How wide is a 240 tire?
+ Reply to Thread
Results 1 to 16 of 16
Thread: How wide is a 240 tire?
  1. #1
    Join Date
    Oct 2005
    Location
    East Texas
    Posts
    161
    Default How wide is a 240 tire?
    How wide is a 240 tire? Has anyone put on a 240 tire with a stock fender? I would like to change the swingarm and wheel and tire but keep the stock fender.
    KD
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member dirtstiff's X's Avatar
    Join Date
    Aug 2007
    Location
    NW Orygone
    Posts
    1,273
    Default
    Divide 240 by 25.400 = 240/25.400= 9.448 inches
    Metric conversion from / to cm to in. is 25.400
    2005 VTX1800R Spec 2 Titanium Pearl
    2013 F6B Deluxe - Black - http://hondaf6b.com/album.php?albumid=106
    RIP JDJ / You will be missed brother, but never forgotten
  4. #3
    Senior Pirate KeyWasted's Avatar
    Join Date
    Jan 2008
    Location
    Key West
    Posts
    6,585
    Default
    This is interesting.
    The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10".
    For example: a tire in the P205/60R15 size has an approved rim width range from 5.5" to 7.5" wide. The tire has a section width of 8.23" (209mm) when mounted on a 6.0" wide wheel. If that tire were mounted on all of the rims within its range, the tire's approximate section width would change plus or minus two tenths of an inch.
    2003 VTX1800 ARRRGH
    VTX BEATS HARLEY and Hitler is Pissed!
    http://www.break.com/usercontent/201...wasted-1912477
    Red Knights MC
    "343"
  5. #4
    Join Date
    Aug 2007
    Location
    NW Orygone
    Posts
    1,273
    Default
    My error; the Metric conversion from mm to inches - multiply inches x 25.400 or divide mm x 25.400 for inches.
    240mm/25.400 = 9.448819 inches, just math.. http://www.sciencemadesimple.com/length_conversion.php
    200mm = 7.87 inches
    40mm = 1.57 inches
    I'm not certain how it 's looked at according to rim size, but will check it out..
    kdO1, I have a 200 on my R with no mod to the fender necessary. Do a search because I think you have to grind the mounting brackets and possibly more for anything wider. Ask some of the many Dark side riders with wide tires. Good Luck!
    Thanks Key,
    Jim
  6. #5
    Senior Member ervin260's Avatar
    Join Date
    Oct 2006
    Location
    Minnetonka, MN
    Posts
    856
    Default
    Quote Originally Posted by kd01 View Post
    KD
    You need a wider fender. There is an other thread about this here on VTXOA.
    Ervin
    VTX 1800/280
  7. #6
    Join Date
    Aug 2007
    Location
    NW Orygone
    Posts
    1,273
    Default
    Great looking bike ERVIN!!
  8. #7
    Join Date
    Aug 2004
    Location
    joliet il
    Posts
    667
    Default
    you do not need a wider fender . there are at least 100 vtxs with the stock fender and a 240 . use the search button . there is even a complete write up on how to do it . remove inner fender and bottle jack the frame ears 1/4 inch pretty simple to do .
    2003 vtx 1800c
  9. #8
    Senior Member whitlow's Avatar
    Join Date
    Jul 2007
    Location
    Victoria, Virginia
    Posts
    1,787
    Default
    You will need a different fender my tire is around 10" wide. I have seen someone that did it and to me it did not look good.
  10. #9
    Senior Member Jon's1800VTXC's Avatar
    Join Date
    Aug 2004
    Location
    Seattle/Everett (AZ in my heart)
    Posts
    15,675
    Default
    Like it's been said you can do it, but it looks a little off. I would rent a port-a-power from a tool rental place to spread the frame ears. In the long run the best look is a SUMO X package
    Why is common sense not so common
    Why doesn't P.E.T.A. ever attack a biker
  11. #10
    Senior Member sixwillwin's Avatar
    Join Date
    Aug 2006
    Location
    Sioux Falls
    Posts
    1,036
    Default
    Here is a 250 underneath a stock fender. If you gonna make it work, its gonna be ugly.
    Edit - How the heck do you make a pic show up and NOT be a thumbnail (without having to use photobucket, etc.)?
    2003 1800C with 1800 final! - 250/240 rear, Jug Huggers, painted engine/polished fins, big bars, tank raised, lotsa stuff SOLD Now 2013 Victory Cross Country in Suede Nuclear Sunset
  12. #11
    Senior Member TASSY5's Avatar
    Join Date
    Nov 2003
    Location
    FLOOD LANDS OF THE SOUTH New Orleans, Louisiana
    Posts
    4,625
    Default
    This Big
  13. #12
    Senior Member dezzy7's Avatar
    Join Date
    Feb 2005
    Location
    North Carolina
    Posts
    5,202
    Default
    This question has been asked a lot over the years. You can keep the stock fender and use a couple of options. You can cut it and weld additional metal in it to make it wider and maintain the stock appearance. Or you can widen it by physically hammering it out... There are bikes on here that have done both.
    You can also buy a steel fender off ebay and custom fit it, or you can buy a number of aftermarket fenders.. The choice is yours it all depends on how you want to handle it.
  14. #13
    Senior Member Eazy-E's Avatar
    Join Date
    Sep 2006
    Location
    Destrehan, Louisiana
    Posts
    7,193
    Default
    Exactly this wide.
    06 Tangelo Pearl 1300C ( Fastest Color)/ 2015 Harley Street Glide
    http://www.bdscycles.com/
  15. #14
    Join Date
    Oct 2006
    Location
    Minnetonka, MN
    Posts
    856
    Default
    Well, a stock C fender is about 9.5" wide (241 mm) at the edges and 8.5" (216 mm) wide inside (inner fender) at the receivers for the frame ears. The rear end of it is narrower, the front is wider. So, I guess you need to stretch that fender, it's not just a bolt-on, without modification.
    Ervin
    VTX 1800/280
  16. #15
    Senior Member RODS X's Avatar
    Join Date
    May 2004
    Location
    East Tennessee
    Posts
    3,211
    Default
    The first guy on the board to use the stock fender with a 240 that I can remember was madmanadam. If I remember correctly he discarded the inner fender,spread the fender by driving a section of 2X4 inside the fender to get the width & then welded nuts inside the fender to bolt to the struts.It turned out pretty good.Shoot him a PM......................................... Rod
    Black 04 1300C with too much stuff
  17. #16
    Join Date
    Nov 2003
    Location
    Posts
    4,625
    Default
    Quote Originally Posted by RODS X View Post
    You might be right about madmanadam but If memory serves me right, I believe VTXROCKETEER did it first.
    http://imageevent.com/germanpete/iconx
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
