Battery tender is hot?
+ Reply to Thread
Results 1 to 10 of 10
Thread: Battery tender is hot?
  1. #1
    Join Date
    Nov 2003
    Posts
    407
    Default Battery tender is hot?
    It has been on for about 3 hours and still show a red light. It is very warm to the touch. Am I looking at buying a new battery? It is the stock battery from 2002. The bike starts great, lights look good. Just wondering do battery tenders get pretty warm (hot) almost? Is this the first sign of a battery going away?
    Boogie
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    May 2004
    Posts
    175
    Default
    has it been giving you trouble starting in the past? what is the reason for charging it was the bike in storage? the charger will naturally get warm to the touch while charging and so will the battery, if the bike is starting good with no trouble then put it back in...purp
    Magenta Metallic 04/c Snuffleupagus/aka The Grawlix
    careful what you wish........you just might get it
  4. #3
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    58,455
    Default
    Yes the Tender gets hot after a while. Yes I would replace that battery soon, as you know it is old for a bike battery and it may not give you a warning before it just won't start the bike. You could be a looooong way from home cause it never dies when you're in the driveway.
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  5. #4
    Join Date
    Jun 2004
    Location
    Robbinsville, NJ
    Posts
    195
    Default
    My nighthawk battery lastet 2 or 3 seasons consistently for 20 years. Was wondering if sealed bike batteries last any longer?
    '02 VTX 1800 C
    Cobra Slash-cuts
    PCIIIUSB
    Hypercharger Pro
    Corbin Young Gun Seat
  6. #5
    Join Date
    Nov 2003
    Location
    Albuquerque,New Mexico U.S.A.
    Posts
    476
    Default
    Mine gets hot as well. As far as charging for long periods,I've noticed if you unplug it and plug it back in the light turns green. Not quite sure why it does this.
    My anger management class pisses me off !!!!!
    Ex X rider '02 1800 Retro,'05 1800F
    '06 Goldwing Dark Red
  7. #6
    Join Date
    Jan 2004
    Location
    Orange, CA (Looking at Utah!)
    Posts
    679
    Default
    Mine gets pretty warm. I just leave it and the green light comes on. Remember that it is a slow charge rate, especially if you got the Jr.
    Mostly, I use it to keep my truck charged. I ride my X most of the time.
    If you want to get a new battery you can just go to HDL and order a new factory battery for about $70. I went to e-bay and found an Odyssey battery (PC-545) for $50 plus $11 S&H.
    I replaced my battery because it was about 2 1/2 years old and I thought it wasn't starting as well as when it was new. It made a difference! Also, I don't have to worry about that inconvenient battery failure while away from home.
    Be cool, ride safe
    6/21/05 is when I got the best bike I have ever had.
    2005 GL 1800 ABS, Silver
    Smooth as silk! Like Buttah!
    DARK SIDER #0009
    Front: Bridgestone Battlax 130/70H18 @ 35 PSI
    Rear: Dunlop 195/55HR16 3D ROF @ 35 PSI
    Hey! Look at MY weather!
    http://www.weather.com/outlook/homeandg ... _schoolday
  8. #7
    Join Date
    Nov 2003
    Posts
    407
    Default
    I unplugged it last night before going to bed just to play it safe. Plugged it back in this morning and the red light came on for about 20 sec. then went green. Yep, I better play it safe and just order a new one.
    Thanks!
    Boogie
  9. #8
    Junior Member
    Join Date
    Apr 2004
    Location
    Scottsdale, AZ
    Posts
    11
    Default
    There is no harm in leaving Battery Tender on for extended periods of time. It us desigbed to charge batter up to full level and then can be left on to keep it fully charges, Batteries go bad when the bike is in storage or not rode for several weeks. The red liight comes on to let you know when the connection is correct and starts to blink when charging. The green begins to blink when the battery has greater than 80% of its capacity available for use. When the green light stops flashing and burns steady, the battery is fully charged. So do not worry if the Battery Tender feels warm or the green light stays on, it is suppose to. Hope this helps answer your concerns.
    2003 VTX1800R
  10. #9
    Join Date
    Jan 2004
    Location
    Posts
    679
    Be cool, ride safe
    DARK SIDER #0009
  11. #10
    VTXROCKETEER
    Guest
    Default
    ......about tender here some words......
    http://www.vtxoa.com/forums/viewtopic.php?t=31148
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
