240/50 Sumo-X Fat Tire Kit Install
+ Reply to Thread
Results 1 to 4 of 4
Thread: 240/50 Sumo-X Fat Tire Kit Install
  1. #1
    Junior Member
    Join Date
    May 2007
    Location
    Canada
    Posts
    13
    Default 240/50 Sumo-X Fat Tire Kit Install
    Does anybody have any "Step-by-Step" instructions for installing a SUMO-X Fat tire kit on an VTX 1800 C ? Not exactly sure where to cut the ears, how to unistall the final drive and wiring. Thanks!
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    57,951
    Default
    Get a service manual, it has all the details you want with pictures included. Really a neccessity for large jobs like this. Also, contact SumoX for their torque specs on their parts.
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  4. #3
    Join Date
    Aug 2004
    Location
    North East Scotland uk
    Posts
    332
    Default
    Summo x had pictures on their web site showing where to cut the frame and also how to install the the rear end after your swingarm has been modified to take a 240/250 .As for the lights just disconnect all the wires and and if fitting a side mount join them up .The same goes for the rear flashers .
  5. #4
    Join Date
    Nov 2003
    Location
    Stockton, CA.
    Posts
    211
    Default Re: 240/50 Sumo-X Fat Tire Kit Install
    bigwaks,
    Like saltire mentioned SumoX has instructions on their website. I did a little write up for my SumoX build. You can check my site out here.
    http://netjam.com/vtx-html/Phat.htm
    My bike is a 1800R not a "C" model. It will give an idea what's involved.
    Cheers!
    Netjammer-
    Quote Originally Posted by bigwaks
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
