Replace Brake Pads
+ Reply to Thread
Results 1 to 5 of 5
Thread: Replace Brake Pads
  1. #1
    Join Date
    May 2006
    Location
    Charleston SC
    Posts
    103
    Default Replace Brake Pads
    I need to replace my front brake pads. The VTX Service Manual gives little info on how to do this. It looks according to the manual you do not remove the caliper? How can you push in the caliper piston without removing the caliper? I know this may sound dumb, but I don't want do more work than needed to replace the pads.
    '06VTX1300R Bright Blue Metallic, Cobra Slash Cut Pipes, Mustang Saddle, Tour Master Bags, Memphis Shades 19" Removed Badges.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member Jack G's Avatar
    Join Date
    Nov 2003
    Location
    Benton,Arkansas
    Posts
    1,557
    Default
    You will see a small flat screw plug. Remove it. Under it is an allen bolt/brake pin. Remove it and your pads will fall out once you've spread them by pushing in the caliper pistons. You can use a large screwdriver to do this by prying between the pads and disc. You may even be able to do it by pressing in on the brake assembly and then pulling back towards you. When placing the new pads, be sure the front ends(without the bolt hole) is properly placed. Also, be sure the spring clip is replaced. Do NOT overtighten the brake pin or it is a bear to remove the next ime. Be very sure to pump your brakes to bring the pads back in contact before you go riding. Don't ask how I know.
    '99 Valkyrie
    Two lane blacktop isn't a highway, its an attitude.
  4. #3
    Join Date
    May 2006
    Location
    Charleston SC
    Posts
    103
    Default
    Thanks for the info Jack !
  5. #4
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    57,497
    Default
    Bookmark or save to your favorites folder, these websites, http://tech.vtxoa.com This is the VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX.
    The VTXOA Garage has a page or two on replacing the pads
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  6. #5
    Join Date
    May 2006
    Location
    Charleston SC
    Posts
    103
    Default
    Ditto Spike !
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
