2005 Honda VTX 1300C Oil Filter Replacement Cross Reference?
+ Reply to Thread
Results 1 to 15 of 15
Thread: 2005 Honda VTX 1300C Oil Filter Replacement Cross Reference?
  1. #1
    Default 2005 Honda VTX 1300C Oil Filter Replacement Cross Reference?
    I know I saw this somewhere, but can somebody point me to a cross reference listing of replacement oil filters for the Honda 15410-MCJ-003 that goes on the 2005 Honda VTX1300C? I'm trying to find it at a local store instead of going to the Honda dealer and paying for the name instead of the performance.
    Thankz, Take Carez and Laterz,
    WarriorOfStormz
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member drewn's Avatar
    Join Date
    Jun 2005
    Location
    Oregon
    Posts
    423
    Default Oil filter......
    NAPA part #1365 FIL or #FIL 1365
    Bosch part #3323
    WIX part #51356
    I know the NAPA is about 2/3 the cost of stealer.
    Good Stuff.
    "Got my whole world to live through,......
    and I ain't gonna copy you."
    "If 6 Was 9"
    James Marshall Hendrix
  4. #3
    Join Date
    Oct 2005
    Location
    Houston, Tx.
    Posts
    213
    Default
    K&N # KN-204
    also
    Fram # PH6607
    DAR - 05 1300R
    Houston, Tx.
  5. #4
    Default
    Thankz Guys!
    WarriorOfStormz
  6. #5
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    57,736
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  7. #6
    Senior Member fev1969's Avatar
    Join Date
    Apr 2005
    Location
    Southern Illinois
    Posts
    3,231
    Default
    mobil 1 filter is a little pricy, but you get what you pay for, excellent filter, combine it with some mobil one synthetic or some amsoil and your good to go for 5000 to 6000 miles.
    http://i14.photobucket.com/albums/a314/fev1969/bw2.jpg[IMG][/IMG]
  8. #7
    Senior Member Hans&Feet's Avatar
    Join Date
    Jun 2005
    Location
    Conyers/McDonough, GA
    Posts
    6,008
    Default
    C-Spike has a good link. This one has a view of the internals of many filters. http://motorcycleinfo.calsci.com/FilterStudy.html
    I have opened up an OEM and a SL14612 filter. Page 3,4 of my BigBikes
    photo post.
    2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back.
    160,330 VTX miles...​On 10th frt tire, 14th rear tire
    When you stop learning, you are dying.
  9. #8
    Join Date
    May 2006
    Posts
    200
    Default
    Is there an advantage using M1-108 vs M1-110 Mobil one?? I use the 110 and saw that the 108 fits too, but its smaller by about an inch. Anything differnt in there worth noting, or is it just the fact that its a smaller filter, but everything inside is the same. I read on the package that the 110 has an advantage because it can hold and filter twice the amount as other filters.
    I use the 110 with Rotella 5W-40 Synthetic oil.
    Billy
    Dallas, Georgia,
    VTX 1300c Metallic Grey 2006
  10. #9
    Join Date
    Nov 2003
    Location
    Maine
    Posts
    7,141
    Default
    Quote Originally Posted by Incabiker
    The M1-110 is better , more filter media...
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
  11. #10
    Junior Member
    Join Date
    Sep 2005
    Location
    Artesia, New Mexico
    Posts
    24
    Default
    Posted: Tue Jun 06, 2006 8:50 pm Post subject: Oil filter......
    Bosch part #3323
    WIX part #51356
    Good Stuff.
    Hey Dude! The filters listed above WILL, indeed, fit your "X", however, the correct filter that matches OEM is the NAPA 1358, WIX 51358, Carquest 85358, etc. The ones y ou listed above are a little longer and may cause some "fitment" problems.
    NAPA and Carquest filters are manufatured by the folks at WIX. Notice the similarity of the last three digits in the part numbers?
    A cool thing to consider is "Nominal micro rating". That's the size of particles the filter will trap. Smaller is better.
    WIX 51358 has a Nominal Micro Rating of 14.
    WIX 51356 has a Nominal Micro Rating of 19.
    Think I'd stick with the equivilent to the WIX 51358 for my scoot.
    Regards
    Jim
  12. #11
    Join Date
    Nov 2003
    Location
    Maine
    Posts
    7,141
    Default
    Quote Originally Posted by Texican Jim
    Bosch part #3323
    WIX part #51356
    Good Stuff.
    Regards
    Jim
    And the Bosch and Mobil 1 are rated at 10 micron, the longer filters are not a problem on the X
    Albert Einstein
  13. #12
    Join Date
    Sep 2004
    Location
    Smyrna, Tn
    Posts
    595
    Default
    What's the OEM Honda rated at?
  14. #13
    Join Date
    Nov 2003
    Location
    Maine
    Posts
    7,141
    Default
    Quote Originally Posted by nevermore
    No one knows for sure..
    Albert Einstein
  15. #14
    Join Date
    Feb 2005
    Location
    Sask. Canada
    Posts
    193
    Default Filters
    I researched lots of filters and found the Purolator pure 1 to be one of the best . Filters to 7 microns and is made of mostly plastic and not paper so it will not break down.By pass cannot malfunction like a paper one. Honda filters are paper , so are Fram.
    Mustang seat,bigshots,Cruiseliner hardbags,Paladin backrest&rack,kuryakn mirrors,swing arm covers,neck trim,aeromach risers,Silver 2004s, Hoppe fairing,pro hyper charger.
  16. #15
    Join Date
    Feb 2005
    Location
    Sask. Canada
    Posts
    193
    Default filter
    Sorry the part no. for the Purolator is PL-14162.
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
