VTX 1300 coolant replacement
+ Reply to Thread
Results 1 to 21 of 21
Thread: VTX 1300 coolant replacement
  1. #1
    Senior Member barkymarky's Avatar
    Join Date
    Nov 2009
    Location
    Denver, Colorado
    Posts
    247
    Default VTX 1300 coolant replacement
    I just bought my bike and it has 25000 miles on it. I do not know if the coolant has ever been replaced. So,can I just remove the hose from the bottom of the radiator, let it drain, refill, circulate, remove, drain, etc, then put new coolant into the reservoir? Or do I need to take it to the dealer? Thanks for any advice.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member uncas's Avatar
    Join Date
    Dec 2008
    Location
    Merritt Island, Florida
    Posts
    692
    Default
    Quote Originally Posted by barkymarky View Post
    It's really pretty easy. There is a procedure in the manual that shows how. Remove the tank, remove the drain plug, drain the reservoir, refill everything, "burp" it, add more fluid and you're done. Oh...yeah...put the fuel tank back on. There is a service manual floating around this board somewhere that shows the details. Even a caveman can do it.
    Welcome to the board!
    -Mike-
    2003 VTX 1300S
    Memphis Fats Windshield, Saddleman Bags
    Cobra:Tachometer, Sissy Bar, Luggage Rack, Back Rest, Freeway Bars; Lotsa Chrome
  4. #3
    Senior Member Papabear's Avatar
    Join Date
    Jan 2006
    Location
    Woodstock, Illinois
    Posts
    826
    05 VTX 1300 C Gone to a very good home
    99 Valkyrie Standard
  5. #4
    Senior Member Donut's Avatar
    Join Date
    Jan 2005
    Location
    Coloma, Mi. MixRider Member
    Posts
    6,020
    Default
    Do not use Automotive coolant. There has been several post on here that says that Automotive coolant can cause damage to the aluminum ( I be leave it causes corrosion).
    Chicago-spike should have the answer to that.
    Donut Doug
  6. #5
    Senior Member Jack G's Avatar
    Join Date
    Nov 2003
    Location
    Benton,Arkansas
    Posts
    1,557
    Default
    There are some coolants which are NOT good for your Honda. I use Honda premix. Your bike doesn't hold a lot so it doesn't cost that much extra.
    '99 Valkyrie
    Two lane blacktop isn't a highway, its an attitude.
  7. #6
    Old Goat TennX's Avatar
    Join Date
    Jul 2006
    Location
    Memphis,Tn.
    Posts
    21,471
    Default
    Welcome and , I like engine ice. good luck
    Phil "I should be riding" Ford
    06 CBC 1300R Darkside/Foots
  8. #7
    Senior Member stepbill's Avatar
    Join Date
    May 2005
    Location
    Aberdeen, North Carolina
    Posts
    2,054
    Default
    Quote Originally Posted by TennX View Post
    How well does the engine ice work in the winter as an anti-freeze?
  9. #8
    Senior Member Mathwiz's Avatar
    Join Date
    Aug 2005
    Location
    Tennessee
    Posts
    1,800
    Default
    According to the container Engine Ice comes in.....
    -26 deg F
    2007 1300R Mid-South X-Riders #11
  10. #9
    Senior Member WhiteThunder's Avatar
    Join Date
    Jul 2009
    Location
    Ottawa, Canada
    Posts
    936
    Default
    Quote Originally Posted by donut View Post
    use honda pre mix, or coolant that is safe for aluminium blocks!!!! ( any bike coolant should do the job )
    the auto coolant does cause corrosion and gunk build up.
    07' 1300 C ( sold )
    IN TORQUE WE TRUST
  11. #10
    Join Date
    Feb 2004
    Location
    Southern West Virginia
    Posts
    1,552
    Default
    It is not that typical automotive coolants are bad or cause corrosion; its that they contain silica which is intended to scour away boiler scale and rust form the system. The silica is a micro abrasive and most Japaneese makers, including Honda, warn that silica can eventually ruin the seals in the water pump. Further, many coolant bottles fail to tell you if they have silica in the recipe. Honda automotive coolant does not and is more economical to buy than the same product packaged for cyles. If the maker does not specify silica free, then assume it is abrasive.
    prs
    "To hell with them fellas. Buzzards gotta eat, same as worms." Josey Wales
    2004C
  12. #11
    Join Date
    Jul 2006
    Location
    Memphis,Tn.
    Posts
    21,471
    Default
    Quote Originally Posted by stepbill View Post
    It is auntie freeze
  13. #12
    Senior Member rcook52459's Avatar
    Join Date
    Dec 2007
    Location
    portland,ore
    Posts
    877
    Default
    you can use any anti-freeze that says it's silica free.
    2008 1300c pearl yellow,mustang seat,CP punisher bars,progressive springs,hicks CTR.bike now totaled.miss that bike
  14. #13
    Senior Member elwray's Avatar
    Join Date
    Jun 2008
    Location
    NJ
    Posts
    2,086
    Default
    In my VFR I've been using green Prestone - borate and silicate free. That's what will be going into the VTX when the time comes.
    At least as of last week, their 50/50 mix was buy-one-get-one at Walmart for only $7.50 here - check that out!
    2007 VTX1300C Pearl White
  15. #14
    Senior Member pappy in MN's Avatar
    Join Date
    Mar 2006
    Location
    Saint Paul, MN
    Posts
    1,548
    Default 50/50 mix for coolant?
    I am going to flush my system...I know I need silicate free coolant.
    Do I mix it 50/50 with water, or 100% coolant?
    Thanks.
    Pat H 04 1300 S
    "To the world you may be one person,
    but to one person you may be the world."
  16. #15
    Join Date
    Jun 2008
    Location
    NJ
    Posts
    2,086
    Default
    Quote Originally Posted by pappy in MN View Post
    Thanks.
    50/50 unless it is premixed. And use DISTILLED water, not just tap water or spring water. You want to avoid introducing minerals into the system.
  17. #16
    Senior Member JOSHWALEE's Avatar
    Join Date
    Feb 2010
    Location
    MT. SERBAL
    Posts
    2,901
    Default
    I use Toyota Super Long Life (pink). It's silicate free, pre-mixed, and it has a surprisingly high resistance to shock and oxidation.
    entia non sunt multiplicanda praeter necessitatem
    support your
    LOCAL 81
  18. #17
    Join Date
    Jun 2008
    Location
    NJ
    Posts
    2,086
    Default
    Quote Originally Posted by JOSHWALEE View Post
    I heard the Toyota coolant makes your throttle stick....
  19. #18
    Join Date
    Feb 2010
    Location
    MT. SERBAL
    Posts
    2,901
    Default
    Quote Originally Posted by elwray View Post
    I'm a wrench with Lexus. I can't tell you what I really think due to privacy disclosures. It's all a joke though.
    support your
    LOCAL 81
  20. #19
    Join Date
    Nov 2003
    Posts
    3,810
    Default
    I certainly is.
    People can't just stomp on the brakes and turn the ignition off? You have to look at the so called drivers and wonder.
    BTW Original Poster, coolant change is so easy on this bike, don't pay someone to do it. Really.
  21. #20
    Lady Rider kermit's Avatar
    Join Date
    Jun 2007
    Location
    Texarkana, Arkansas
    Posts
    4,189
    Default
    Amen. I love my toyota!!!
    '07 Pearl Uranium Green, 1300CRN
  22. #21
    Join Date
    Jun 2008
    Location
    NJ
    Posts
    2,086
    Default
    My dad has a Lexus and loves it... Aw man I didn't mean to derail this thread, lol sorry.
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
