Removing Kuryakyn ISO grips
+ Reply to Thread
Results 1 to 6 of 6
Thread: Removing Kuryakyn ISO grips
  1. #1
    Join Date
    Aug 2007
    Location
    Savage, MN
    Posts
    357
    Default Removing Kuryakyn ISO grips
    Is there a safe way to remove a set of Kuryakyn ISO grips, so they can be reinstalled after some other work has been done? the reason I am asking, is that I would like to add a heated grip element to the inside of the handle bars and I need to remove these grips to make this happen.
    Any advice would be great
    Gregg
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Member
    Join Date
    Feb 2008
    Location
    Garland, TX.
    Posts
    58
    Default Re: Removing Kuryakyn ISO grips
    I have found the following method very successful for removing grips without damage.
    1. Remove the left side switch box and lever clamp from the bars. Lay a good thick towel over the tank and set them on
    top.
    2. Now that you have the inside of the grip exposed, use a long thin ice pick and carefully shove it between the grip and
    the bar, now take a can of WD-40 with the little red nozzle and spray down inside the grip. Do this in 5 or 6 locations
    around the grip, then start twisting, it should slide right off.
    3. Now that you've got the hang of it, remove the right side switch box and take the throttle cables lose. Then slide the
    sleeve and grip off as one piece. Take it over to the work bench and repeat the process, be very careful not to break
    the throttle sleeve as it is plastic.
    4. Clean the grips and throttle sleeve with warm water and some good dish soap and they should be good as new.
    Use this method at your own risk. I take no responsibility for any puncture wounds to fingers while using the ice pick!!!!!!!!
    Good luck, and as always your mileage may vary.
    Later,
    MT
    "He who talks the most, does the least."
  4. #3
    Senior Pirate KeyWasted's Avatar
    Join Date
    Jan 2008
    Location
    Key West
    Posts
    6,593
    As an adjunct to MT's method, you may also try using compressed air.
    Remove the cap on the left grip and blow air into the handlebar. The right/throttle grip should bulge and loosen enough to remove. Reinstall the throttle grip, without glue of course, and use the same method to loosen the left grip. Best of luck.
    Nice bike MT.
    2003 VTX1800 ARRRGH
    VTX BEATS HARLEY and Hitler is Pissed!
    http://www.break.com/usercontent/201...wasted-1912477
    Red Knights MC
    "343"
  5. #4
    Join Date
    Nov 2006
    Location
    Ontario, Canada
    Posts
    207
    Default
    Did you actually try this method to remove the ISO grips? Thanks.
    Quote Originally Posted by KeyWasted View Post
    Nice bike MT.
    2007 VTX 1300 R
    Hondaline luggage carrier, grab rails, passenger back rest, windshield, saddle bags, Ultimate low rider seat, passenger seat, rider back rest, passenger back rest, and Rivco passenger floorboards with link arm.
  6. #5
    Sith Lord toasted_3111979's Avatar
    Join Date
    May 2006
    Location
    West Memphis, AR
    Posts
    4,906
    Default
    Quote Originally Posted by Slinkydriver View Post
    That's the way I do it everytime on any bike.
    I do not want to achieve immortality through my work, I want to achieve it through not dying.http://mcdarksiders.forumotion.com/
    05 1300 N, HK 3, CP Punishers, custom paint, full fairing, Michelin HydraEdge 205/65/16, Tsukayu bags
  7. #6
    Join Date
    Nov 2006
    Location
    Ontario, Canada
    Posts
    207
    Default
    Glad to know that it actually works on the ISO grip.
    Slinky
    Quote Originally Posted by toasted_3111979 View Post
    2007 VTX 1300 R
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
