How do I remove Vance and Hines Baffles
+ Reply to Thread
Results 1 to 24 of 24
Thread: How do I remove Vance and Hines Baffles
  1. #1
    Senior Member Paul Clouser's Avatar
    Join Date
    Jan 2007
    Location
    Somerville, Alabama
    Posts
    172
    Default How do I remove Vance and Hines Baffles
    I tried to remove the quiet baffles in my Vance and Hines big shots last night with no success. Heat shields are off and allen screw is out. They will move back about and inch and then no more. How about a slide hammer or other means of removal? Any help would be appreciated.
    Silver 2003 VTX1800 RS
    Burgandy 2008 Suzuki C109
    Revtek DFO,Vance and Hines big shots,Thunder Hurricane intake
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Oct 2006
    Posts
    1,998
    Default
    slide hammer is one way ...
    but if you can get them out about an inch, try sliding a wood dowel
    of the same diameter inside the baffle so you can get locking pliers
    on the baffle without crimping it and try turning it ... then pull, then
    turn ... what you are fighting in there is rust and soot which tends
    to 'weld' them buggers in tight ...
    2005 VTX 1800 F3 (Canada)
  4. #3
    Senior Member whitlow's Avatar
    Join Date
    Jul 2007
    Location
    Victoria, Virginia
    Posts
    1,787
    Default
    I also had to make a slide hammer to get my old one out.
  5. #4
    Default
    Spray them down with WD-40 or Liquid Wrench for a while. Take a metal rod and bend one end in a vice approx. 1". Slide the bent end into the baffle and try to "hook" it on the perferations and pull it out. Probably will take several tries because they tend to get stuck tight.
  6. #5
    Senior Member BartowBiker's Avatar
    Join Date
    Jul 2009
    Location
    bartow florida
    Posts
    180
    Default
    how much louder will that make them.....didnt know you could do that...i might have to do it now myself.....dang im learning alot on this site gettin a head ache
    05 vtx1300c
  7. #6
    Member Ripped1800's Avatar
    Join Date
    May 2009
    Location
    O'Fallon, MO
    Posts
    88
    Default
    Quote Originally Posted by BartowBiker View Post
    Loud enough to get you a ticket if you are in the wrong area....and that is the way I like it!!!!
  8. #7
    Senior Member JEC1800N's Avatar
    Join Date
    Sep 2008
    Location
    Nazareth, PA
    Posts
    129
    Default
    I bought my big shots new is it safe to assume that they all ship with quiet baffles?
    V&H Bigshots, Fatty Bars, Big Baron Air Kit, Memphis Shades, Big Bike Lightbar, Bad X seat mod, ISO Grips, NEO Backrest, Desmog
  9. #8
    Join Date
    Aug 2006
    Location
    Waxahachie Tx
    Posts
    607
    Default removing baffles V&H
    Don't forget when removing these baffles you will loose a little hp & torque. It may sound better to you but a dyno will prove the performance loss. The built in crossover isn't enough back pressure. Just a proven thought.
  10. #9
    Join Date
    Jun 2004
    Location
    Denver and Chicago
    Posts
    7,076
    Default
    Quote Originally Posted by JEC1800N View Post
    No. The C/F models ship with other baffles and you have to buy the quiet ones.
    It looks like you have a N model - those would have the quiet baffles.
    Do not go gentle into that good night. Rage, rage against the dying of the light - Dylan Thomas
    All that is necessary for the triumph of evil is that good men do nothing - Edmund Burke
    If you can, help others; if you cannot do that, at least do not harm them. - Dalai Lama
  11. #10
    Join Date
    Jan 2007
    Location
    Somerville, Alabama
    Posts
    172
    Default
    I'm really removing the baffles to see if I still get an annoying rattle at idle. Just installed the pipes and was getting this intermittent rattle. Removed heat shields and still a rattle. Baffles are very tight. Maybe I can get the baffles out and make the bike so loud I can't hear the rattle.
  12. #11
    Join Date
    Jan 2007
    Location
    Somerville, Alabama
    Posts
    172
    Default
    Rented a slide hammer to remove the baffles. Still getting an intermittent rattling noise @ idle. Not sure what to look at next. Some kind of funky harmonics thing going on. On a positive note this thing really talks without baffles?
  13. #12
    Join Date
    Jun 2007
    Posts
    523
    Default
    They come with the "regular" baffle, which is not the quiet baffle. You don't want to run those pipes w no baffle as you will lose all your low end torque and they will be way too loud.
    V/H Bigshots, Pwr. Cmdr, Honda w.s., Clearview replacement Lexan (2 inches wider), HID 50 watt kit, Honda light bar, U. S. Saddlebags, Ultimate Big Boy seat, rider backrest, Ultimate passenger seat, Cobra Fat Engine guard with Kuryakin Highway pegs, Cobra chrome license plate mount, Barons Big Air Kit, Kisan Signal Minder, LED rear brake and signal lights, desmog.
  14. #13
    Join Date
    Jun 2007
    Posts
    523
    Default
    Quote Originally Posted by Paul Clouser View Post
    Check the right floor board where the heat shield makes an elbow. I think you will find the heat shield touching the inside bracket that holds the floor board. I had to shim mine out with one washer to give enough clearance. Rattle gone.
  15. #14
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    59,157
    Default
    You may also have had a band clamp bracket snap off the heat shield
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  16. #15
    Senior Member Apache's Avatar
    Join Date
    Jul 2006
    Location
    Novato, California
    Posts
    984
    Default
    The problem is the packing is jambing in between the baffle front collar and the pipes. When you get the baffles out reverse the front collar and weld it back in place, then you should not have much trouble removing the baffles in the future.
    As someone suggested spray heavy with WD40 or some other spray lubricant. Be sure to clean the inside of the pipes real good before re-installing the baffles. I use a 2" brass wire brush in a 12" electric drill extension. After brushing, start the bike and rev it up a little to blow the pipes clean.
    All that is needed for the evil to succeed is for the decent human beings to do nothing.
    Darkside Bridgestone Potenza G019 grid 205/60/16 V-rated, 2002 VTX1800C with a bunch of extra crap it probably doesn't need.
  17. #16
    Join Date
    May 2005
    Location
    Green Bay, WI
    Posts
    835
    Default
    Quote Originally Posted by Chicago-Spike View Post
    OMG, please don't even mention this or my freakin piece of crap Vance and Hines may break another one of these. Vance and Hines replaced both my shields quite some time ago, they continue to break so I have them welded now, the marks show a bit, but I found a good welder that doesn't leave much of a mark. I have another one right now that just went, so off they come again. I'm so sick of this ****.
    I really want the pipes that vtxbronco has on his bike, he said they were Cobras, but I can't find them at HDL damnit. His bike looks like an 1800 R so I'm guessing they'd fit mine too.
    These are his, anybody know what they're called?
    Overtime pays more because of what you're missing...money isn't everything!
  18. #17
    Join Date
    Sep 2006
    Location
    Rapid City, SD
    Posts
    5,143
    Default
    Cobra Speedster Slashdowns is what they are called. On HDL for the R/N model
    Cobra 2 1/2" Angled Slashcut Exhaust for 1800C
    I think the nice curve is the early version that is now more like the R/N model above?
    -Richard
    05 1800F/N - the goodies keep getting better...
    I walk on water
    CLICK here for Darkside Forum
    DS -01/06/07
  19. #18
    Join Date
    May 2005
    Location
    Green Bay, WI
    Posts
    835
    Default
    The top model doesn't look good IMHO, the bottom version is absolutely beautiful!
    Quote Originally Posted by nodakbassmaster View Post
  20. #19
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    59,157
    Default
    www.cobrausa.com
    What you got is for 2 different model VTX's. C models that have the nice curve is called "Angled Slashcut"
    http://cobrausa.com/exhaust_detail.p...2&product_id=1&
    They don;t make that for the R/N
    2002 VTX1800 C
  21. #20
    Join Date
    May 2005
    Location
    Green Bay, WI
    Posts
    835
    Default
    www.cobrausa.com
    that's what I thought, but then vtxbronco looks to have a retro with the nice looking pipes. Or did he put different tins on his C?
  22. #21
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    59,157
    Default
    No, he just put C pipes on his R. You would need to get a C bracket and you might have to cut/grind some of the floorboard mount to give way for the heat shield a little
    2002 VTX1800 C
  23. #22
    Join Date
    May 2005
    Location
    Green Bay, WI
    Posts
    835
    Default
    Hmmm, I may have to contact him for more info, I really really really love those pipes.
    Thanks Spike!
  24. #23
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    59,157
    Default
    No problem
    2002 VTX1800 C
  25. #24
    Junior Member
    Join Date
    Jul 2014
    Location
    IA
    Posts
    1
    Default wanted to try vance and hines short shots without baffles and figured they were stu
    So figuting 4d40 might try to burn or something i sprayed a mixture of dish soap and water up in there. Next day stripped on baffle screw of course as everything on this scooter is tightened to 10000 foot pounds got the screw out and the baffles were stuck vance and hines short shots on 02 dyna lowrider. Buddy suggested slide hammer but without a zecond thought i got that old bar bell bar ive been trippin over for 9 years and sure enough the threads on that bar very closely match the threads in the baffle louvers!!! Thread it in wiggl waggle and out come the baffles with no hammering pounding heating or other!!!!! If you still need the slide hammer effect slip a 20 pound weight first and use that!!!!!! Glad i could get this tip out there. Its my first harley but not my first repair rodeo! Loooool
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
