1300 Carburator: Scar Mod, A/F Mix&Idle Adj, Fuel Pump bypass
+ Reply to Thread
Results 1 to 17 of 17
Thread: 1300 Carburator: Scar Mod, A/F Mix&Idle Adj, Fuel Pump bypass
  1. #1
    Old Goat TennX's Avatar
    Join Date
    Jul 2006
    Location
    Memphis,Tn.
    Posts
    21,725
    Default 1300 Carburator: Scar Mod, A/F Mix&Idle Adj, Fuel Pump bypass
    Scar method with pics
    Here is a photo version of the "Scar" method:
    Originally Posted by Scar
    You may have just purchased a new exhaust and/or air intake and are wondering how you should "tune" the carburetor. First off if you just "fire the bike up" with the new parts installed, THE BIKE WILL RUN. Depending on how "free flowing" the aftermarket parts are that you installed the bike will run anywhere from "pretty good" to "pretty lean and very nervous", but it will run. So now the bike has to be TUNED. The easiest, least expensive, quickest, most predictable and fool proof method of rapidly tuning it would be to ADJUST the stock parts that are already in the carb. Some people venturing into the "mods" game want to do them all at the same time... this has OFTEN been proven to cause problems for the neuvo MC "wrench". DO NOT remove the PAIR system during the same session that you are tuning the carb.
    , it is common while working with the PAIR removal to "miss" something in the process and have an open vacuum line or "other" air leak. Many who have done both of these mods simultaneously have ended up fiddling with their carb for days/weeks on end chasing their tails looking for what went wrong with the carb tuning while all the time it was an error in the PAIR system removal. There have been some war stories spread about how difficult it is to tune a carburetor.. bull hocky! The most difficult part of tuning a carb on a VTX 1300 is removing the fuel tank for the first time and figuring out how to dissconnect the electrical connectors under the tank.
    So, what comes first eh? REMOVE THE FUEL TANK. Follow the directions in the service manual.. everyone should have a service manual.. the money you save in THIS carb tuning process alone will pay for a service manual. The money you save doing your first valve adjust using the service manual would buy a nice set of tools that can be used in OTHER money savings projects... EVERYONE needs a service manual..
    Next REMOVE the air filter and backing plate. I won't "get into" hooking and unhooking the hoses attached behind the backing plate, they are pretty straight forward and will become part of your "learning process" of the easiest ways to rapidly navigate through assembly/disassembly.
    NOW the carburetor is EXPOSED.
    Sitting on top of the carb you will see the vacuum chamber cover.
    Remove the cover and then remove the compression spring under the cover.
    Now gently grab the diaphram/piston rubber and pull it out.. the Vacuum piston (slider piston is what most old timers call it) is attached to the diaphram and the whole package will come out with it.
    YOU ARE ALMOST DONE AND READY TO PUT THINGS BACK TOGETHER.. see, I told you.. removing the tank was the most difficult part of the process... unscrewing the 4 vacuum chamber cover screws was no big deal, right?
    Look at the slider piston and you will see a tappered "needle" sticking out the bottom of it, that is the jet needle.
    Look inside the slider piston and you will see the Jet needle holder.
    The jet needle holder is next to be removed.. you will see in the center of the holder it will accept a Phillips head screwdriver which can be used to "unscrew" the cam locks, BUT the "best" method is to use a small socket and fit over the head of the "cap" and unscrew the cap... I'm thinking it's an 8mm.. difficult to recall those things sometimes at my age, but you'll discover the correct size. Twist the cap counter clockwise just as tho you were unscrewing any "standard" nut or bolt and you will feel a "pop" after making a very small motion.. that was the cams unlocking.. the cap can now be removed, it is "unlocked".
    Under the needle holder cap there is a small spring "screwed" onto a plastic "tit" protruding from the bottom of the cap... well actually the "tit" has no threads, so the spring is not "screwed" on, but consider it so... instead of "pulling" the spring off and distorting it's shape, give a "light force" pull on the spring while unscrewing it from the "tit" and set the spring aside. The "tit" does not protrude very far, but it must be "trimmed" for "heavy breather" mods, so go ahead and trim it now even if you are doing a "light breather" tune... Take some TOENAIL clippers (those are the large ones, not to be confused with fingernail clippers) and "snip" the "tit" in half.. that should be enough for heightened needle raising and still provides enough remaining "tit" for the small spring to be screwed back onto... set the needle holder cap aside.
    Remove the needle from the slider piston.. place your shims into the needle "point" and make sure they slide all the way to the needle head with the washer/shim hole big enough so free movement along the needle is achieved. Hold the slider piston in your left hand and turn it at an upwards angle and insert the needle INTO the slider piston hole, passing through the CENTER hole in the slider piston (this process will not work for "left handers", you will have to purchase a Yamaha carburetor). Face the slider piston DOWN and the needle should be hanging from the bottom of the slider piston and sitting "on" the shims/washers INSIDE the piston.
    Take the SMALL spring that was unscrewed from the underside of the needle holder cap and screw it back onto the shortened "tit" under the needle holder. Put the needle holder cap into the slider piston with the small needle spring tensioner sitting on top of the needle head. (If the 8mm socket is placed onto the top of the needle holder cap "nut" the tension is enough to hold the cap.. the needle cap holder can be easily inserted into the slider piston with this method utilizing a socket extender). Twist the needle holder cap clockwise (even the left handers) as tho "tightening" and you will feel the cams lock into place... that's it, the needle holder is locked. If enough of the "tit" was trimed, this should be a relatively easy "twist"... Hold the slider piston with one hand and "wiggle" the needle with the fingers on the other hand... the needle should "wiggle" (movement), this assures true alignment into the emulsion tube . If the needle is "stiff" and won't "wiggle", then the "tit" was not trimed enough ... go back and trim more from the tit until free needle movement is achieved. (If you are using a DJ needle, the tit must also be trimmed for the same reasons)
    Replace the diaphram spring onto the needle holder cap and replace the vacuum chamber cover.. NOTE: There is an irregular "shape" in the cap that must be matched to it's mating surface when remounting, this is what the manual calls the "tab and air passages"... "Snug" the vacuum cap screws and continue reassembly.
    Under the carb is the A/F screw (see manual), the stock screw head requires a "D" type tool for adjustment. If you slightly dent the end of an empty .22 shell casing, this will fit into the hole and can be used to unscrew the "D" screw. Take the "D" screw completely OUT. On the top of the "D" screw head will be a spring followed by a washer and then an "O" ring.. save these parts and reasemble in the same order when putting the A/F screw back in.
    While the A/F screw is OUT, use a hacksaw blade or some simular device to cut a thin channel into the head of the top of the "D" screw.. this slot or channel should be wide enough for a flathead screwdriver blade to fit into for A/F adjustment. Once the slot has be cut into the screw/needle head and the screwdriver blade fits, replace the spring/washer and "O" ring and replace the A/F needle into the needle jet hole and screw IN. Take your screw driver and screw in the needle until it LIGHTLY seats or stops turning ... don't get anal about this and over tighten or damage could be caused to the needle/jet mating surfaces . If you error on "seating", error on the LOOSE side, final tuning will not be affected by a minute discrepancy of "seating" at this stage of tuning. Turn the A/F screw OUT 2 1/2 turns with the screwdriver.
    Reassemble the airbox and fuel tank.
    Before firing the engine, look at the CHOKE KNOB and push it in all the way... any flexing of the carb while working on it will flex the choke cable and pull the choke out... it will not run properly with the choke pulled out AT ALL and final tuning cannot be achieved.
    Shim heights:
    "Open" style airbox and aftermarket "free flow" pipes... usually about 2or 3 shims.
    Airbox flowing more air than stock design, but not in the "heavy breathing" class and/or pipes either free flow or somewhat restricted... usually about 1or 2 shims
    Stock airbox (K&N filter in stock box is still "stock") and after market pipes... usually 0 or 1 shims
    Stock airbox and stock pipes... tune the A/F screw for maximum performance...
    A/F settings:
    While determining proper main jet circuit settings the A/F screw should be set at 2 1/2 turns and NO adjustments made to it until the high speed circuit has been properly tuned -- Turning the screw IN leans the mixture... turning the screw OUT richens the mixture -- Fine tuning the A/F screw should be done in no more than 1/8 turn increments... very fine tuning will be even less... it is highly recommended to "slot" the "D" screw and tune the A/F screw with a screw driver... a 90 degree drive is useful if you have one... improvise.
    SLIDER PISTON SPRING:
    That's what I call the big spring directly under the vacuum cap and sitting on the needle holder cap. -- Most tuners that have springs of the type found in the VTX carb shorten the spring for faster throttle response... this is not necessary for the bike to operate, but you will shorten the response time if you shorten it... I would not recommend shortening it past 5 1/16"... that is the lenght of the shorter DJ kit supplied spring and is a proven entity... The Keihin spring is of slightly larger diameter wire so a "safe" fudge factor is built in if you cut it to 5 1/16", most do... you can cut it less than that if you are nervous, but you shouldn't have any problems with 5 1/16"... place the cut end DOWN into the slider piston and resting on the needle cap... uncut end UP against the vacuum cover.. that is the "common" practice (and no bannanas on boats either).
    Most any needle design or jet design will work with the Keihin carb as long as they are set to the proper height and have the correct diameter... It has been my findings that the stock Keihin needle and jet work more "smoothly" if properly shimmed than some other designs because of the needle design and large diameter jet size... The Keihin design is just more forgiving and not as "touchy" as some other designs and need I say you are not required to remove the float bowl cover to change main jet sizes?... The Keihin 195 main jet suits most all purposes... if you require more than that you are past the "beginning" tuner stages and in that case you might think about a Keihin 200 or 205 (DJ equivalents of 213 and 21... I don't think more than a 205(/21 would be required by anyone unless cam, piston, valve and porting changes have been made... in which case I would like to communicate with you on your engine mods and findings... you most likely won't require any "advice", but I would like to hear about extensive engine mods... mine will retain the stock configuration... I have a 1200cc street fighter for speed.
    Have fun and if I am "not around" to answer any possible questions (I have a somewhat irregular schedule at times), I would recommend asking Retro Rich.. He has a mechanical mind and a healthy grasp on the tuning philosophy.
    Radio Shack Shims:
    Radio Shack Part # 64-3022
    Package of 100
    Steel Flat Washers
    20 each: #2, #4, #6, #8, #10
    They are in the Hardware section of the store -- In the plastic pull out trays that are divided into sections.. Plastic bag... Looking at the bag I would say we are using the #4 washers.. anyway it is the second from the smallest... we "miched" em several years ago and can't recall, they are like 0.019 or 0.020 or pretty close to that neighborhood.. they work! -- Oh yea, they now cost $1.99/pkg -- inflation.
    Any "washer/shim" of similar thickness (0.020") with a hole big enough for the needle to comfortably slide through and small enough for the needle head to sit on will work just fine.
    I could write another entire page on "tuning techiques", but it has already been done in what I consider a comprehensive and accurate manner... use it as your tuning Bible -- Factory Pro http://www.factorypro.com/tech/carbtun.html
    Don -- AKA "Scars"
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    59,157
    Default Idle Circuit A-F Mixture and Idle Speed Adjustment
    Idle circuit A-F mixture and idle speed adjustment, by Joe Licketto
    To get the most accurate setting for idle speed mixture, you will need two (2) tools - a good vacuum gauge (similar to one part of a carb sync gauge set, or even a cheap old automotive vacuum gauge with a dampener to avoid too much fluctuation) and a (inductive) tachometer that attaches to a spark plug lead.
    Warm your bike up to operating temperature, about a 5 minute ride should do.
    - Attach your vacuum gauge to a "T"-fitting coming off the intake manifold between the carb and the cylinder head, maybe where your PAIR valve connects or connected to.
    - Pick any spark plug wire and hook up your inductive tachometer.
    - Start the bike and set the idle speed screw so the RPMs are 850-950.
    - Begin by adjusting your A/F mixture screw in (leaner) until the RPM drops noticeably - you will note that the vacuum gauge drops its reading and becomes erratic, but the engine still runs.
    - Bring your idle speed back up to proper range with the idle speed screw.
    - Now adjust our A/F screw out (richer) in ľ turn increments until you obtain the highest possible vacuum reading. Hopefully this will also be your highest RPM as well.
    - Back the RPM down to proper range with the idle speed screw, again.
    - Try ľ turn in (leaner) and see if your vacuum and RPM drops. Continue turning it in using ľ turns until the vacuum does drop off of its highest reading after setting the idle speed in the step just above.
    - When the vacuum does drop, go back out (richer) the last ľ turn.
    Your idle mixture should now be correctly set. Remember, it's ONLY the idle circuit and possibly the first 1/8 throttle off-idle that you are affecting. This will also include when allowing the throttle to snap shut on deceleration. Any throttle position other than idle, should NOT be affected by this adjustment procedure.
    You may need to apply a mild amount of choke (enrichener) in cool/colder weather so that the engine stays running at a high enough idle speed so as not to stall out for the first few minutes. After that, push the choke all the way in and ride on.
    __________________
    Author; Joe Licketto
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  4. #3
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    59,157
    Default pepsX's fuel pump removal
    PepsX's Fuel Pump Removal
    Don't bother replacing a faulty fuel pump (the '03 model VTX1300 had a fuel pump)
    Simply use the pet**** and fuel line from the newer models. In a pinch (if you're stranded on the road) - you may simply run a fuel line directly from your existing pet**** to the carb....bypassing the pump completely.
    pepsX wrote:
    I just got my bike back on the road after removing a faulty fuel pump.
    the sysmpton was: bike just died while riding, let it sit for 10-15 minutes, and it started and ran for 10 minutes, then died again. it acts just like it runs out of gas (it actually does).
    after removing the fuel pump, i placed the pickup tube in a can of gas, applied 12v to it and it ran fine for a few minutes, then you can hear it pumpling slower and slower until it dies after about 2 minutes. disconnect the 12v and let it sit for a few minutes and re-apply 12v and it does the same thing.
    here is what i did to replace it.
    buy a newer model pet**** and fuel line. remove early 03 pet**** from tank and put in the new one, run the new short fuel line to the carb, tap into a vacume line (the new pet**** has a vacume shut off safety line).
    i removed the old fuel pump by taking the seat off, taking out the battery, removing the battery box (a bitch), and removing the fuel pump. then put it all back together without the fuel pump.
    use this thread for pic and part number to replace parts.
    http://www.vtxoa.com/forums/viewtopic.php?t=170132&highlight=
    thanks LozTX.
    this is the third 03 I know that the fuel pump has died.
    here is a pic of the battey box and fuel pump and hoses.
    it cost me about $135.00 for the pet**** and fuel line. a new pump cost over $400.00
    hope this helps someone in the future.
    Last update: 2006-11-26 18:52
    Author: Ceetro
    2002 VTX1800 C
  5. #4
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    59,157
    Default Removing A-F "D" screw by AZVTXtra
    I purchased CyberHick's A/F screw, as I see the value in not having to make adjustments using a .22 shell bent to the "D" shape, nor was I willing to buy the tool from Honda for some $92. Because I was ready to embark on the change of the airbox, it seemed the right time to do it.
    But I had on heck of a time with the .22 shell trying to get the screw out. To start, it is in a heck of a hidden place under the carb to the back, inside a collar. You can't see it without a mirror, so it's mostly by feel. No room for two hands, so it's a two finger balancing act. And there's hoses in the way, so nothing is simple. I kept thinking I "had it" and was turning and turning and turning. Then I'd discover (using the mirror) I had barely moved it. To get it out, you are turning it clock-wise (as viewed from the top of the bike).
    This is the little jewel I was after:
    Well my .22 shell was getting beaten to heck and I got tired of re-bending the "D" shape to try to to make it "catch". So I started looking in the parts drawers, and stumbled upon an electrical crimp "bullet" connector. The blue plastic part was almost exactly the size I needed.
    By "force fit" while still in the carberator, it "grabbed", and spinning it out was easy from there.
    Hopefully my experience will save some of you a couple of frustrating hours.
    So I didn't use a .22 cartridge, I used an electrical "bullet connector" ... seems like will still stayed in the firearms arena.
    Last update: 2007-04-01 18:50
    Author: Ceetro
    2002 VTX1800 C
  6. #5
    Senior Member PapiRauk's Avatar
    Join Date
    Feb 2009
    Location
    Stockholm, Sweden
    Posts
    121
    Default
    If I may, I'd like to add some additional info to the SCAR mod fŲr those of you living in metric countries.
    The width of the needle at the top, just under the hat is just below 3mm. The hat itself is about 6mm.
    An M3 shim worked perfectly for me and I estimate it's thickness to the same as SCAR posted above.
    Hope this helpes someone
    Love people like you never been hurt, and hurt people like you never been loved.
    VTX 1300S -06, Accutronix forward controls, Deep Clayton mod, Spyker mod, PAIR mod, SCAR mod, Cycle grafix, 16" Apes, skull mirrors, usb-output.
  7. #6
    Join Date
    Jul 2009
    Location
    Proctor, WV westpennsyltucky
    Posts
    6,154
    Default Factory Pro Jet Kit
    Factory Pro jet kit install
    This write up is for installing a Factory Pro jet kit in VTX 1300. Portions of this write up are from Scar mod write up Buy TennX. Those Portions will be quoted to Tennx and Scar.
    the factory pro jet kit contains
    1. Factory pro needle
    2. 5 E-clips
    3. Main Jets 225, 220, 215, 210
    4. 58 slow jet
    5. replacement socket cap screws for the float bowl
    6. d shape tool for adjusting A/F or pilot screw
    7. documentation
    First remove the seats, gas tank and breather housing
    Quote taken from Scar mod post By TennX
    Under the needle holder cap there is a small spring "screwed" onto a plastic "tit" protruding from the bottom of the cap... well actually the "tit" has no threads, so the spring is not "screwed" on, but consider it so... instead of "pulling" the spring off and distorting it's shape, give a "light force" pull on the spring while unscrewing it from the "tit" and set the spring aside. Take some TOENAIL clippers (those are the large ones, not to be confused with fingernail clippers) and "snip" the "tit" in half.. that should be enough for the factory pro needle and still provides enough remaining "tit" for the small spring to be screwed back onto... set the needle holder cap aside.
    Remove the needle from the slide. Take the Factory Pro needle out of the kit and install the clip in the 4th slot down from the top of the needle. Factory Pro recommends the fourth slot for a start point. The top of the needle is the end of the needle that has the slots for the clip. Position one is the slot at the end of the needle. Position 5 is in the middle before the taper starts. Ensure the e-clip is in the slot properly. The back side of the clip has a tab on it. This tab must be in the slot on the needle. If it is not the needle will not sit in slide properly it will lean to one side. Put the needle into the slide. This a picture of the Factory Pro needle with the E-lip on the fifth position.
    Take the SMALL spring that was unscrewed from the underside of the needle holder cap and screw it back onto the shortened "tit" under the needle holder. Put the needle holder cap into the slider piston with the small needle spring tensioner sitting on top of the needle head. (If the 8mm socket is placed onto the top of the needle holder cap "nut" the tension is enough to hold the cap.. the needle cap holder can be easily inserted into the slider piston with this method utilizing a socket extender). Twist the needle holder cap clockwise as tho "tightening" and you will feel the cams lock into place... that's it, the needle holder is locked. If enough of the "tit" was trimed, this should be a relatively easy "twist"... Hold the slider piston with one hand and "wiggle" the needle with the fingers on the other hand... the needle should "wiggle" (movement), this assures true alignment into the emulsion tube
    . If the needle is "stiff" and won't "wiggle", then the "tit" was not trimmed enough ... go back and trim more from the tit until free needle movement is achieved.
    Replace the slide diaphragm assembly. When replacing the diaphragm and slide carefully push the diaphragm towards the needle so that the diaphragm is pointing down towards the needle.
    This will make it easier to install the diaphragm gasket into the groove in the carb.
    Install the spring into the slide. If cut the slide spring (not needed with Factory Pro Kit but some will cut it for different tuning) Make sur the cut end is down inside the slide. Install the vacuum chamber cover.. NOTE: There is an irregular "shape" in the cap that must be matched to it's mating surface when remounting, this is what the manual calls the "tab and air passages"... "Snug" the vacuum cap screws and continue reassembly.
    Loosen the clamp on the carb side of the intake manifold. An extra long screwdriver works well on the clamp. losen the choke knob from the bracket and lift the choke knob from the bracket. Pull the carb out of the manifold boot and let it hang. Remove the accelerator pump linkage be careful not to loose any of the small parts of the linkage. After the linkage is removed put the screw and washers and spacers back into the hole and screw them in a little so you donít loose the parts. Loosen the screw facing sideways on the bottom of the bowl. Put a rag under it this will drain the gas out of the bowl. Tilt the carb out and remove the float bowl screws. Push on the screw driver with strong force. The screws strip very easily. If the screw head strips use small pair of locking pliers to remove the screw. Remove the float bowl carefully so you donít damage the floats. Clean the bowl if there is any residue in it. Use a flat tip screwdriver and remove the main jet from the Jet holder. Put in the recommended main jet for your intake setup. The recommended jet size is on the sheet that came in the kit. This jet is a start point it may not be the correct one for your bike but thatís part of rejetting (trial and discovery). Use a Flat head screw driver and remove the slow jet. Install the #58 slow jet from the factory pro kit. Again this may not be the correct jet but itís a start point. Reassemble carb and accelerator pump linkage.
    Under the carb is the A/F screw (see manual).
    If The long boy screw or Glens A/F screw is used remove the A/F screw and replace it. If the stock screw is used use the D-head tool in the jet kit screw in the needle until it LIGHTLY seats or stops turning ... don't get anal about this and over tighten or damage could be caused to the needle/jet mating surfaces . If you error on "seating", error on the LOOSE side, final tuning will not be affected by a minute discrepancy of "seating" at this stage of tuning. Turn the A/F screw OUT 2 turns.
    Push the carb back into the manifold boot. Note the tab on the back of the carb were it goes into the manifold boot. There is a slot in the manifold boot that this tab goes into. After carb seats into manifold tighten manifold clamp. while tightening the clamp reach under the carb and feel the clamp and make sure the bottom of the clamp is in the proper location on the bot. sometime the clamp will tilt to one side.
    Reassemble the airbox and fuel tank and seats. remount the choke in its mount
    On initial start do not use the choke youíll have trouble starting it
    Attached Images Attached Images
    "Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one." Thomas Paine
    Where is our government!
  8. #7
    Join Date
    Jul 2009
    Location
    Posts
    6,154
    Default
  9. #8
    Senior Member JOSHWALEE's Avatar
    Join Date
    Feb 2010
    Location
    MT. SERBAL
    Posts
    2,901
    Default Jet conversion chart
    I thought this might help some people. There's a lot of question about what equals what when it comes to jets. Stock Keihen and Factory Pro jets are measured numerically in 2.5 increments, while DJ jets are measured by diameter, and Mikuni is measured by flow rate (we don't use these). FYI, If you have Cobra or Thunder kits they are using DJ jets. The DJ jets flow at a different curve due to beveled edges. In reality there is no direct comparison between any of these jets due to design differences.
    We are often asked for a "cross reference" sheet that compares our main jets to Mikuni or Keihin. The fact is you cannot directly interchange the jets for a given size. Many things affect fuel flow through a jet of the same orifice size. The entry and exit tapers of our main jets differ from those of other companies. Due to this, the fuel flow changes as a function of velocity through the carburetor venture. This means that two jets of equal orifice size will have a different fuel flow curve relative to intake air speed. At a certain speed the two may flow equally, but a change in velocity changes the flow characteristics. The Dynojet main jet hole size is measured in millimeters. For example, a DJ142 has a 1.42mm hole.
    Michael Cory
    Research & Development
    Phone: 800-992-4993 EXT. xxx
    Michael@Dynojet.com
    Due to these differences it is not advised to run DJ needles with stock or FP jets and vise-versa. They are not designed to work with each other.
    Although there is no direct conversion, these are the diameter measurements for each manufacturer. They will at least get you in the ballpark, but fine tuning will get you the rest of the way there!
    So here is a chart to help everyone out(Stock jet for 03-07 is labeled in RED, 08-09 is labeled in GREEN.):
    Width------Kehein (FP)# -- DynoJets # -- Mikuni #
    0,0350---- 92,5--------- 92----------- 86,3
    0,0360---- 95----------- 94----------- 88,1
    0,0370---- 97,5--------- 96----------- 90,0
    0,0380---- 100---------- 98----------- 91,9
    0,0390---- 102,5------- 100---------- 93,8
    0,0400---- 105--------- 102---------- 95,6
    0,0410---- 107,5------- 104---------- 97,5
    0,0420---- 110--------- 106---------- 99,4
    0,0430---- 112,5------- 108--------- 101,3
    0,0440---- 115--------- 110--------- 103,1
    0,0450---- 117,5------- 112--------- 105,0
    0,0460---- 120--------- 114--------- 106,9
    0,0470---- 122,5------- 116--------- 108,8
    0,0480---- 125--------- 118--------- 110,6
    0,0490---- 127,5------- 120--------- 112,5
    0,0500---- 130--------- 122--------- 114,4
    0,0510---- 132,5------- 124--------- 116,3
    0,0520---- 135--------- 126--------- 118,1
    0,0530---- 137,5------- 128--------- 120,0
    0,0540---- 140--------- 130--------- 121,9
    0,0550---- 142,5------- 132--------- 123,8
    0,0560---- 145--------- 134--------- 125,6
    0,0570---- 147,5------- 136--------- 127,5
    0,0580---- 150--------- 138--------- 129,4
    0,0590---- 152,5------- 140--------- 131,3
    0,0600---- 155--------- 142--------- 133,1
    0,0610---- 157,5------- 144--------- 135,0
    0,0620---- 160--------- 146--------- 136,9
    0,0630---- 162,5------- 148--------- 138,8
    0,0640---- 165--------- 150--------- 140,6
    0,0650---- 167,5------- 152--------- 142,5
    0,0660---- 170--------- 154--------- 144,4
    0,0670---- 172,5------- 156--------- 146,3
    0,0680---- 175--------- 158--------- 148,1
    0,0690---- 177,5------- 160--------- 150,0
    0,0700---- 180--------- 162--------- 151,9
    0,0710---- 182,5------- 164--------- 153,8
    0,0720---- 185--------- 166--------- 155,6
    0,0730---- 187,5------- 168--------- 157,5
    0,0740---- 190--------- 170--------- 159,4
    0,0750---- 192,5------- 172--------- 161,3
    0,0760---- 195--------- 174--------- 163,1
    0,0770---- 197,5------- 176--------- 165,0
    0,0780---- 200--------- 178--------- 166,9
    0,0790---- 202,5------- 180--------- 168,8
    0,0800---- 205--------- 182--------- 170,6
    0,0810---- 207,5------- 184--------- 172,5
    0,0820---- 210--------- 186--------- 174,4
    0,0830---- 212,5------- 188--------- 176,3
    0,0840---- 215--------- 190--------- 178,1
    0,0850---- 217,5------- 192--------- 180,0
    0,0860---- 220--------- 194--------- 181,9
    0,0870---- 222,5------- 196--------- 183,7
    0,0880---- 225--------- 198--------- 185,6
    0,0890---- 227,5------- 200--------- 187,5
    entia non sunt multiplicanda praeter necessitatem
    support your
    LOCAL 81
  10. #9
    Join Date
    Feb 2010
    Location
    MT. SERBAL
    Posts
    2,901
    Default Refer to this before you even think about opening your carburetor!!
    There are so many questions on here about tuning, and not too many riders seem to understand exactly what they are adjusting. The following information is the BEST explanation of CV Carburetor operation I have found. The Keihen CVK40 is a Vulcan carburetor, but is basically identical in design to the VTX's 38mm. Please, review the following info for a more thorough understanding of your bike's fuel system. I have edited a portion which talked about special pilot adjustment tools, but Glen's VTX Garage can supply the proper tools. I really think this can help a lot of members!
    **The following is from http://www.gadgetjq.com/keihin_carb.htm**
    Keihin CVK40
    The Care & Feeding Of Your Vulcan Carb
    Originally posted by Redondo Ron on a now defunct AOL website in 1998. The pictures and text are all his. Many thanks.
    Part I - How It Works
    THE BASICS - Mixing and Delivering
    While most of the following information applies to all CV carbs, and to some extent all carb types, this article is specific to the Keihin CVK40 found on many Kawasaki motorcycles (KLR's and Vulcans) along with some Harleys. If you need replacement parts you'd be well advised to get them from your local Harley Davidson outlet. They will be less expensive than ordering through your Kawasaki dealer and, in most cases they will be 'in stock'.
    The CVK40 is technically a bleed type carb, with a variable venturi that's controlled by constant velocity (CV). It's also known as Constant Depression or Constant Vacuum. The 40 in the name represents a 40 mm venturi exit diameter. Wonder why 'K'awasaki added the K...?
    BLEED TYPE CARBS - Let it Bleed
    Most carbs have a one piece needle jet. On the CVK40 it consists of a collar and what Kawasaki calls a holder. Most 4-strokes have pin holes along the length of this brass jet. These pin holes allow air from the air jet to premix with fuel from the fuel jet to start the mixture emulsification process before it enters the venturi. Primary type carbs use a solid jet, (no pin holes).
    VARIABLE VENTURI - Getting Sucked In
    A venturi is a tube with a convex taper, (one end wider than the other). As air enters the wider end it's squeezed into the narrower section of the tube, lowering the air's pressure. The area of lowest pressure is just past the narrowest point and is called the depression. This has always seemed counterintuitive to me, but Bernoulli's Principle outlines the fluid dynamics involved in this effect. This lowered pressure, or comparative vacuum is separate from the engine vacuum. A variable venturi varies the venturi diameter at the depression
    by raising or lowering an obstruction. This obstruction is called a slide. On a CV the slide
    is called a piston or diaphragm valve.
    CV or SLIDE CARB - The Great Compromise
    Both the CV and conventional slide carbs are classified as variable venturi carbs. The slide on a conventional carb is directly connected to the throttle cable. Twist the throttle grip and the slide is raised in the venturi. On a CV carb the throttle cable is connected to a butterfly valve that varies the volume through the venturi. It's not the throttle, it's the pressure difference from the venturi to the outside atmosphere that moves the slide.
    So which type is better? That depends on what you want to do. The manufacturers will tell you the CV is the next best thing to electronic fuel injection. It does feed a precise amount of mixture to smooth out throttle response, reduce pollution, and stretch your fuel budget and gas tank range.
    This is great for tarmac cruising and feeling warm and fuzzy about doing your part to reduce global warming while pocketing some spare change. It sure makes it easier for the manufacturers to get the EPA approval stamp on the bike.
    But what if you feel that no matter how much you hop up your little beast, you're never going to match the belching of that cager in the gas guzzling V-12 ? What if you don't mind spending more for gas, and when you go off-road you want a burst of power to blip over obstacles or steer through a wash without fanning your clutch while waiting for the vacuum to build in the venturi? If you can discipline yourself to control the throttle so that you don't bog your engine, then you want a conventional slide carb.
    40 MM -Size Matters
    With the same engine and carb design,
    a 38mm diameter venturi will more
    accurately meter the mixture on the low
    end, while a 41mm diameter will do a
    better job of supplying mixture at higher
    engine speeds. It's another factor to
    consider if you replace your carb.
    MIXING AIR AND FUEL - All In the Pressure
    It all starts in your engine. Think of your thumper as a big pump,
    happily sucking and blowing down the road. During the intake stroke
    the engine's piston descends in the cylinder. This creates a void that
    sucks in whatever is on the other side of the open engine intake valves.
    Unless the engine intake valves are open, the carb is not being sucked
    on by the engine. This vacuum action powers the carb.
    Look at the 4-cycles of our 4-stroke thumperpumper.
    1) Intake - piston pulls down sucking mixture in.
    Intake valves open, exhaust closed.
    2) Compression - piston goes up.
    Intake and exhaust valves closed.
    3) Ignition/Power - piston forced down.
    4) Exhaust - piston goes up blowing out burned gas.
    Exhaust valves open, intake closed.
    Each time the piston goes up and down, (two of the four strokes), one revolution has occurred. It takes two revolutions to complete the four strokes, or one-half of a revolution to complete one of the four strokes. At redline, your engine is sucking on the carb at a rate of over 60 times per second. At idle it's around 11 times a second. The math below shows that with a 651cc displacement, a theoretical maximum of between 7 and 40 liters of mixture are sucked in each second.
    7500 .......(engine RPM)
    / 2 ...........(2 revs per intake stroke)
    = 3750 .....(intake strokes per minute)
    / 60 .........(seconds per minute)
    = 62 ........(intake strokes per second)
    x .651 ......(engine displacement in liters)
    = 40.69 ....(liters per second)
    These numbers assume 100% efficiency. Mister_T calculates about
    38% efficiency at idle. So these numbers are only to illustrate
    the relative difference in volume from idle to redline.
    Remember Bernoulli's effect in the venturi? Sitting below the venturi is
    the fuel float chamber which is vented to the outside of the carb to match
    atmospheric air pressure. The fuel in the float bowl is also 'vented' to the
    low pressure of the venturi through the starter, pilot and main fuel jets.
    So you can think of the float chamber as being pressurized in comparison
    to the partial vacuum of the venturi. The fuel naturally tries to fill in the
    low pressure of the venturi's depression by injecting itself through one,
    or a combination of the three fuel jets.
    THE ODDS - Skinny or Fat
    Any carb problem boils down to either it's too rich, (too much fuel or too little air), or it's too lean, (too much air or too little fuel). The 'mixture', (a mixture of fuel and air, your engine's 'food'), is theoretically ideal at around 15 parts of air to one part of gasoline
    by weight, (not volume). The outer limits are 12:1
    and 18:1 .
    Too rich and you're wasting fuel, spewing more pollutants, diluting your oil, fouling engine parts, and performance suffers. Too lean and you run the risk of detonation, engine operating at higher temperatures, and performance suffers.
    An air-cooled engine needs to run richer (more fuel)
    to aid in engine cooling. This is another plus of our water-cooled system to balance out it's disadvantages.
    PARTS - Is Parts
    Supplementing the factory manuals, the following text and photos should make it easier to understand how the carb works. The parts are broken into the following groups:
    FLOAT SYSTEM - You're Floating In It
    The float system acts as a fuel reservoir to meet engine
    demand. The float is hinged on a pin in the float boss. It
    rises and falls with the fuel level in the float bowl. The small
    metal tang integrated in the plastic float supports the float
    valve, aka float needle. As the fuel in the float bowl rises,
    the float valve is pushed into the valve seat, until it's high
    enough to shut off the fuel flow to the bowl. The level in
    the bowl drops lowering the float which pulls the float
    valve from it's seat, and fills again.
    STARTER ENRICHER - KLR Morning Coffee
    This system is referred to as the
    choke. But that's a misnomer. When
    you apply the choke lever, what
    you're doing is retracting a plunger
    that opens a tube connected to the
    starter jet, allowing additional fuel
    to enter the venturi just below the
    vacuum hose nipple. It supplements
    the pilot system at start up.
    PILOT SYSTEM - Steering You to Better Lows
    The primary purpose of the pilot system is to supply the mixture at idle. It continues to supply fuel throughout the entire throttle range, but after about 1/8 throttle is reached the MAIN SYSTEM starts to put out an increasing percentage of the total mixture up to full throttle.
    When you set the idle with that big screw on the right side of the carb, what you're doing is covering or uncovering one or more of the four small holes that are drilled into the venturi, (leading to the pilot jet) just under the butterfly valve, and letting more or less air pass the butterfly. When you adjust the pilot screw that's under the carb, you are varying the amount of air premixing with the gas before it enters the venturi.
    MAIN SYSTEM - The Meat
    As you advance the throttle cable that's connected to the butterfly valve, the butterfly opens to allow more air through the venturi. This increases the vacuum effect that
    is transferred up
    through the vacuum
    drilling (the hole you
    bored out for the
    Dynojet kit), on the diaphragm valve (slide), that leads
    to the TOP diaphragm chamber.
    The top chamber is separated from the BOTTOM chamber
    by the rubber diaphragm. The bottom chamber is open to
    atmospheric pressure from the airbox by the crescent shaped
    casting on the top of the venturi. When the vacuum in the top
    chamber rises sufficiently, the constant ambient pressure
    of the lower chamber, helps the diaphragm valve overcome
    the downward force of the diaphragm spring, and it rises
    from the venturi.
    As the diaphragm valve is raised from the venturi
    depression (lowest pressure area), the needle is pulled
    further out of the needle jet, exposing a thinner portion
    of the needle taper which allows even more fuel to rise
    into the venturi to meet the increased engine demand.
    COASTING ENRICHER - Feeding a Closed Mouth
    You're blasting down the trail and you see a
    hairpin coming up, so you close the throttle.
    This closes the butterfly valve. You and your
    400lb baby (the bike, not the other love of
    your life), are still rolling with inertia, keeping
    the engine revs high. Now it can't get the
    mixture it's trying to suck in because the
    butterfly valve is closed, blocking the air flow.
    To compensate for this there's an air jet in the lower
    diaphragm chamber that transfers ambient pressure to
    one side of the coasting enricher's spring loaded cut off
    valve. The excess vacuum in front of the butterfly valve
    is transferred to a drilling that leads to the other side of
    the cut off valve. This sucks it open, allowing the pilot
    jet to feed more fuel to the engine preventing an overly
    lean condition. (Pop. Pop. Pop.)
    Redondo Ron
    12/98
    support your
    LOCAL 81
  11. #10
    Senior Member Gonzo1970's Avatar
    Join Date
    Oct 2009
    Location
    Belleville, IL
    Posts
    1,478
    Default
    The "turns out" on the A/F are directly related to the Needle's Shim and the Pilot Jet.. The needle's clip position to a lesser extent, but still would need fine tuning if you move it.
    Factory Carb with SCAR Mod should be 2 1/4 to 2 1/2 turns out from lightly seated.
    Factory Pro Stage 3 58 Pilot (factory is 55) you can take about 1 turn off of that.
    Im 4th clip position, 58 pilot and it seems to like 1 to 1 1/4 turns out from lightly seated.
    -Gonz
    Harley Owners Need Dependable Alternatives
    "Dear Fox News: I am writing today to request that you add a laugh track to your coverage to properly identify it for the comedy that it is.
    Also, clown noses for the reporters would be nice."
  12. #11
    Junior Member
    Join Date
    May 2011
    Location
    katy, texas
    Posts
    1
    Default Thanks!!!
    I just wanted to thank you for posting the Scar Mod info. I have a 2006 Honda VTX 1300s with 26000 miles on it. Shortly after buying the bike (brand new) I put some Cobra slip-on exhaust on. Everyone told me I would have to do a jet kit inorder for the bike to run correctly. Well almost 25000 miles later it started loosing power so I tryed A Dynojet kit and after 3 days of frustration because no mater what Dynojet or Cobra told me what I needed to do nothing worked. Then I found your post and went back to the stock needle and jet. Then did the Scar Mod exactly as you described and low and behold on the first shot my bike hasen't ran this good since I first got her!
    Thanks,
    Rkovic
  13. #12
    Senior Member Knight's Avatar
    Join Date
    Dec 2003
    Location
    Calgary Alberta
    Posts
    3,480
    Default Fuel Pump bypass 2003 1300
    My fuel pump packed in after 55,000 miles on my 2003 1300S , it gave a few indications that it was on it's last legs , with the bike dying and after a couple of minutes the pump was fine again
    So I ran new fuel line from the tank to the carburetor
    It's real easy to do with a few tools
    Hex size 5 , 6
    Sockets 10 mm ,12 mm
    Phillips screw driver
    Needle-nose pliers
    Electrical tape
    Rags/paper towel
    1) Remove seat and right rear side cover
    2) Remove tank and right rear side cover for better access
    (Turn gas OFF , unplug 2 green speedo connectors under right front of tank , lift clips , don't wreck em, mark with a sharpie for ease of installing))((,pull off tank vent hose under right rear of tank, pull off fuel line at petcock)
    3) Pull back rubber boot and disconnect 2 fuel pump wires ( blue/black, green)
    4) Loosen air box by removing the 5 screws holding on the cover ( DO NOT
    over tighten when installing) , remove 10mm bolt and 3 Phillips screws ,
    Undue the tab at the top of the air box and gently pull back being careful
    to not pull the air box from the attached air and breathers hoses
    5) Disconnect fuel line from carburetor
    6) Install new 3/8" fuel line with inline fuel filter between jugs , approximately 12" in length
    I used the rags to catch the few drops of gas when the lines were removed and the tape to cover the wires and cap ends of old fuel line
    TURN OFF GAS WHEN MOTORCYCLE IS PARKED
    http://www.vtxoa.com/forums/picture.php?albumid=211&pictureid=950
  14. #13
    Member VTXNewbie141's Avatar
    Join Date
    Mar 2015
    Location
    Hawthorne
    Posts
    84
    Default
    Guys maybe it's just me being tired, but by 2 turns out you mean 360 degrees and another 360 degrees on the a/f screw?
  15. #14
    Join Date
    Mar 2006
    Location
    SeaTac Wa
    Posts
    2,354
    Default
    Quote Originally Posted by VTXNewbie141 View Post
    yes two full 360* turns from lightly seated
    05 1300S 6901 miles at start 113950 now
    03 1800 R 64100 at start 67500 now dyno results 97.55 HP 110.22 torque
  16. #15
    Senior Member chuck_VTX F's Avatar
    Join Date
    Aug 2007
    Location
    Upper Right Ohio
    Posts
    4,925
    Default
    Quote Originally Posted by Charlie D View Post
    And lightly seated.. like kissing a new born baby... just barely touch... and turn out..
    2005 VTX1800 "F" type II...... Silver Tribal .... 61,000 Miles, Purchased Feb, 2005.
    I am Right, ...................... because I am a lefty.................. I am retired,, .................and NO I will not fix your car...
    MTC clutch & springs.. K&N Air Filter. Garmin GPS.
  17. #16
    Join Date
    Mar 2015
    Location
    Hawthorne
    Posts
    84
    Default
    Quote Originally Posted by chuck_VTX F View Post
    Thanks, i have a D-Shaped socket already so i think ill be doing this as soon as my pipes arrive. I dont really want to put an intake on the bike as i like the look of it the way it is, im just going to put in a KN filter with the cobra speedsters. Fine tuning is going be a b*tch
  18. #17
    Join Date
    Mar 2015
    Location
    Hawthorne
    Posts
    84
    Default
    Guys, did the Scar mod today! Very easy and great write up. Thanks. Darn breather hoses were a son of a to get back on. Also i found a very nice/easy way to get to the A/F screw. I bought this bit http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 via amazon and used a wobble extension 8" i think on a 1/4 driver. Was able to dial it in easily. Just need a flashlight set up to see. I made marks on the socket for the D tool bit. I can take some pics of my set up if needed. Good luck
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
