oil in air box
+ Reply to Thread
Results 1 to 3 of 3
Thread: oil in air box
  1. #1
    Junior Member
    Join Date
    Oct 2008
    Location
    Longwood Fl
    Posts
    14
    Default oil in air box
    I went to check and change my stock air filter and noticed a small puddle of oil, do I need to worry about it , I cleaned it out and filter not too dirty but i was going to change it , as my 05 vtx 1300 is at the 12000 mile service.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    58,203
    Default Re: oil in air box
    It is most likely oil&water crud from the crankcase vent and is perfectly normal. You should clean the airbox and the drain tube at least once a year, more so if you ride in cooler temps
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  4. #3
    Junior Member
    Join Date
    Oct 2008
    Location
    Longwood Fl
    Posts
    14
    Quote Originally Posted by rkeene
    thanks for the info
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
