oops pulled the spark plug wire out of the boot
+ Reply to Thread
Results 1 to 8 of 8
Thread: oops pulled the spark plug wire out of the boot
  1. #1
    Junior Member
    Join Date
    Apr 2009
    Location
    Puget Sound area
    Posts
    27
    Default oops pulled the spark plug wire out of the boot
    I was pulling the spark plug boot off of the spark plug and I slipped and pulled the wire out of the boot.........I pushed it back in hard so I'm hoping it's OK. Is that a problem? Should I replace the wire/boot or would I have to replace the whole harness?
    Thanks!
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member slanca's Avatar
    Join Date
    Mar 2009
    Location
    San Antonio, TX
    Posts
    187
    Default
    Did the plug connector come off the wire? If not, you should be okay. But, that's based on experience from shade treeing on cars. If the connector pulled off, I'd suggest looking into new wires.
    A bad day riding is better than a good day at work!
  4. #3
    Senior Member bo_mull's Avatar
    Join Date
    Jun 2008
    Location
    Cleveland, TN.
    Posts
    455
    Default
    I pulled mine off last week, If you look inside the boot, there is a pin in there that sticks inside the wire, Just push the wire back in the boot and you should be ok.
    2007 1300R Titanium, Mustang Wide Touring Seat, MS Windshield, Easy Brackets, Vance & Hines Bigshots with Quiet Baffles, Pair Valve Removed. All-Balls Steering Bearings
  5. #4
    Join Date
    Mar 2008
    Location
    North Side of planet urth
    Posts
    5,097
    Default
    Try putting a very small amount of Dielectric Grease on the inside lip of the boot and the next time around you shouldn't have any problem gettign the boots off.
    “Let me control the media and I will turn any nation into a herd of pigs” – Joseph Goebbels
    Our current Federal Government is what our Founding Fathers Tried To Prevent.
    When only cops have guns, it's called a "police state".
  6. #5
    Senior Member korbo's Avatar
    Join Date
    Apr 2006
    Location
    Central Jersey
    Posts
    259
    Default
    Did the same thing about a year ago, all I did was push back together and it is working well. I don't believe that these s/p wires are 'attached' to the boot. As long as you didn't mash up the end of the wire, you should be OK
    korbo
    '05 VTX1300C, BadX'd, CTR'd, Natl Cycle 2up, progressive front springs, NEW AVONS and DYNABEEDS(2nd try, Love em both!!!)
  7. #6
    Senior Member SCteach's Avatar
    Join Date
    Feb 2009
    Location
    Charleston, SC
    Posts
    1,822
    Default
    I am not sure how the plug wires are assembled on the X. Sounds like a few have pulled them apart and had success just pushing them back into the boot. However, when working with cars and this happens, I found it best in the long run to just replace the wire. Helpful hint when removing the plug wires, or any rubber part from metal, simply twist right and left while pulling to help brake the seal. Comes off a lot easier. Also as mentioned above, some dielectrical grease will keep the plug wires from sticking too.
    Candy red 05 1300C-Sold
    A-10 Thunderbolt paint 03 1800R, PCIII, Reinhardt pipes, Tornado intake, Dyno'd, PAIR mod, ultimateX lowrider seat, ISO grips w/boss, brake away cruise.
    01 Harley Road Glide Screaming Eagle
  8. #7
    Senior Member BlueMaxim's Avatar
    Join Date
    Jul 2008
    Location
    Vicksburg, Mississippi
    Posts
    1,425
    Default
    A lot of bike wires are made different that automotive wires. Many have removable caps that just twist off. So twist it back on the aforementioned pin and all should be good.
    2007 VTX 1300R On Civil Rights: MLK fought to gain them NRA fights to retain them I am the NRA
  9. #8
    Senior Member LoneRanger's Avatar
    Join Date
    Jan 2006
    Location
    Cincinnati-O
    Posts
    3,177
    Default
    Quote Originally Posted by bo_mull View Post
    This is what I did 20,000 miles ago. Still running on that same wire with no issues.
    "This country has come to feel the same when Congress is in session as when the baby gets hold of a hammer." Will Rogers
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
