Changing rear brake pads (Red Sonja) Decided to document what I did when I changed my rear brakes on the 1300c Step 1Removed the left bolt from the brake housing using a 12mm socket Step 2
Once the bolt is removed the brake housing can pivot on the other bolt Step 3
use a large flat head screwdriver to remove the brake retaining bolt cover Step 4
Once the pin cover is off, Use a 5mm allen wrench to remove the brake retaining bolt. This can require quite some force to break loose Step 5
remove the brake retaining bolt and notice that the brake pad bolt loops are facing down and towards the brake housing. Step 6
I used an old wood clamp to compress the brake caliper in so putting the new pads in would be easier. Step 7
Orient the new pads the same way the old ones came off and reinstall the retaining bolt with the 5mm allen wrench . Dont forget the black bolt cover screw you took off before. Step 8
Pivot the housing back on the rotor while pushing in on the pads so they will line up correctly with the housing retainer clip (you will feel when its right ) Step 9
reinstall the main housing bolt using a 12mm socket wrench ( dont over torque it ) Step 10
Pump the foot brake so the caliper will decompress and snug the housing assembly. Thats it you did a brake job on the rear brakes of your 1300c Author: Red Sonja *I recommend that you pull the calipers off and clean the piston before shoving the piston (and all of the dirt stuck to it) back into the caliper. Also a good time to grease the caliper pins. You should be able to slip the rear caliper off with no further work, howerver, the front will require removal of the wheel. - Ceetro
