rattle at 30mph
+ Reply to Thread
Results 1 to 10 of 10
Thread: rattle at 30mph
  1. #1
    Join Date
    Jun 2009
    Location
    southern wv
    Posts
    5
    Red face rattle at 30mph
    i have encountered a rattle at 30 mph on accel or decel or if you hold the speed there only if you are by yourself.. i have tightened all visible bolts that i can see but nothing changes... any ideas? its driving me crazy
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Junior Member bigbench400's Avatar
    Join Date
    Sep 2008
    Location
    versailles, mo
    Posts
    24
    Default Headlight rattle?
    Look it up in the threads Headlight Rattle I think this might be ur problem--maybe the shocks rotate the top cover or get progressive shocks
    BiG BeNcH 400 205
  4. #3
    Senior Member Venjurak's Avatar
    Join Date
    Apr 2007
    Location
    Pittsboro, IN
    Posts
    237
    Default
    Quote Originally Posted by tazman5157 View Post
    I've had the EXACT same problem. Never been able to lock it down. Originally I had a rattle in my speedo which I fixed but the 30mph rattle seems to be coming from somewhere in the front of the engine but I cannot find anything loose that would cause the rattle. It only happens at exactly 30mph just a little over or under and it goes away. Very strange.
    Old Ride: 2006 VTX1300C
    Current Ride: 2011 Yamaha Stryker
  5. #4
    Member chadwce's Avatar
    Join Date
    Sep 2009
    Location
    Goodyear, AZ
    Posts
    94
    Default
    I had a rattle that turned out to be the small silicon rubber grommet that isolates the heat shield needed to be replaced.
    2007 VTX1300C, VTX1800R handlebars, Invicta Motorsports fairing, Cobra highway bar, Wolo Bad Boy Air Horn, Mustang seat, NC Cruiseliner saddlebags, Hondaline heel and toe shifter, DMY trunk, All Balls, Walmart Lights, Veypor VP2 Computer
  6. #5
    Join Date
    Jan 2010
    Location
    charleston wv
    Posts
    110
    Default 30 mph rattle
    i had the same issue with my xr and as some one said the speedo always rattles on these bikes. fixed that and it was still there so i kept on looking and found it to be the radiator cover at a certain speed, so a black zip tie through the mesh and around the frame fixed that also. these rattles come and go.
  7. #6
    Senior Member lv2cruz's Avatar
    Join Date
    Jul 2008
    Location
    Nampa,Idaho
    Posts
    1,416
    Default
    Might also check your horn bracket. I had a similar rattle, drove me nuts. Finally found that the horn bracket was vibrating. Tightened it up, all is well. Just a thought.
    2004 VTX1300S
  8. #7
    Join Date
    Apr 2007
    Location
    Pittsboro, IN
    Posts
    237
    Default
    Thanks guys! I'll check these clues out. This thing has drove me nuts for a couple of years. I had to replace one of the rubber gromets on the rear cyclinder pipe about 2 years ago. I will check the front cylinder head as well as the horn bracket and the radiator cover. Thanks for the tips!
  9. #8
    Join Date
    Apr 2007
    Location
    Pittsboro, IN
    Posts
    237
    Default
    Ok, so far no luck in finding the rattle. Weird thing is that rattle disappears when riding with my wife in the back. Can't explain it. If it is just me, I get the 30mph rattle. I hear it when I am decelerating and it hits the 30 mark briefly or if I drive at 30mph, it is a constant rattle. Just not if my wife is on the back.
  10. #9
    Junior Member slowpoke730's Avatar
    Join Date
    Jan 2015
    Location
    South Boston Virginia
    Posts
    23
    Default Rattle
    Quote Originally Posted by Venjurak View Post
    What did you do to fix the speedometer rattle? I just put a tank bib on my 09 1300 r and I now have a rattle from the speedometer....
  11. #10
    Junior Member Montana Redneck's Avatar
    Join Date
    Jun 2014
    Location
    Colorado
    Posts
    21
    Default Rattles, noise from speedometer...
    Quote Originally Posted by slowpoke730 View Post
    I isolated the noise directly from the speedometer...to do this, try at around 30 mph, carefully, press down on glass on speedometer . If things quiet down, then you have a bit of a loose cover. To fix it, I took a hair braide, or a rubber band will work, and"pinch" it into the space between the glass and the chrome. To get a really good "pinch", use a fine edged screw diver to push it in. Once done the noise will stop .
    "Hope is a good thing...maybe the best of things...and no good thing ever dies"
    2005 Honda Neo Retro VTX 1800 Cobalt blue, stock pipes, new dunlop tires (both) ...Kuryakyn Iso grips with throttle boss, aluminum running boards, Windshield with chrome accents no tint, quick release saddlebags, Mustang seats
+ Reply to Thread
Quick Reply Quick Reply
Please enter the name by which you would like to log-in and be known on this site.
Where you live
Please select your insurance company (Optional)
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not post attachments
  • You may not edit your posts
