10-40 is the most popular, should be the most preferred in the Honda engine oil temp chart.
Diesel engine oil is in common use, Rot T6 5-40 syn, I use it sometimes. Good winter oil.
Usually 15-40 Diesel oil is what I use. I have done 39 oil changes some with automotive engine oils....
I like the Purolator, it has a large filter area, simple bypass valve. L14612(standard), PL14612(better).
I prefill my oil filters before installing....
post #6 of 26 (permalink) Old 05-17-2017, 09:02 PM
shell rotella synthetic or dino.
i used to use synthetic rotella but have switched to dino some time back
i change every 2-3 thousand miles anyway so no need for synthetics
my vtx has had rotella from day one...31.000 miles and purrs like a kitten
skeeter69392 is offline
post #7 of 26 (permalink) Old 05-17-2017, 09:03 PM
Your engine is water cooled, 20-50 is not needed to help cool the engine. Sure you can use it, by why when it doesn't help any.
When you do change your oil, remember there are 2 drain plugs on this Honda engine. Go here and see the write up on how to change the oil http://tech.bareasschoppers.com
nate6966, StarrRider and Pumba23 like this.
post #8 of 26 (permalink) Old 05-18-2017, 05:07 PM Thread Starter
Pumba23's Avatar
Thanks guys! Much appreciated
Sent from my SAMSUNG-SM-G891A using Tapatalk
Pumba23 is offline
post #9 of 26 (permalink) Old 05-18-2017, 08:39 PM
cavie's Avatar
Rotella T-6, Mobil 1-110 filter 2005 1300R 49,000 miles. Don't make yourself crazy with this. Just use any recommended oil and filter and ride. Do you mull over this stuff with your car? I'm guessing not.
cavie is offline
post #10 of 26 (permalink) Old 05-19-2017, 09:29 AM
stemo's Avatar
And don't lose the copper washers on each drain bolt. Don't ask me how I know this.
stemo is offline
