Results 1 to 8 of 8
Thread: rattle at 30mph
  1. #1
    Junior Member
    Join Date
    Jun 2009
    Location
    southern wv
    Posts
    5
    Red face rattle at 30mph
    i have encountered a rattle at 30 mph on accel or decel or if you hold the speed there only if you are by yourself.. i have tightened all visible bolts that i can see but nothing changes... any ideas? its driving me crazy
  2. #2
    Junior Member bigbench400's Avatar
    Join Date
    Sep 2008
    Location
    versailles, mo
    Posts
    24
    Default Headlight rattle?
    Look it up in the threads Headlight Rattle I think this might be ur problem--maybe the shocks rotate the top cover or get progressive shocks
    BiG BeNcH 400 205
  3. #3
    Senior Member Venjurak's Avatar
    Join Date
    Apr 2007
    Location
    Pittsboro, IN
    Posts
    237
    Default
    Quote Originally Posted by tazman5157 View Post
    I've had the EXACT same problem. Never been able to lock it down. Originally I had a rattle in my speedo which I fixed but the 30mph rattle seems to be coming from somewhere in the front of the engine but I cannot find anything loose that would cause the rattle. It only happens at exactly 30mph just a little over or under and it goes away. Very strange.
    Old Ride: 2006 VTX1300C
    Current Ride: 2011 Yamaha Stryker
  4. #4
    Member chadwce's Avatar
    Join Date
    Sep 2009
    Location
    Goodyear, AZ
    Posts
    90
    Default
    I had a rattle that turned out to be the small silicon rubber grommet that isolates the heat shield needed to be replaced.
    2007 VTX1300C, VTX1800R handlebars, Invicta Motorsports fairing, Cobra highway bar, Wolo Bad Boy Air Horn, Mustang seat, NC Cruiseliner saddlebags, Hondaline heel and toe shifter, DMY trunk, All Balls, Walmart Lights, Veypor VP2 Computer
  5. #5
    Join Date
    Jan 2010
    Location
    charleston wv
    Posts
    110
    Default 30 mph rattle
    i had the same issue with my xr and as some one said the speedo always rattles on these bikes. fixed that and it was still there so i kept on looking and found it to be the radiator cover at a certain speed, so a black zip tie through the mesh and around the frame fixed that also. these rattles come and go.
  6. #6
    Senior Member lv2cruz's Avatar
    Join Date
    Jul 2008
    Location
    Nampa,Idaho
    Posts
    1,417
    Default
    Might also check your horn bracket. I had a similar rattle, drove me nuts. Finally found that the horn bracket was vibrating. Tightened it up, all is well. Just a thought.
    2004 VTX1300S
  7. #7
    Join Date
    Apr 2007
    Location
    Pittsboro, IN
    Posts
    237
    Default
    Thanks guys! I'll check these clues out. This thing has drove me nuts for a couple of years. I had to replace one of the rubber gromets on the rear cyclinder pipe about 2 years ago. I will check the front cylinder head as well as the horn bracket and the radiator cover. Thanks for the tips!
  8. #8
    Join Date
    Apr 2007
    Location
    Pittsboro, IN
    Posts
    237
    Default
    Ok, so far no luck in finding the rattle. Weird thing is that rattle disappears when riding with my wife in the back. Can't explain it. If it is just me, I get the 30mph rattle. I hear it when I am decelerating and it hits the 30 mark briefly or if I drive at 30mph, it is a constant rattle. Just not if my wife is on the back.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not edit your posts
