Heat & JB Weld
+ Reply to Thread
Results 1 to 9 of 9
Thread: Heat & JB Weld
  1. #1
    Senior Member zebian2's Avatar
    Join Date
    Dec 2003
    Location
    Federal Way,WA
    Posts
    1,910
    Default Heat & JB Weld
    Greetings to all.
    Would the JB weld dry quicker if I apply heat to it? or the heat might slow the drying process?
    Thank you.
    Jamal
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member Jon's1800VTXC's Avatar
    Join Date
    Aug 2004
    Location
    Seattle/Everett (AZ in my heart)
    Posts
    15,467
    Default
    Quote Originally Posted by zebian2 View Post
    Greetings to all.
    Thank you.
    Jamal
    Just buy some JB Quik
    Why is common sense not so common
    Why doesn't P.E.T.A. ever attack a biker
  4. #3
    Senior Member SGT MacGyver's Avatar
    Join Date
    Oct 2005
    Location
    Roy Washington
    Posts
    658
    Default
    I don't think so. I think the heat that is generated durring curing is more of a byproduct of curring and not the cure it's self. JMO
    VTX1800R, C Exhaust, HD Bat wing, Audiovox Cruise Control, Tskiu Hard Bags, Home made hitch, HD Batt Wing and a Good Year 205-60-R16 Tripple tread (Yea that's a Car Tire) and a little'n on the side just for fun
  5. #4
    Senior Member bigd_74's Avatar
    Join Date
    Jun 2006
    Location
    Graham, WA
    Posts
    3,386
    Default
    Quote Originally Posted by Jon's1800VTXC View Post
    +1 on the JB Qwik - it is just that!
    Proud C.R.A.P. Member #29 - 2004 1300c Black, BuBs
    "An excellent man, like precious metal, is in every way invariable; A villain, like the beams of a balance, is always varying, upwards and downwards." - John Locke
  6. #5
    Join Date
    Dec 2003
    Location
    Federal Way,WA
    Posts
    1,910
    Default
    It' good to know about the JB Quick.
    I'm in the middle of a small project, and I'm using the regular JB, so that is why I'm asking.
    I was not aware of the existing of the JB quick.
    Thank you all.
    Jamal
  7. #6
    Banned
    Join Date
    Aug 2008
    Location
    Washington State, just north of Libtardistan!
    Posts
    8,514
    Default
    I'm in the middle of a small project, and I'm using the regular JB, so that is why I'm asking. I was not aware of the existing of the JB quick.
    Thank you all.
    Jamal
    When you get done with your project and you have a mess to clean up I highly recomend Lift-Off No.4 to do the job. You can get it at Lowes or Home Depot , it is non toxic and it will clean JB weld from your hands or anywhere you might have inadvertently smeared it! I just installed some aluminum doublers on my Leatherlyke saddle bags to prevent them from cracking. Having the aircraft engineering mindset from 27 years at Boeing I decided to add an adhesive to the doublers even though the instructions did not call for it. I used a Boeing spec adhesive that is very strong but very messy and ended up with goop smeared everywhere. Lift Off cleaned it all up. I think it would also work on cleaning melted shoe soles from hot exhaust pipes too!
  8. #7
    Senior Member NDAna's Avatar
    Join Date
    Aug 2005
    Location
    Seattle Metro, U.S.A.
    Posts
    12,832
    Default
    Usually a moderate amount of heat will increase the speed of set up.
    Sam/NDAna #15542 IB#38401 '04 1800 C, HID, Audiovox Cruise, 2xDarkSide & enough other stuff to keep me comfortable. Now have H4 HID & LED headlights available NDs.HIDs@gmail.com "Can you see me now?" For DarkSide info go here http://mcdarksiders.forumotion.com
  9. #8
    Join Date
    Dec 2003
    Location
    Federal Way,WA
    Posts
    1,910
    Default
    Quote Originally Posted by X-Beast Driver View Post
    Good to know.
    Thank you.
    Jamal
  10. #9
    Senior Member ChromeMagnon's Avatar
    Join Date
    May 2006
    Location
    Puyallup, WA
    Posts
    587
    Default
    From the JB Weld website:
    "DRYING: Allow 4-6 hours for drying before handling. Allow to dry overnight (approximately 15 hours) before putting object to use. J-B WELD works faster if used in a room with a temperature above 50� F. After J-B WELD has cured for six hours, a heat lamp or light bulb placed near the weld will speed drying time."
    I didnt have a heat lamp, per se, last time I use JB Weld so I used one of those single halogen work lamps and put it about 6 inches from the project...warmed it right up.
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
