How to check oil vtx 1800c
+ Reply to Thread
Results 1 to 10 of 10
Thread: How to check oil vtx 1800c
  1. #1
    Member
    Join Date
    Aug 2009
    Location
    murfreesboro
    Posts
    80
    Default How to check oil vtx 1800c
    Just wondering how to check the oil level should I do it when its running hot cold, I know every bike is a little different. Any advice would be appreciated thanks.
    Attached Images Attached Images
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member PunisherVTX's Avatar
    Join Date
    Aug 2009
    Location
    Northeast
    Posts
    267
    Default
    Quote Originally Posted by nickrprop1 View Post
    Level, undo dipstick, wipe, insert back DO NOT screw it in. Pull out and check. Some state that the marks are all over the chart and inaccurate. Mine is dead on. I suggest you check just after doing an oil change (and filter), refill with the gallon and then check as above. If the dipstick is accurate BINGO you got it
  4. #3
    Member
    Join Date
    Aug 2009
    Location
    murfreesboro
    Posts
    80
    Default
    Do it when its warm or hot and where should it be on the dip stick exactly. Think the mechanic may have over filled me.
  5. #4
    Senior Member Spamaster's Avatar
    Join Date
    Nov 2003
    Location
    Dallas, Oregon
    Posts
    5,451
    Default
    This got me thinking, I cannot remember the last time I check mine.
    I change it so often I just do not think about it.
    2013 Victory Cross Country Tour
  6. #5
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    58,203
    Default
    You do NOT check it with the engine running. Well, you can, but you'll be cleaning the bike and yourself and the floor up for a while afterwards.
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  7. #6
    Senior Member debelt's Avatar
    Join Date
    Feb 2004
    Location
    Norwalk, CA
    Posts
    946
    Default
    On another note, does anyone's 1800 use a little bit of oil? My 1800 C doesn't smoke or anything else obvious, but I do notice it goes through about a pint of oil every 1K miles or so.
    '03 VTX 1800 C, '05 Yamaha Midnight RSV
    "I only use my gun whenever kindness fails" - Robert Earl Keen.
  8. #7
    Senior Member Bigdog 1's Avatar
    Join Date
    Nov 2003
    Location
    Virginia, Midlothian, MR VTX is my hero
    Posts
    5,530
    Default
    Quote Originally Posted by debelt View Post
    Mine used about 4 oz on my 5,000 mile trip out west. I don't call that using oil.
    Send in the Marines
    '09 Victory Vision Tour Premium sold 5/2013
    I miss all my X's
    '04 1300C
    '03 1800C
    '06 1800F
  9. #8
    Join Date
    Jul 2009
    Location
    Proctor, WV westpennsyltucky
    Posts
    6,130
    Default
    the bike should also be level not sitting nm the side stand
    "Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one." Thomas Paine
    Where is our government!
  10. #9
    Senior Member fubar606's Avatar
    Join Date
    Jul 2005
    Location
    Endicott WA.
    Posts
    679
    Default
    I ride a 02 1800 c it never seems to use any oil i change it when i put
    up for winter and ride all summer. (syn)
    life is sexuality transmitted and ALWAYS fatal
    Double Dark
    2002 vtx 1800 C silver (the faster )color
  11. #10
    Senior Member dbx's Avatar
    Join Date
    Mar 2008
    Location
    NH
    Posts
    1,306
    Default
    Ref. manual, let idle for 3-5 mins. shut down for 2-3 mins., hold bike straight upright off kickstand, insert dipstick, don't screw in, upper mark is full, lower mark means add a pint.
    18C-31T-215/65
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
