Okay, I bought a new starter switch housing due to intermitent headlight not working before I researched how to fix/clean the starter button. Now that I have the new housing, I'm not exactly sure how to install it.
The housing (clam shell) is held together by 2 screws. Not sure if I can separate and remove the shells with the master cylinder attached. Do I need to remove the master cylinder first?
Once I remove the starter housing, I'm not sure how to remove the throttle cables. The look like they are threaded into the housing. If so, how do you remove? Also, are the cables attached somehow to the housing on the inside?
I have a service manual, but it doesn't go into enough detail. Any help would be appreciated.
Thanks in advance!
Jeff
Thanks in advance!
Jeff
