License Plate Light Removal
+ Reply to Thread
Results 1 to 16 of 16
Thread: License Plate Light Removal
  1. #1
    Junior Member
    Join Date
    Jan 2007
    Location
    Hilliard, OH
    Posts
    24
    Default License Plate Light Removal
    I am trying to remove the license plate light from my 1300C. I have taken the housing and everything off, except there is 1 wire in the back of the light that runs directly into the center of the light and I cannot get it out. I really do not want to cut it, any ideas?
    Scott
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Aug 2004
    Location
    SC Columbia
    Posts
    4,839
    Default
    Are you just trying to replace the bulb, or remove the whole thing from the bike?
    To replace the bulb, here's what the Service Manual says:
    Remove the bolt and bulb socket cover from the rear fender.
    Turn the socket counterclockwise and remove it.
    Pull the license light bulb out of the socket and replace it with a new one.
    Looking at the diagram, the bolt is installed pointing down, with the hex head at the top of the bulb housing.
    Eddie
    2004 Red 1300S, Clayton Mod, Ultim. LowRider w/ Driv & Pass Backrests, wishmasterg Riser, Cobra Eng Grd w/ Floorbrds, Pass. Floorbrds, Honda Dlx Sissy Bar&Dlx Luggage Rack, Lightbar, 19" Memphis Wndshld, Memphis Lowers, TourMaster Zipper-Removable Bags, HDL Fender Tip, Chrome V-Radiator, Freeway Blasters, Turn Signal Beeper, Remote-Controlled LED Lighting, Backoff Module, X-Hinge, Garmin 2610 GPS
  4. #3
    Junior Member
    Join Date
    Jan 2007
    Location
    Hilliard, OH
    Posts
    24
    Default
    I am removing the entire light from the bike. On the back of the light there are two wires, one has a plug on it and the other goes into the center of the light socket. Is there a way to remove the socket and/or wire without cutting it?
    Scott
  5. #4
    Join Date
    Mar 2004
    Location
    Corpus Christi, TX
    Posts
    1,098
    Default
    CUT IT!!!!...(Thats all you can do...or follow it into the right side cover and mess with the whole bundle there)...Brown wire by chance?....cut it!!!!
  6. #5
    Join Date
    Jul 2007
    Location
    Miami FL
    Posts
    253
    Default
    I cut it and replaced the lamp with a RADIANT tag bracket/lamp and install round terminals
    2006 VTX 1300 C Candy Orange
    2004 Shadow Aero 750
    1979 suzuki 185 all terrain
  7. #6
    Senior Member Fossil (not)'s Avatar
    Join Date
    Mar 2007
    Location
    Maple Ridge B.C.........C eh N eh D eh
    Posts
    214
    Default
    Quote Originally Posted by gildagu
    I am quite interested in how that was done! More info please!
    ........His; 2006 Candy Tangerine VTX 1300C...................
    ................... Hers; 2004 Black VTX 1300C......................
  8. #7
    Senior Member VTX MIKE VTX's Avatar
    Join Date
    Sep 2007
    Location
    MARLBORO, NEW JERSEY
    Posts
    484
    "Treat every day as if it were your first and every opportunity as if it were your last."
    www.midatlanticxriders.com
  9. #8
    Join Date
    Mar 2007
    Location
    Posts
    214
    Default
    Thanks so much for the link!! This mod just jumped to the top of my to-do list!!
  10. #9
    Seasoned Member VTX1300cnME's Avatar
    Join Date
    Feb 2008
    Location
    Southern Maine
    Posts
    7,329
    Default Re: License Plate Light Removal
    Quote Originally Posted by scottc_ohio
    CUT IT. No other choice. If you ever go back to using the stock setup, that's what solder and shrink wrap are for.
    Bub Club member #361
  11. #10
    Junior Member
    Join Date
    Jan 2007
    Location
    Hilliard, OH
    Posts
    24
    Default
    OK guys thanks for the help.
    But, I have another question. I bought a license plate frame that has a brake light and license light, however it only has two wires. The instructions state "Wire one each to your brake and tail lamp circuits or together for an extra bright stop or running light or use your imagination."
    Any advice?
    What about the ground wire that was hooked up to the old license plate light, where should I hook it up?
    Scott
  12. #11
    Join Date
    Sep 2007
    Location
    Posts
    484
    Default
    Any advice?
    What colors are the wires? I think it may be: hook up either the brake or the lamp light. Or together for an extra bright stop or running light.
    I don't know why it would only have two wires???? Is their any type of tab for mounting the ground???
  13. #12
    Junior Member
    Join Date
    Jan 2007
    Location
    Hilliard, OH
    Posts
    24
    Default
    No there is no tab for mounting the ground. This unit has both a brake light and also the license plate light, each light has one wire. Not sure what the heck to do with the ground, I am really stumped.
    Scott
  14. #13
    Join Date
    Mar 2007
    Location
    Posts
    214
    Default
    Quote Originally Posted by Fossil (not)
    Thanx again for the link! Did the mod today. I think the look is much improved. This Signal Dynamics plate frame has an LED run/brake light in it as well.
  15. #14
    Senior Member Hydrazine's Avatar
    Join Date
    Sep 2005
    Location
    London, Ontario, Canada, Third Stone from Sun...
    Posts
    358
    I did it this way. No drilling or cutting, just a Radiantz bracket and solder.
    M.
    2004 VTX-C Silver
    Mustang seat, Cobra handrail and rack, Drag Specialties tach, Formotion clock, Madco Cam Lock, Hick Clutch Tension Reducer, some extra bling and of course, the sticker mods.
  16. #15
    Don't cut the brown wire the bike will self destruct if you do, cut the black wire, oh thank god I just saved your life
    06 1300c wanting lots, but can't stop taking stuff of it for now.
  17. #16
    Join Date
    Sep 2005
    Location
    Posts
    358
    Quote Originally Posted by bobby1122
    lol, snip, click, tick, tick, tick.... do you hear that? Is something ticking? What's ticking?
    M.
    2004 VTX-C Silver
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
