How to clean iridium plugs?
+ Reply to Thread
Results 1 to 21 of 21
Thread: How to clean iridium plugs?
  1. #1
    Senior Member rayjohn02's Avatar
    Join Date
    Mar 2005
    Location
    Amarillo, TX
    Posts
    313
    Default How to clean iridium plugs?
    Any suggestions on cleaning the plugs ( removing carbon ) that won't remove the iridium coating. I know the plugs are supposed to last much longer, but what is the advantage if they carbon up? I have not had much luck using carb cleaner or oven cleaner.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member GaryH NC's Avatar
    Join Date
    Jan 2009
    Location
    Charlotte NC (Indian Trail)
    Posts
    634
    Default
    I soaked mine in some Techron overnight then took a very fine wire brush to them.They looked new after that.
    2004 1800C, Hard Krome American Classic pipes, HyperCharger-K&N,PC III,Mustang seat,Bobs block off plates,pair mod,Switchblade 2 up,
    200 Metz rear tire..and lots of chrome goodies..
  4. #3
    Member
    Join Date
    Jan 2009
    Location
    roanoke,va
    Posts
    62
    Default plugs
    they make a sparkplug cleaner uses air and somekind of dust I have one workes very well. I got mine from the snap-on tool truck. brian
  5. #4
    Senior Member Hounddogohio's Avatar
    Join Date
    Nov 2007
    Location
    Columbus,Ohio
    Posts
    1,171
    Default
    Quote Originally Posted by rebal1967 View Post
    Harbor freight sells them also. less than $20.00.
    You plug it into an compressor air hose and it sandblast the tips clean.
    (Not sure how good this is for Iridium plugs)
    Left plug cleaned.
    Don't confuse my personality with my attitude.
    My personality is who I am, and my attitude depends on who you are.
  6. #5
    Senior Member TLynn's Avatar
    Join Date
    Mar 2005
    Location
    Willow Glen CA
    Posts
    537
    Default Ultra-sonic Cleaner
    An ultra-sonic cleaner works well although it weakens the ceramic after several cleanings. Had one crack on me. I suppose if you hang them keeping the ceramic dry that would work better.
  7. #6
    Join Date
    Mar 2005
    Location
    Amarillo, TX
    Posts
    313
    Default
    I have the spark plug cleaner that uses the blast media. I just wonder if it or a wire brush removes the iridium plating.
  8. #7
    Senior Member Jon's1800VTXC's Avatar
    Join Date
    Aug 2004
    Location
    Seattle/Everett (AZ in my heart)
    Posts
    15,483
    Default
    I soak them in brake parts cleaner and use a small brass brush
    Why is common sense not so common
    Why doesn't P.E.T.A. ever attack a biker
  9. #8
    Join Date
    Jan 2009
    Location
    Posts
    634
    Default
    Quote Originally Posted by Jon's1800VTXC View Post
    Thats what i used,the fine brass brush.The Techron seemed to cut the carbon better than the carb cleaner i had.Brake clean is a good idea too...
  10. #9
    Senior Member Apache's Avatar
    Join Date
    Jul 2006
    Location
    Novato, California
    Posts
    984
    Default
    When I was having plug fouling problems from carbon buildup, I used Sea Foam to soak the plugs in. I put the plugs in a small jar and only poured enough Sea Foam in to cover the carboned area and let them soak overnight. I then lightly brushed them clean with a bristle parts cleaner brush and blew them out with an air compressor. Cleaned like new.
    Jack
  11. #10
    Senior Member VTX1800NR's Avatar
    Join Date
    Nov 2007
    Location
    South, Florida
    Posts
    724
    Default
    Hi Jon. I cleaned my iridium plugs with brake cleaner and a brass brush about 6 months ago. A couple days later I read an article from one of the iridium plug manufactures that warned not to use any kind of metal brushed on iridium electrodes. Nylon or similar was suggested. It seems that cleaning the electrode with a metal brush can lead to electrode failure and catastrophic engine damage. I don't know if it is true however I replaced the plugs with new ones that day. I wish I could find the article again
    Just found one of the links
    http://www.globaldenso.com/PLUG/qa/tech/qa_23.html
  12. #11
    Senior Member NDAna's Avatar
    Join Date
    Aug 2005
    Location
    Seattle Metro, U.S.A.
    Posts
    12,843
    Default
    Quote Originally Posted by VTX1800NR View Post
    Link not working?
    Sam/NDAna #15542 IB#38401 '04 1800 C, HID, Audiovox Cruise, 2xDarkSide & enough other stuff to keep me comfortable. Now have H4 HID & LED headlights available NDs.HIDs@gmail.com "Can you see me now?" For DarkSide info go here http://mcdarksiders.forumotion.com
  13. #12
    Senior Member ShowTime56's Avatar
    Join Date
    Oct 2005
    Location
    Saint Louis, Missouri
    Posts
    5,578
    Default
    When mine start looking a little carboned up...............................I hit the freeway and twist the throttle. That is the easiest way to keep um clean............................................. ....Dont baby it, nail it!
    Show
    "Specializing in Chrome teeth" "Thats 31Ts if you know what I mean!"
  14. #13
    Senior Member tin-indian's Avatar
    Join Date
    Mar 2005
    Location
    N/E Ohio
    Posts
    1,197
    Default
    Thats right, crank that bike a little, let the plugs heat up. If that doesn't work, then brake cleaner or seafoam and a nylon brush
  15. #14
    Join Date
    Nov 2007
    Location
    South, Florida
    Posts
    724
    Default
    Quote Originally Posted by NDAna View Post
    Link not working?
    I just clicked the link in my post and your quote of my post. Both worked and brought up the "Denso" question and answer blurb about not using a brass brush. Maybe a browser problem
  16. #15
    Senior Member richard head's Avatar
    Join Date
    Nov 2008
    Location
    Atlanta
    Posts
    596
    Default
    Easiest way to clean plugs ,run bike like you stole it.And don't copy your hardley friends and "blip" throttle while idling.(they do that to keep there motor from dieing,yuc,yuc!)That only pours gas on an allready rich mix.Don't even look at plugs unless it starts missing ,or you're getting ready for a long trip.If they appear fouled ,Replace! Recently I checked my plugs in prep for a long ride ,and they looked fine .But I run the hell out of mine.The money we're talking about to replace doesn't even get you warmed up at the local watering hole.Get your priorities straight.
  17. #16
    Junior Member
    Join Date
    Jan 2006
    Location
    INDY
    Posts
    27
    Default Pull down the throttle
    Read below
    PULL DOWN THE THROTTLE AN LET IT RUN, YOU FEEL LIKE A BULLET OUT OF A GUN.
  18. #17
    Senior Member mark_1bx's Avatar
    Join Date
    Oct 2004
    Location
    IL
    Posts
    8,541
    Default
    Quote Originally Posted by ShowTime56 View Post
    Show
    That's the way NGK say's to clean them.
    I was told a while back that putting any kind of brush to a iridium plug was not recommended and ruins the plug. I tried to find that info to c/p but couldn't find it to back it up with a link. Sorry
    M STAR KMA
  19. #18
    Join Date
    Mar 2005
    Location
    N/E Ohio
    Posts
    1,197
    Default
    My bike was one of the first '02s that had all the problems w/plugs fouling. Honda engineers came up to Warren, OH several times to work on it, and it was shipped back to Marysville to have them work on it. When all was said and done, they decided that the proper fix was to go 1 heat range hotter on the plugs on all '02s and early '03s, which has been said on VTXOA several times.
    But I still find that when my wife or son ride my bike allot (they both ride like pansys) that my plugs still foul out. When I'm doing the majority of the riding, they don't foul out. But I'm still wondering if I were to go 1 more heat range hotter if it would be better.
    just a random thought
  20. #19
    Senior Member DBoyz's Avatar
    Join Date
    Feb 2006
    Location
    south FL
    Posts
    2,460
    Default
    The above links didn't work for me either, but here's the link that does:
    http://www.globaldenso.com/en/produc...ech/qa_23.html
    The last line is interesting, basically it says only clean the plugs to get you running again better to buy new ones. It could be a sales pitch especially for what most charge for the iridium plugs.
  21. #20
    Join Date
    Nov 2008
    Location
    Atlanta
    Posts
    596
    Default
    What read into link is,if you are on the road with a fouled plug .And happen to have brought along all your plug cleaning tools .It may kindoff work as a stopgate measure .Relace the plugs
  22. #21
    Member
    Join Date
    Aug 2006
    Location
    sunny Florida
    Posts
    35
    Default irridium plug cleaning
    My one range hotter irridium fouled after 20,000 miles of too rich low end. I cleaned em with a plug sandblaster,....gaps were still perfect,....eyeballed em after 5000 miles and re-tuned Powercommander,,.....good to go. Pretty tough plugs.
    JC
    02 C Darkside 3x 205-65-KH16 26psi
    J.C.
    'Life is not measured by the # of breaths we take,.but by the moments that take our breath away'
    02 1800 C Blk, Corbin , Drag Spec Tach, Roadhouse, airbox holes, K&N, heat shield, relocate IAT, desmog, IK-16 plugs, PC III usb, lean SCXriders map, Progressive 440 rear + front springs, 5wt, raised/narrowed foot pegs, 44 mpg, DARKSIDE 205-65-R16 KH-16 28psi
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
